最近有个客户产品上采用了STM8L系列的芯片,看了原理图刚好是采用的CT模式触摸,这两天从ST网站上下了CT模式的触摸库.理解了一部分,试着在客户的板子上跑跑触摸按键,没想到还成功了,在论坛上找了找,很少看到CT模式下的配置说明,现在和大家分享一下,说的不对的地方,望理解.
1:其实ST给出的触摸库中已经给出了说明.现在把触摸库的按键配置和大家分享一下.然后再一步步和大家解释.以下是CT模式下的配置.中文注释的地方是我用到的按键触摸部分说明.滚轮和划条由于产品上没有,也没法测试.过段时间有空打个板玩玩.
* @file Example06_STM8L15x_LD_CT_10k_SWacq\inc\stm8_tsl_conf.h
* @author MCD Application Team
* @version V2.4.0
* @date 01-July-2011
* @brief STM8 Touch Sensing Library - This file is a template for the
* Charge-Transfer acquisition and must be adapted to your requirements.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __TSL_CONF_H
#define __TSL_CONF_H
// 1) MCU SELECTION
// 1 = STM8L10x
// 2 = STM8L15x with 4Kb or 8Kb Flash (low density) - Software acquisition mode
// 3 = " " " " " - Hardware acquisition mode
// 4 = STM8L15x with 16Kb, 32kb or 64Kb Flash (medium and high density)
// STM8L16x
#define MCU_SELECTION (2) //第一步要选择MCU型号,我用的型片中4K的.所以选2
// 2) GENERIC TIMEBASE TIMER SELECTION (TIMTICK)
// Set the generic timebase timer.
// The timer you select must be a basic 8-bit timer.
// This table summarizes the values for some products (consult the datasheet
// if your product is not in the list):
// Product TIMTICK
// STM8L15x TIM4
// STM8L10x TIM4
// Warning: The selected timer update/overflow interrupt vector must point to
// the TSL_Timer_ISR() interrupt routine.
#define TIMTICK (TIM4) //第二步.定时器选择.我用的是TM8L15x ,如上所说选TIM4
// *** GROUP AND CHANNEL DESCRIPTION ***
// CHARGE_TRANSFER group and channel description for STM8L10x devices
// For more details please refer to the Comparator
// section in the reference manual
// Group 1 CH1 PB0 __/____
// CH2 PB1 __/__|
// CH3 PD0 __/__|
// CH4 PD1 __/__|
// Group 2 CH1 PB2 __/____
// CH2 PB3 __/__|
// CH3 PD2 __/__|
// CH4 PD3 __/__|
// CHARGE_TRANSFER group and channel description for STM8L15x devices
// For more details please refer to the Routing Interface
// Group 1 CH1 PA6 __/____
// CH2 PA5 __/__|
// CH3 PA4 __/__|
// CH4 PA7 __/__| FOR STM8L15x with 4Kb or 8Kb Flash only
// Group 2 CH1 PC7 __/____
// CH2 PC4 __/__|
// CH3 PC3 __/__|
// CH4 PE7 __/__| FOR STM8L15x with 4Kb or 8Kb Flash only
// Group 3 CH1 PC2 __/____
// CH2 PD7 __/__|
// CH3 PD6 __/__|
// Group 4 CH1 PD5 __/____
// CH2 PD4 __/__|
// CH3 PB7 __/__|
// Group 5 CH1 PB6 __/____
// CH2 PB5 __/__|
// CH3 PB4 __/__|
// Group 6 CH1 PB3 __/____
// CH2 PB2 __/__|
// CH3 PB1 __/__|
// Group 7 CH1 PB0 __/____
// CH2 PD3 __/__|
// CH3 PD2 __/__|
// CH4 PE3 __/__| FOR STM8L15x with 4Kb or 8Kb Flash only
// Group 8 CH1 PD1 __/____
// CH2 PD0 __/__|
// CH3 PE5 __/__|
// CH4 PE4 __/__| FOR STM8L15x with 4Kb or 8Kb Flash only
// The below values are only used for the groups and channels settings.
