回复: 5
关于STM32驱动DS12C887的问题,驱动是改的,读写有问题
发表于 2012-7-15 13:16:21 | 显示全部楼层 |阅读模式
硬件的连接:
PE8~PE15对应的是DS12C887的AD0~AD7,PE7~R/W,PB1~DS,PB10~AS,PB11~CS,PB0~IRO,另外MOT~GND    VCC~5V,reset ~5v
初始化:
ds12c887_init();
  ds12c887_writereg(0x0a,0x2f);//启动887的震荡
  ds12c887_writereg(0x0B,0x16);//0001 0110  选更新中断+二进制格式,每秒产生一次中断
我在WHILE里面看看到底驱动成功没有:TAB_887A[0]=ds12c887_readreg(0x02);,一直是0XFF,
下面是子程序函数:
void ds12c887_setoutput(uint16_t i)
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8 |GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14| GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8 |GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14| GPIO_Pin_15 ;
    if(i)
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IPU;//GPIO_Mode_Out_PP;GPIO_Mode_IN_FLOATING
void ds12c887_delay(uint32_t us);
void ds12c887_init(void)
ds12c887_setoutput(0);
GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_14 ;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
CS_DESELECT();
AS_DISABLE();
WR_DISABLE();
RD_DISABLE();
ds12c887_delay(100000l);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_1  | GPIO_Pin_10 | GPIO_Pin_11;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    //ds12c887Z中断引脚说明,注意由于是漏极输出,所以必须上拉电阻输入
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0;
    CS_DESELECT();
    AS_DISABLE();
    WR_DISABLE();
    RD_DISABLE();
    uint32_t i,j;
    for(j=0;j<us;j++)
    for(i=0;i<72;i++);
void ds12c887_writeadd(uint8_t add)
    u16 RTC_DATA_OUT = 0x0000 ;
    u16 RTC_DATA_OUT1 = 0x0000;
    ds12c887_setoutput(1);
    //DAT_OUTPUT(add);
    RTC_DATA_OUT = GPIO_ReadOutputData(GPIOE);
    RTC_DATA_OUT &=0x00FF;
    RTC_DATA_OUT1 = (u16)(add)<<8;
    RTC_DATA_OUT |= RTC_DATA_OUT1;
    GPIO_Write(GPIOE, RTC_DATA_OUT);
    ds12c887_delay(10);
    AS_ENABLE();
    ds12c887_delay(10);
    AS_DISABLE();
    ds12c887_delay(10);
void ds12c887_writedat(uint8_t dat)
    //DAT_OUTPUT(dat);
    RTC_DATA_OUT1 = (u16)(dat)<<8;
    ds12c887_delay(10);
    WR_ENABLE();
    ds12c887_delay(10);
    WR_DISABLE();
    ds12c887_delay(10);
uint8_t ds12c887_readdat(void)
    uint8_t dat;
    ds12c887_delay(10);
    RD_ENABLE();
    ds12c887_delay(10);
    //dat = DAT_INPUT();
    dat=(u8)((GPIOE->IDR)>>8);
    RD_DISABLE();
    ds12c887_delay(10);
    return dat;
void ds12c887_writereg(uint8_t add,uint8_t dat)
    CS_SELECT();
    ds12c887_delay(10);
    ds12c887_writeadd(add);
    ds12c887_writedat(dat);
    CS_DESELECT();
    ds12c887_delay(10);
uint8_t  ds12c887_readreg(uint8_t add)
    uint8_t dat;
    CS_SELECT();
    ds12c887_delay(10);
    dat = ds12c887_readdat();
    CS_DESELECT();
    ds12c887_delay(10);
    return dat;
前辈们帮帮小弟,看看到底哪个环节出问题了,应该是我这个驱动程序的问题,硬件四块都试过了都不行,哎在线等,帮忙呀,江湖救急,好几天了
 楼主| 发表于 2012-7-15 13:19:25 | 显示全部楼层
呜呜在线等,自己顶顶大哥们你们帮忙一下呀,小弟拜谢了,暑假同学都回家了,自己在实验室搞这个,搞的心烦着急呜呜,搞完了再回家
 楼主| 发表于 2012-7-15 13:20:15 | 显示全部楼层
 楼主| 发表于 2012-7-15 14:14:50 | 显示全部楼层
哎在线等前辈们
 楼主| 发表于 2012-7-15 15:54:31 | 显示全部楼层
光又看的,没人帮帮忙呀
发表于 2022-9-8 09:28:11 | 显示全部楼层
电平不匹配导致的吧,12C887是5V,ST单片机是3.3V。
GMT+8, 2024-6-2 08:15
