发表于 2013-8-16 09:20:52
Tifosi_ 发表于 2013-8-15 22:05
具体是怎么个情况 有提示错误?
我也用的是TQ2416的板子,在下载的时候提示如下面的两个图,帮忙分析下。
1、下载过程输出:
Load "Z:\\Project\\ZQ\\Software\\TQ2416\\LED\\OBJ\\LED.axf"
ProjectFile = Z:\Project\ZQ\Software\TQ2416\LED\JLinkArm_Target 1.ini
Info: Device "UNSPECIFIED" selected (0 KB flash, 0 KB RAM).
Device = S3C2416
VTarget = 3.293V
Info: TotalIRLen = 4, IRPrint = 0x01
Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
Info: CP15.0.1: 0x1D152152: ICache: 16kB (4*128*32), DCache: 16kB (4*128*32)
Info: Cache type: Separate, Write-back, Format C (WT supported)
Info: RTCK is not connected
Info: Auto JTAG speed: 8000 kHz
Info: J-Link: ARM9 CP15 Settings changed: 51078 from 78, MMU Off, ICache On, DCache Off
Info: RESET has cleared breakpoint, using default reset strategy.
Info: Resetting target using RESET pin
Info: Resetting TRST
DLL version V4.62, compiled Jan 25 2013 15:19:47
Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52
Hardware: V8.00
Hardware-Breakpoints: 2
Software-Breakpoints: 8192
Watchpoints: 0
Found 1 JTAG device, Total IRLen = 4:
Id of device #0: 0x07926F0F
ARM9 identified.
JTAG speed: 1000 kHz
Insufficient RAM for Flash Algorithms !
Full Chip Erase Failed!
Device = S3C2416
VTarget = 3.293V
Hardware: V8.00
Watchpoints: 0
ARM9 identified.
2、截图在附件的图片里面;
3、麻烦看下,谢谢, |
