回复: 82
Keil和IAR约好了同步更新软件,有新版本出来了
发表于 2014-9-25 09:16:25 | 显示全部楼层 |阅读模式
发表于 2014-9-25 09:17:39 | 显示全部楼层
是吗?新版本有什么优势?
发表于 2014-9-25 09:17:40 | 显示全部楼层
等破解吧
发表于 2014-9-25 09:18:23 | 显示全部楼层
没破解就算了,那属于高消费
 楼主| 发表于 2014-9-25 09:20:30 | 显示全部楼层
rowen800 发表于 2014-9-25 09:17
是吗?新版本有什么优势?
http://www.keil.com/update/whatsnew.asp?p=MDK&v=5.12
呵呵,正在下载中,还没安装
发表于 2014-9-25 09:26:41 | 显示全部楼层
Cortex-M7 ... 不知道是什么概念
 楼主| 发表于 2014-9-25 09:29:20 | 显示全部楼层
就是增加了几条流水线,提高“生产效率”吧
出0入93汤圆
发表于 2014-9-25 09:30:08 | 显示全部楼层
我昨天就预测出来啦,M7一出肯定要更新啦
出0入93汤圆
发表于 2014-9-25 09:30:53 | 显示全部楼层
What's New in MDKARM Version 5.12
MDK-ARM Version 5.12
Release Date: 24th September, 2014
This MDK version introduces support for ARM Cortex-M7 processor based devices.
Note: The STM32 Device Family Packs Version 1.x.x are incompatible with CMSIS Version 4.2.0 and MDK-Middleware Version 6.1.1. The compatible STM32 Device Family Packs Version 2.x.x will be released shortly. The application note 266 Using Keil MDK v5.11 with STM32 devices describes how to use the older STM32 Device Family Packs.
    [uVision]
        Enhanced performance in the Project View and new file, group, and component attributes.
    [Software Packs included]
        CMSIS Version 4.2.0: Cortex-M7 related updates to CMSIS-CORE, CMSIS-DSP, CMSIS-PACK and CMSIS-SVD.
        MDK-Middleware Version 6.1.1: Driver Network/Driver/ETH_KSZ8851SNL.c corrected an invalid power status in function MAC_PowerControl.
    [ARM Compiler]
    This MDK release contains two ARM Compiler versions that can be selected in the dialog Project - Options for Target - Target (under Code Generation):
        ARM Compiler 5.05 (build 41) (in directory ..\ARM\ARMCC\) with support for Cortex-M7 and other enhancements (see release notes).
        ARM Compiler 5.04u2 (build 82) (in directory ..\ARM\ARMCC_504u2\) for safety critical applications in combination with the ARM Compiler Qualification Kit (only available with a license for MDK-Professional).
    [FlexNet Floating Licenses]
        Customers using FlexNet floating licenses are required to update their license server software to Version 11.12.1 or higher.
        Using older versions of the FlexNet license server will result in error messages by the ARM Compiler tools.
        FlexNet Licensing error:-96,7. System Error: 11001 "Comm. error"
        FlexNet Version 11.12.1 License Server tools for Windows are located in the directory ..\Keil\UV4\FlexNet. For other operating systems please contact support.
    [Target debugging]
        Updated: Segger J-Link driver for ARM devices to version 4.91b.
        Updated: NuLink software to version 6.3.14
        Updated: STMicroelectronics ST-Link driver for STMicroelectronics devices to version 2.0.10.0.
        Updated: ULINKPro\ULINK2\CMSIS-DAP driver to support Cortex-M7 based devices.
    [Supported Operating Systems]
        Refer to System Requirements Overview for hardware and operating system requirements.
 楼主| 发表于 2014-9-25 09:31:19 | 显示全部楼层
先生果然有先见之明!仰慕中。。。
发表于 2014-9-25 09:33:15 | 显示全部楼层
等破解
发表于 2014-9-25 09:34:18 | 显示全部楼层
除了芯片都有了。CMSIS-DAP继续更了。
发表于 2014-9-25 09:39:00 | 显示全部楼层
这都要约好?
 楼主| 发表于 2014-9-25 09:47:04 | 显示全部楼层
嗯。。。是的,本座同时收到他们的请柬
发表于 2014-9-25 09:48:02 来自手机 | 显示全部楼层
让新版本飞一会儿
出100入101汤圆
发表于 2014-9-25 10:05:15 | 显示全部楼层
有新系列芯片出来,KEIL、IAR自然要同步更新!
发表于 2014-9-25 10:13:09 | 显示全部楼层
软件使用,没必要追求最新
发表于 2014-9-25 10:13:47 | 显示全部楼层
我用的都是老芯片,够用就好,对新版本无爱
出0入93汤圆
发表于 2014-9-25 10:14:26 | 显示全部楼层
MDK已经有人发了,谁发一个IAR的下载
发表于 2014-9-25 10:49:38 | 显示全部楼层
新版本就是自愿当小白鼠,一般不去赶这个时髦
发表于 2014-9-25 11:03:22 | 显示全部楼层
laoshuhunya 发表于 2014-9-25 09:47
嗯。。。是的,本座同时收到他们的请柬
请你去下载?
 楼主| 发表于 2014-9-25 11:12:16 | 显示全部楼层
是啊
发表于 2014-9-25 11:14:12 | 显示全部楼层
你们买过正版么?还有这待遇?
 楼主| 发表于 2014-9-25 11:14:44 | 显示全部楼层
IAR随便都可下载的,只要本机有授权文件即可(坛子里有)。
http://supp.iar.com/Common/Prote ... 1&protocol=HTTP
 楼主| 发表于 2014-9-25 11:15:52 | 显示全部楼层
ccrt 发表于 2014-9-25 11:14
你们买过正版么?还有这待遇?