// DO NOT change the values.
#define GROUP1 (0x01)
#define GROUP2 (0x02)
#define GROUP3 (0x04)
#define GROUP4 (0x08)
#define GROUP5 (0x10)
#define GROUP6 (0x20)
#define GROUP7 (0x40)
#define GROUP8 (0x80)
#define CH1 (1)
#define CH2 (2)
#define CH3 (3)
#define CH4 (4) //以上参数不能修改.ST定义好的.
// 3) SAMPLING CAPACITOR CHANNEL SELECTION
// Set the sampling capacitors channel.
// The hardware for CHARGE_TRANSFER is done in such way that all the sampling
// capacitors have to be connected to the same channel of each group.
// For example, the sampling capacitors are connected to CH2 of each group.
#define SAMP_CAP_CH (CH3) /**< Possible values are CH1, CH2, CH3 and CH4 */
//电容通道配置,在GROUP1-8中,每一个GROUP中(4个IO或3个IO)要有一个引脚接一个电容,而接电容的引脚,在GROUP1-GROUP8中必须是同一通道,如以下两组
// CH2 PA5 __/__|
// CH3 PA4 __/__|
// CH2 PC4 __/__|
// CH3 PC3 __/__|
如果SAMP_CAP_CH =(CH3),则第一组的PA4,和第二组的PC3,是接电容通道,电容连接原理图示例如下,第一组GROUP需要接一个电容.
// 4) SINGLE CHANNEL KEYS DEFINITION FOR CHARGE_TRANSFER - 1st Bank
// Set the number of keys
// Set the Channel (cannot be the channel defined for the sampling capacitor)
// Set the Group for each key
#define SCKEY_P1_KEY_COUNT (5) //第一通道按键数量,每组可以设置8个按键,有3组,一个最多可以支持24个(ST).有SCKEY_P1,SCKEY_P2,SCKEY_P3.
我的理解为有8个GROUP,假设第个GROUP有3个IO.那就是3*8=24个IO.但每组需要有一个电容引脚所以占用8个,那就是24-8=16个.也不知道理解对不对?
#define SCKEY_P1_CH (CH1) /**< Possible values are CH1, CH2, CH3 and CH4 */ //选择按键通道号,如果选CH1就是指PA6,PC7,PC2, PD5, PB6 ,PB3,PB0,PD1,这几个引脚所接的触摸按键(见上面GROUP1-8定义
/**< Even if SCKEY_P1_KEY_COUNT is null */
/**< SCKEY_P1_CH must contain the channel number */
/**< used by a multi-key*/
#define SCKEY_P1_A (GROUP1) //为这一通道配置按键,由于我们选择的是CH1,而GROUP1中CH1对应的是PA6,那就是说明PA6上我们接了一个触摸按键
#define SCKEY_P1_B (GROUP5) // PB6上我们接了一个触摸按键
#define SCKEY_P1_C (GROUP6) // PB3上我们接了一个触摸按键
#define SCKEY_P1_D (GROUP7) // PB0上我们接了一个触摸按键
#define SCKEY_P1_E (GROUP8) // PD1上我们接了一个触摸按键
#define SCKEY_P1_F (0)
#define SCKEY_P1_G (0)
#define SCKEY_P1_H (0)
//上面参数不能空着写.如
#define SCKEY_P1_B (0) //这里不能为空,必须连续.
#define SCKEY_P1_C (GROUP5)
#define SCKEY_P1_D (GROUP6)
#define SCKEY_P1_E (GROUP7)
// 5) SINGLE CHANNEL KEYS DEFINITION FOR CHARGE_TRANSFER - 2nd Bank
#define SCKEY_P2_KEY_COUNT (4) //这里配置和上面说明一样,只不过有3个通道,这是第二个.这一通道我们配置了4个按键.
