发表于 2013-3-7 22:12:13
Release notes for Altium Designer Version 13.1
Complete list of Altium Designer 2013 updates
Version 13.1
Date: 28 February 2013
This update brings improvements to a number of areas affecting stability and performance. The Altium Installer has also been greatly improved to work with anti-virus software.
System Components: Altium Designer Base
307 FPGA Project mapping to vault items dialog has been disabled.
313 The "Extruded 3D body conversion to generic STEP model" option has been enabled.
316 Unnecessary project compilation has been reduced in the following areas. Update from PCB Libraries, PCB Release View, Output Jobs, Harness Problem Finder, Annotate, Default Print
Configuration, Component Links, View Channels, Parameter Manager, Footprint. Veiw BugCrunch report #1183.
319 Saving constraint file paths in FPGA projects is now compatible with AD12.
562 Fixed an issue causing an incorrect or blank output path in both new and existing projects.
731 An option has been added to suppress output of component parameters when exporting to PDF.
746 A crash when using the All Off command to de-selected items in the Sch Item Manager has been resolved through investigation of a crash report.
774 A crash occurring during certain sequences of output generation has been resolved through investigation of a crash report.
775 Through investigation of crash reports a Access Violation occurring in version control that could occur upon opening of documents has been resolved.
776 A crash that could occur generating a report from the configuration dialog of BOM style outputs has been resolved through investigation of a crash report.
782 HTML based reports including DRC and File Format warnings now open in a new tab rather than replacing the home page.
786 A crash during opening of the DXP menu has been resolved through investigation of a crash report.
787 A crash occurring upon wake from system hibernate has been resolved through investigation of a crash report.
797 A crash when closing a modified PCB document with the automatic saving option enabled has been resolved.
798 A crash in copying data from various grids with a subset of columns selected has been resolved through investigation of a crash report.
814 A crash in wire optimization during drag operations in schematic has been fixed through investigation of several crash reports.
822 Fixed a "canvas does not allow drawing" error during print preview through investigation of a crash report.
827 AD12 Configurations are now correctly loaded into AD 2013.
840 Crash reports generated within the PCB editor due to large floating values have been resolved.
877 Improved the generation of PDF reports when zero byte files where produced in some situations.
System Components: Altium Designer Installation System
310 Locate and install missing plugins now working properly.
717 An error that could occur when adding plugins has been resolved through investigation of a crash report.
768 Installing from Local and Network repositories has been improved.
System Components: Data Management
745 A Division by Zero error has been resolved when using copy/ paste operations in the CmpLib editor.
792 The Generate CompLib command was available when the incorrect document type was visible and caused a crash when run. The visibility has been corrected.
794 A Cannot make a visible window modal error when attempting to move a folder in the vault explorer has been resolved.
845 The choose item revision dialog always displays all revisions appropriately.
System Components: Altium Designer Localization
829 Updated Japanese localization of Altium Designer.
System Components: PCB Support
801 Memory corruption that could occur when changing the color of component bodies through the PCB Inspector has been resolved through investigation of a crash report.
802 An AV occurring when Signal Integrity was run on a project containing duplicate designators has been resolved through investigation of a crash report.
823 An AV when saving or exporting CAM files has been resolved through investigation of crash reports.
843 Memory allocation when working with polygons has been improved.
System Components: PCB System
593 The performance and reliability of the Silk to Soldermask rule has been improved
706 A menu entry has been added to the Options Popup to jump directly to the Transparency Tab of the Board Layers and Colors dialog.
759 An AV when dragging parallel tracks when one of the selected tracks is not connected to any others has been resolved through investigation of a crash report.
766 A crash on close has been resolved through investigation of several crash reports.
770 A regression issue setting the selection when dragging multiple tracks has been corrected. The newly added tracks are now selected as before.
789 Invalid STEP files are now handled gracefully when placing 3D bodies.
799 Find Similar Objects now creates the correct expressions for match based on coordinates.
804 An AV that could occur loading certain PCBDoc and PCBLib documents containing Component Bodies has been resolved through investigation of a crash report.
811 An AV occurring when creating a snippet from objects on internal planes has been resolved through investigation of a crash report.
847 Circles now display properly on PCB footprint previews.
System Components: Schematic System
560 Overlapping text in the Synchronize Ports to Sheets Entries has been fixed.
646 The No ERC and Schematic Component dialogs have been updated to accommodate scaled displays.
660 Sheet entries are now positioned correctly when using Smart Paste in Schematic.
674 Placing wires, lines and polygonal blankets in schematic now completes closed loops after right click.
698 Attributes missing from the Schematic Inspector for Rectangle, Text Frame, Compile Mask and Blanket objects are now visible.
703 Find similar objects can now correctly use the font property to match objects.
803 Memory corruption that could occur when changing the color of component bodies through the PCB Inspector has been resolved through investigation of a crash report.
813 A crash when attempting to exit with the Schematic inplace editor is active has been resolved through investigation of a crash report.
System Components Soft Design System
316 Rescanning JTAG chain is now much faster.
320 Toolchain and device names are saved in the embedded project document to improve backward compatibility with AD12.
Data Management Packages Version Control - SVN
771 The Use External SVN preference is now sticking correctly.
Output Generators: Printer - PCB
Output Generators: Output - NC-Drill
Output Generators: Output - Gerber
Output Generators: Output - ODB
Output Generators: Output - STEP
676 A hang up when exporting some PCB documents to STEP has been resolved.
Embedded Design Tools: Software platform
308 SDHC driver in Software Platform now has a correct include and help files.
328 CANopen configurator is now enabled.
Embedded Design Tools: Software Platform R10
Embedded Design Tools: TASKING TSK3000
311 Embedded compilers issue warning W557 correctly.
Embedded Design Tools: TASKING MicroBlaze
Embedded Design Tools: TASKING NiosII
Embedded Design Tools: TASKING PowerPC
Development updating various modules
765 Failure of several importers to run due to an interface not supported error has been resolved.
767 The Create Installation Repository command now uses the correct (AD 2013) version of the installer.
