电机型号:90TDY115-2
永磁低速同步电动机
电机转子 (原文件名:DSCF0626.JPG)
电机绕线的地方 (原文件名:DSCF0627.JPG)
程序:正弦波的测试方法
INT8U const SinParam[256]={
128,132,135,138,141,144,147,150,153,156,159,162,165,168,171,174,
177,180,183,186,188,191,194,196,199,202,204,207,209,211,214,216,
218,220,223,225,227,229,231,232,234,236,237,239,241,242,243,245,
246,247,248,249,250,251,252,252,253,254,254,255,255,255,255,255,
255,255,255,255,255,255,254,254,253,252,252,251,250,249,248,247,
246,245,243,242,241,239,237,236,234,232,231,229,227,225,223,220,
218,216,214,211,209,207,204,202,199,196,194,191,188,186,183,180,
177,174,171,168,165,162,159,156,153,150,147,144,141,138,135,132,
129,125,122,119,116,113,110,107,104,101,98,95,92,89,86,83,
80,77,74,71,69,66,63,61,58,55,53,50,48,46,43,41,
39,37,34,32,30,28,26,25,23,21,20,18,16,15,14,12,
11,10,9,8,7,6,5,5,4,3,3,2,2,2,2,2,
1,2,2,2,2,2,3,3,4,5,5,6,7,8,9,10,
11,12,14,15,16,18,20,21,23,25,26,28,30,32,34,37,
39,41,43,46,48,50,53,55,58,61,63,66,69,71,74,77,
80,83,86,89,92,95,98,101,104,107,110,113,116,119,122,125,
static INT8U pint_U= 0,pint_V= 85,pint_W= 170;
void Tim1_Inital(void)
//CLK_PCKENR1 |= 0x80; //开启定时器1外设时钟
TIM1_PSCRH = 0x00;
TIM1_PSCRL = 0x04;
//TIM1_EGR |= 0x01; //重新初始化TIM1
TIM1_BKR=0x80;
TIM1_CR1 = 0xe0;
TIM1_IER = 0x02;
TIM1_ARRH = 0x00;
TIM1_ARRL = 0xff;
TIM1_CCMR1 = 0x60;//OC1输出
TIM1_CCR1H = 0;
TIM1_CCR1L = SinParam[++pint_U];
TIM1_CCMR2 = 0x60;//OC1输出
TIM1_CCR2H = 0;
TIM1_CCR2L = SinParam[++pint_V];
TIM1_CCMR3 = 0x60;//OC1输出
TIM1_CCR3H = 0;
TIM1_CCR3L = SinParam[++pint_W];
TIM1_CCER1 = 0x11;
TIM1_CCER2 = 0x01;
#pragma vector=TIM1_CAPCOM_COMIF_vector
__interrupt void TIM1_CAPCOM_COMIF_vector_IRQHandler(void)
TIM1_CCR1H = 0;
TIM1_CCR2H = 0;
TIM1_CCR3H = 0;
TIM1_SR1 = 0;
这个方法电机升温速度比较快
用方波120°相位来控制升温速度比较慢,但是温度还是不断的上升。 |