#define SCKEY_P2_CH (CH2) /**< Possible values are CH1, CH2, CH3 and CH4 */
/**< Even if SCKEY_P2_KEY_COUNT is null */
/**< SCKEY_P2_CH must contain the channel number */
/**< used by a multi-key if different from SCKEY_P1_CH */
#define SCKEY_P2_A (GROUP1)
#define SCKEY_P2_B (GROUP5)
#define SCKEY_P2_C (GROUP6)
#define SCKEY_P2_D (GROUP8)
#define SCKEY_P2_E (0)
#define SCKEY_P2_F (0)
#define SCKEY_P2_G (0)
#define SCKEY_P2_H (0)
// WARNING: FOR STM8L10x or STM8L15x devices with 4kb or 8kb Flash only
// 6) SINGLE CHANNEL KEYS DEFINITION FOR CHARGE_TRANSFER - 3rd Bank
#if (MCU_SELECTION != 4)
#define SCKEY_P3_KEY_COUNT (0) //这里配置和上面说明一样,只不过有3个通道,这是第二个.如果不用说写0
#define SCKEY_P3_CH (0) /**< Possible values are CH1, CH2, CH3 and CH4 */
/**< Even if SCKEY_P3_KEY_COUNT is null */
/**< SCKEY_P3_CH must contain the channel number */
/**< and SCKEY_P2_CH */
#define SCKEY_P3_A (0)
#define SCKEY_P3_B (0)
// For STM8L15x devices with 4kb or 8kb Flash only
#if ((MCU_SELECTION == 2) || (MCU_SELECTION == 3))
#define SCKEY_P3_C (0)
#define SCKEY_P3_D (0)
#define SCKEY_P3_E (0)
#define SCKEY_P3_F (0)
#define SCKEY_P3_G (0)
#define SCKEY_P3_H (0)
// 7) NUMBER OF MULTI CHANNEL KEYS AND NUMBER OF CHANNELS USED
// Set the total number of multi channel keys used (0, 1 or 2)
#define NUMBER_OF_MULTI_CHANNEL_KEYS (0) /**< Number of multi channel keys (value from 0 to 2) */ //滚轮和划条配置.最多两.
// 8) MULTI CHANNEL KEYS DEFINITION FOR CHARGE_TRANSFER - 1st MCkey
// and the Group for each IO composing the MCkey
#if NUMBER_OF_MULTI_CHANNEL_KEYS > 0
#define MCKEY1_A_CH (0) /**< Multi channel key 1: 1st IO Channel */
#define MCKEY1_A (0) /**< Multi channel key 1: 1st IO Group */
#define MCKEY1_B_CH (0) /**< Multi channel key 1: 2nd IO Channel */
#define MCKEY1_B (0) /**< Multi channel key 1: 2nd IO Group */
#define MCKEY1_C_CH (0) /**< Multi channel key 1: 3rd IO Channel */
#define MCKEY1_C (0) /**< Multi channel key 1: 3rd IO Group */
#define MCKEY1_TYPE (0) /**< Multi channel key 1 type: 0=wheel (zero between two electrodes), 1=slider (zero in the middle of one electrode) */
// 9) MULTI CHANNEL KEYS DEFINITION FOR CHARGE_TRANSFER - 2nd MCkey (optional)
#if NUMBER_OF_MULTI_CHANNEL_KEYS > 1
#define MCKEY2_A_CH (0) /**< Multi channel key 2: 1st IO Channel */
#define MCKEY2_A (0) /**< Multi channel key 2: 1st IO Group */
#define MCKEY2_B_CH (0) /**< Multi channel key 2: 2nd IO Channel */
#define MCKEY2_B (0) /**< Multi channel key 2: 2nd IO Group */
#define MCKEY2_C_CH (0) /**< Multi channel key 2: 3rd IO Channel */
#define MCKEY2_C (0) /**< Multi channel key 2: 3rd IO Group */
#define MCKEY2_TYPE (0) /**< Multi channel key 2 type: 0=wheel (zero between two electrodes), 1=slider (zero in the middle of one electrode) */
