发表于 2009-6-12 18:57:35
"1。按楼上的说法,Q3、Q4基极电流应该都是30mA左右,Vce都是10V以上,如此一来,静态条件下的Q3/Q4发射极电流都应该在2A以上,与模拟结果存在比较大的差异,难道还有其它因素在起作用?而且,这个静态电流应该与电流放大倍数密切相关,是通过R9限制的么?感觉不是这么回事。 "
how much idle current you get in Q3/Q4 depends on their hFE, once R9 is determined.
"2。C2/R9的存在好像在一定程度上还充当了前馈功能,其前馈量与R9/R10取值有关,关于这个问题,有什么特别的说明么? "
C2/R9 do nothing. C2/R9/R8 form a passive constant current source to increase the phase splitter's open loop gain.
there is no feedforward here.
"3。从电路结构来看,Q3好像是充当了Q4的恒流源负载,因为Q3、Q4使用了相同型号的管子,才需要C2、R8自举回路,如果用互补型号三极管,应该就没有如此复杂,而且还更容易控制静态电流,在这里,是不是也还有其它考虑? "
Q3 is an emitter follower to the signal output from the bootstrap network (C2/R9/R8). the use of the bootstrap network has nothing to do with if Q3/Q4 are of the same transistors. you can get rid of C2 and the amp will continue to work - you will need to use a miller cap to keep it stable, through.
the amp will work if Q4 is configured into a constant current source, or a simple resistor. Actually, that's how this topology is used for preamp.
you can use a complementary pair here, but you will have to temperature compensate them so they are thermally stable. the BJT version of the JLH1969 is inherently thermal stable. so the use of a complementary pair will complicate the design, rather than simplify it. |
