代码如下:
//所选芯片:PIC16f886
#include <pic.h> //包含单片机内部资源预定义
#define TRUE 1
#define FALSE 0
void vInit(void);
void vUART0_Init(void);
void delay(void);
//__CONFIG (HS & WDTEN & PWRTEN & BOREN & LVPDIS
unsigned int unCount = 0, unRvCount = 0, unSendCount = 0;
unsigned char ucFlag = 0, ucRvFlag = 0;
unsigned char ucRvData[10] = {0}, ucSendData[10] = {0};
ANSEL = 0X00; //禁止模拟输入AN0~AN13
ANSELH = 0X00;
TRISA = 0X00; //PORTA0定义为输出
PORTA = 0X00;
vInit();
vUART0_Init();
while(1 == 1)
// TXREG = 0x21;
// while(!TXIF); //TXIE置1时,TXIF被置1;待发送的最后一个字符写入TXREG时,TXIF被清零
delay();
asm("clrwdt"); //清除看门狗
if (unRvCount == 10)
CREN = 0;
for (unRvCount = 10; unRvCount>=0; unRvCount--)
ucRvData[10-unRvCount] = TXREG;
while(!TXIF);
unRvCount = 0;
CREN = 1;
void delay(void)
unsigned int x = 2000;
while(--x){ NOP();}
void vInit(void) //芯片基本配置初始化函数
OSCCON = 0X75; //内部振荡器选为8Mhz
INTCON = 0x00; //关闭所有中断
PIE1 = 0x00; //外设中断禁止寄存器1
//外部中断配置RB0引脚
TRISB0 = 1; //RB0定义为输入
//TRISB1 = 0; //RB1定义为输出
RBPU = 0;
WPUB |= 0X01;
INTEDG = 1; //外部中断引脚下降沿触发
INTF = 0; //外部中断标志位清零
INTE = 1; //外部中断允许
//定时器0配置
T0CS = 0; //TMR0选为定时器模式,时钟Fosc/4
PSA = 0; //预分频器分配给Timer0
PS0 = 0; //PS<2:0>为011 TMR0 1:16 WDT 1:8
PS1 = 0;
PS2 = 0;
TMR0 = 0x37; //写入TMR0时有两个指令周期的延时
T0IF = 0; //TMR0溢出中断标志位清零
T0IE = 1; //允许TMR0溢出中断
PEIE = 1; //使能所有未屏蔽的外设中断
GIE = 1; //开放总中断
//通信初始化
SPBRG = 51; //8M晶振 设置波特率2400 波特率:Fosc/[64(n+1)]
BRGH = 0;
BRG16 = 0; //BRG 8位定时器 异步
SPEN = 1;
SYNC = 0;
TXSTA = 0x20; // 0110 0001 //八九位数据、发送使能、异步通信
RCIE = 1; //允许接收中断
GIE = 1;
CREN = 1;
void interrupt ISR(void) //中断服务程序
if (T0IF)
TMR0 = 0X37;
T0IF = 0;
unCount++;
if (unCount <= 10)
RA0 = 1;
RA0 = 0;
if (unCount == 20)
unCount = 0;
if (INTF)
INTF = 0;
RA2 = ~RA2;
if(RCIF)
RA3 = ~RA3;
if (OERR) //溢出错误恢复
CREN = 0;
CREN = 1;
ucRvData[unRvCount++] = RCREG; //RCREG被读走时RCIF自动清零
大神支招 |