// 10) TSL PARAMETERS CONFIGURATION
/** @addtogroup TSL_parameters_CT
// Thresholds
#define SCKEY_DETECTTHRESHOLD_DEFAULT (20) /**< Single channel key detection threshold (value from 1 to 127) */ //
#define SCKEY_ENDDETECTTHRESHOLD_DEFAULT (10) /**< Single channel key end detection threshold (value from 1 to 127) */
#define SCKEY_RECALIBRATIONTHRESHOLD_DEFAULT (-10) /**< Single channel key calibration threshold (value from -1 to -128) */
#define MCKEY_DETECTTHRESHOLD_DEFAULT (45) /**< Multi channel key detection threshold (value from 1 to 127) */
#define MCKEY_ENDDETECTTHRESHOLD_DEFAULT (40) /**< Multi channel key end detection threshold (value from 1 to 127) */
#define MCKEY_RECALIBRATIONTHRESHOLD_DEFAULT (-45) /**< Multi channel key calibration threshold (value from -1 to -128) */
// MCKey resolution
#define MCKEY_RESOLUTION_DEFAULT (7) /**< Multi channel key resolution (value from 1 to 8) */
// MCKey Direction Change process
#define MCKEY_DIRECTION_CHANGE_ENABLED (1) /**< Multi channel key direction change enable (1) or disable (0) switch */
#define MCKEY_DIRECTION_CHANGE_MAX_DISPLACEMENT (255) /**< Multi channel key direction change maximum displacement (value from 0 to 255) */
#define MCKEY_DIRECTION_CHANGE_INTEGRATOR_DEFAULT (1) /**< Multi channel key direction change integrator (value from 1 to 255) */
#define MCKEY_DIRECTION_CHANGE_THRESHOLD_DEFAULT (10) /**< Multi channel key direction change threshold (value from 1 to 255) */
// Integrators
#define DETECTION_INTEGRATOR_DEFAULT (2) /**< Detection Integrator = Debounce Filter (value from 0 to 255) */
#define END_DETECTION_INTEGRATOR_DEFAULT (2) /**< End detection Integrator = Debounce Filter (from 0 to 255) */
#define RECALIBRATION_INTEGRATOR_DEFAULT (10) /**< Calibration integrator (value from 1 to 255) */
// IIR Filter
#define ECS_TIME_STEP_DEFAULT (20) /**< Sampling frequency, multiple of 10ms */
#define ECS_TEMPO_DEFAULT (20) /**< Delay after detection, multiple of 100ms */
#define ECS_IIR_KFAST_DEFAULT (20) /**< K factor for fast filtering */
#define ECS_IIR_KSLOW_DEFAULT (10) /**< K factor for slow filtering */
// Detection Timeout
#define DTO_DEFAULT (0) /**< 1s unit (value from 0 (= infinite!) to 255) */
// Acquisition values limits
#define SCKEY_MIN_ACQUISITION (50) /**< Single channel key minimum acquisition value */
#define SCKEY_MAX_ACQUISITION (3000) /**< Single channel key maximum acquisition value */
#define MCKEY_MIN_ACQUISITION (150) /**< Multi channel key minimum acquisition value */
#define MCKEY_MAX_ACQUISITION (5000) /**< Multi channel key maximum acquisition value */
// Optional parameters for Delta Normalization Process (for Multi channel keys only).
