回复: 1
4432DEMO代码中有个配置表,奇怪低波特使用了大的频偏,比如2.4K 用36K频偏,这样带宽
发表于 2011-4-8 13:50:14 | 显示全部楼层 |阅读模式
//         IFBW, COSR, CRO2, CRO1, CRO0, CTG1, CTG0, TDR1, TDR0, MMC1, FDEV, B_TIME,  AFC,         ChargepumpCT
        {0x01, 0x83, 0xc0, 0x13, 0xa9, 0x00, 0x05, 0x13, 0xa9, 0x20, 0x3a, 209,                0x40,        0x80},          //DR: 2.4kbps, DEV: +-36kHz, BBBW: 75.2kHz
        {0x04, 0x41, 0x60, 0x27, 0x52, 0x00, 0x0a, 0x27, 0x52, 0x20, 0x48, 105,                0x40,        0x80},                //DR: 4.8kbps, DEV: +-45kHz, BBBW: 95.3kHz
        {0x91, 0x71, 0x40, 0x34, 0x6e, 0x00, 0x18, 0x4e, 0xa5, 0x20, 0x48, 53,                0x40,        0x80},                //DR: 9.6kbps, DEV: +-45kHz, BBBW: 112.8kHz
        {0x12, 0xc8, 0x00, 0xa3, 0xd7, 0x01, 0x13, 0x51, 0xec, 0x20, 0x13, 50,                0x40,        0x80},                //DR: 10kbps, DEV: +-12kHz, BBBW: 41.7kHz
        {0x13, 0x64, 0x01, 0x47, 0xAE, 0x04, 0x46, 0xa3, 0xd7, 0x20, 0x13, 25,                0x40,        0x80},                //DR: 20kbps, DEV: +-12kHz, BBBW: 45.2kHz
        {0x02, 0x64, 0x01, 0x47, 0xae, 0x05, 0x21, 0x0A, 0x3D, 0x00, 0x20, 13,                0x40,        0x80},                //DR: 40kbps, DEV: +-20kHz, BBBW: 83.2kHz
        {0x05, 0x50, 0x01, 0x99, 0x9A, 0x06, 0x68, 0x0C, 0xCD, 0x00, 0x28, 10,                0x40,        0x80},                //DR: 50kbps, DEV: +-25kHz, BBBW: 112.8kHz
发表于 2011-4-9 21:19:47 | 显示全部楼层
经过测试2.4kbps(最低速度时)我们用2k的频偏测试,因为理论上频偏越小越好,这样发射的SNR越高,可是存在部分收发不能工作的情况。
个人理解为频偏太小,而频率误差现实情况较大,超出了。
请高手指点啊!
GMT+8, 2024-6-2 09:13
