我的板子的F28035使用了外部的晶振,但是怎么调试都无法运行。使用内部的晶振1、2都可以运行。
我的硬件电路如下;实际焊接的是20M,12pf,但是使用示波器无法测试到晶振两端的波形。
dsp软件的晶振配置的程序如下。DSP28_PLLCR=6,DSP28_DIVSEL=2;
不知道和电容的ESR有没有关系?还是软件配置的不对?
请大家多多指教。
谢谢
void InitSysCtrl(void)
// Disable the watchdog
DisableDog();
// *IMPORTANT*
// The Device_cal function, which copies the ADC & oscillator calibration values
// from TI reserved OTP into the appropriate trim registers, occurs automatically
// in the Boot ROM. If the boot ROM code is bypassed during the debug process, the
// following function MUST be called for the ADC and oscillators to function according
// to specification. The clocks to the ADC MUST be enabled before calling this
// function.
// See the device data manual and/or the ADC Reference
// Manual for more information.
EALLOW;
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // Enable ADC peripheral clock
(*Device_cal)();
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 0; // Return ADC clock to original state
EDIS;
// Select Internal Oscillator 1 as Clock Source (default), and turn off all unused clocks to
// conserve power.
//IntOsc1Sel(); //使用内部晶振
//IntOsc2Sel();
XtalOscSel(); //使用外部无源晶振
// Initialize the PLL control: PLLCR and CLKINDIV
// DSP28_PLLCR and DSP28_CLKINDIV are defined in DSP2803x_Examples.h
InitPll(DSP28_PLLCR,DSP28_DIVSEL);
// Initialize the peripheral clocks
InitPeripheralClocks();