// The MSB is the integer part, the LSB is the real part:
// For example to apply a factor 1.10:
// 0x01 to the MSB
// 0x1A to the LSB (0.1 x 256 = 25.6 -> 26 = 0x1A)
// Final value to define is: 0x011A
#define MCKEY1_DELTA_COEFF_A (0x0100) /**< MCKey1 Channel A parameter */
#define MCKEY1_DELTA_COEFF_B (0x0100) /**< MCKey1 Channel B parameter */
#define MCKEY1_DELTA_COEFF_C (0x0100) /**< MCKey1 Channel C parameter */
#define MCKEY2_DELTA_COEFF_A (0x0100) /**< MCKey2 Channel A parameter */
#define MCKEY2_DELTA_COEFF_B (0x0100) /**< MCKey2 Channel B parameter */
#define MCKEY2_DELTA_COEFF_C (0x0100) /**< MCKey2 Channel C parameter */
// Interrupt synchronisation
//#define IT_SYNC (1) /**< Interrupt synchronisation. (=1) Allow to synchronize the aquisition with a flag set in an interrupt routine */
//IO Protection from Interrupt modification
#define PROTECT_IO_ACCESS (1) /**< Protect the IO access : to be enabled to allow the access to the IO registers used by the STM Touch library by any interrupt routine */
// Capacitance Loading Waiting HIGH Time Adjustment
#define CLWHTA {nop();nop();nop();} /**< Add here the necessary number of NOP or a call to wait(n);*/
// Capacitance Loading Waiting LOW Time Adjustment
#define CLWLTA {} /**< Add here the necessary number of NOP or a call to wait(n);*/
// Spread spectrum
#define SPREAD_SPECTRUM (1) /**< Spread spectrum enabled (=1) */
#define SW_SPREAD_SPECTRUM (0) /**< Software Spread spectrum enabled (=1) for STM8L15x only when the UART is also used, to comment if not used */
#define SPREAD_COUNTER_MIN (1) /**< Spread min value (for STM8L10x devices or when STM8L15x and the Software Spread Spectrum is used) CAUTION : 0 is not a valid value*/
#define SPREAD_COUNTER_MAX (20) /**< Spread max value (for STM8L10x devices or when the Software Spread Spectrum is used) or maximum amplitude of the HSI trimming for STM8L15x and Software Spread Spectrum disabled */
// Active Shield
#define ACTIVE_SHIELD_GROUP (0) /**< Active Shield is disabled (=0), else this symbolic constant contains the group dedicated to this function, this group will be driven but never acquired */
// RTOS Management of the acquisition (instead of the timebase interrupt sub-routine
#define RTOS_MANAGEMENT (0) /**< The Timebase routine is launched by the application instead to be managed through a timebase interrupt routine */
// Timer Callback to allow the user to add its own function called from the timer interrupt sub-routine
#define TIMER_CALLBACK (0) /**< if (1) Allows the use of a callback function in the timer interrupt. This function will be called every 0.5ms. The callback function must be defined inside the application and have the following prototype FAR void USER_TickTimerCallback(void); */
//Inline functions
#define USE_INLINED_FUNCTIONS (0) /**< Inline functions are enabled (=1) */
// For STM8L15x with 4Kb or 8Kb Flash (low density) devices only
#define HW_ACQ_CT_PERIOD (2) /**< Charge-Transfer H/W acquisition period in 祍 unit (value from 1 to 10) */
// DEFINITIONS CHECK. DO NOT TOUCH ANYTHING BELOW !!!
#define CHARGE_TRANSFER (1)
// Automatic Calibration always enabled
#define NEGDETECT_AUTOCAL (1)
// Only 3 channels per MCKey are supported
#define CHANNEL_PER_MCKEY (3)
#define MCKEY1_D_CH (0)
#define MCKEY1_D (0)
#define MCKEY1_E_CH (0)
#define MCKEY1_E (0)
#define MCKEY1_F_CH (0)
#define MCKEY1_F (0)
#define MCKEY1_G_CH (0)
#define MCKEY1_G (0)
#define MCKEY1_H_CH (0)
#define MCKEY1_H (0)
#define MCKEY2_D_CH (0)
#define MCKEY2_D (0)
#define MCKEY2_E_CH (0)
#define MCKEY2_E (0)
#define MCKEY2_F_CH (0)
#define MCKEY2_F (0)
#define MCKEY2_G_CH (0)
#define MCKEY2_G (0)
#define MCKEY2_H_CH (0)
#define MCKEY2_H (0)
// Only the interlaced layout is supported
#define MCKEY1_LAYOUT_TYPE (0)
#define MCKEY2_LAYOUT_TYPE (0)
#include "stm8_tsl_checkconfig.h"
#endif /* __TSL_CONF_H */
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2: 以下是工程文件,可以参考.