用的是正版MDK
出0入93汤圆
发表于 2014-9-25 11:33:48 | 显示全部楼层
http://supp.iar.com/Common/ProtectedDownlo ...
谢谢,先下来瞅瞅
发表于 2014-9-25 11:37:22 | 显示全部楼层
破解可能还是以前那个注册机
发表于 2014-9-25 11:37:31 | 显示全部楼层
不想用最新的。麻烦。。
发表于 2014-9-25 11:41:53 | 显示全部楼层
都很速度呀,M7的内核一出,各种配套的东西都出来了。
出110入0汤圆
发表于 2014-9-25 11:50:16 | 显示全部楼层
为了更新M7之类的内核吧
发表于 2014-9-25 11:51:29 | 显示全部楼层
大家正等着破解版出现。。。。。。
发表于 2014-9-25 12:04:01 | 显示全部楼层
求链接。。。。。。
看起来只是对M7的更新支持和一些个开发工具的更新,少许性能优化,对stm32有新的family pack版本要求
发表于 2014-9-25 12:04:05 | 显示全部楼层
新版本有破解吗,没有的话也用不起啊
出0入93汤圆
发表于 2014-9-25 12:05:43 | 显示全部楼层
Earthman 发表于 2014-9-25 12:04
求链接。。。。。。
这个帖子里 http://www.amobbs.com/thread-5597665-1-1.html
发表于 2014-9-25 12:33:38 | 显示全部楼层
一直在用老版本。。。
发表于 2014-9-25 12:40:28 | 显示全部楼层
一对好基友。。
发表于 2014-9-25 12:44:16 | 显示全部楼层
不追新,先观望。之前吃的亏太多了,追新没好处
发表于 2014-9-25 13:12:50 | 显示全部楼层
看看
发表于 2014-9-25 15:32:30 | 显示全部楼层
最新其实没有多大的意义,用好自己的片子就可以了!!!!
发表于 2014-9-26 09:47:42 | 显示全部楼层
哪里哪里呀????
发表于 2014-9-26 09:58:17 | 显示全部楼层
坐等破解更新了
发表于 2014-9-26 10:03:29 | 显示全部楼层
这个 哈哈 纯属巧合
发表于 2014-9-26 13:04:32 | 显示全部楼层
新出了硬件 软件就要更新吧
发表于 2014-9-26 13:08:43 | 显示全部楼层
ARM出新产品之前都会和编译软件公司做好沟通,要不然出来了片子没法用那不是搞笑了
发表于 2014-9-26 13:45:37 | 显示全部楼层
哈,KEIL和IAR这俩手脚还真是够快的。
发表于 2014-10-5 20:30:30 | 显示全部楼层
没破解就只能试用版本将就用了
发表于 2014-10-5 20:49:46 | 显示全部楼层
让新版本飞一会儿
发表于 2014-10-5 21:04:57 | 显示全部楼层
问下楼主,正版的MDK多少钱?是企业版的吗?可以允许几台机器用?
发表于 2014-10-5 21:24:49 | 显示全部楼层
没兴趣,和钱无关的都兴趣不大
 楼主| 发表于 2014-10-5 21:45:02 | 显示全部楼层
5年前买的个人版,价格好像2K多。
现在的价格不清楚,可以到这里问问看:
http://www.embedinfo.com/list.asp?id=271
补充:买个单机版,可以多机用,但要在防火墙里禁止MDK访问网络。
发表于 2014-10-5 22:41:33 | 显示全部楼层
还在用4~
发表于 2014-10-5 22:52:58 | 显示全部楼层
要是能免费就好了
发表于 2014-10-5 23:26:07 | 显示全部楼层
laoshuhunya 发表于 2014-10-5 21:45
5年前买的个人版,价格好像2K多。
现在的价格不清楚,可以到这里问问看:
http://www.embedinfo.com/list ...
你这是公司买的吗?还是个人购买的?
 楼主| 发表于 2014-10-6 00:38:31 | 显示全部楼层
xjmlfm1 发表于 2014-10-5 23:26
你这是公司买的吗?还是个人购买的?
个人。
发表于 2014-10-6 08:26:39 | 显示全部楼层
还真有个人购买keil的呀,头一回听说,赞一个。
发表于 2014-10-6 08:36:48 | 显示全部楼层
M7
发表于 2014-10-6 08:44:58 | 显示全部楼层
还在用老版本
发表于 2014-10-6 08:46:45 | 显示全部楼层
版本够用就行。
发表于 2014-10-6 14:52:36 | 显示全部楼层
暂时够用,不更新
发表于 2014-10-6 15:23:48 来自手机 | 显示全部楼层
我发现keil安装库都要联网了,如果没有网络的话怎么安装stm的元件支持啊
发表于 2014-10-8 11:45:40 | 显示全部楼层
发表于 2014-10-8 13:24:47 | 显示全部楼层
关注  !!!!!
发表于 2014-10-8 14:23:58 | 显示全部楼层
关注一下,M7看起来不错的样子
发表于 2014-10-8 15:41:10 | 显示全部楼层
够用就行,盲目升级可能会存在问题
发表于 2014-10-8 16:18:47 | 显示全部楼层
对的,我一般也不去尝那个鲜。。。
发表于 2014-10-8 16:29:22 | 显示全部楼层
那估计出来的新版要收费了!!
发表于 2014-10-8 19:10:52 | 显示全部楼层
   够用就行
发表于 2014-10-8 19:22:35 | 显示全部楼层
发表于 2014-10-8 19:35:23 | 显示全部楼层
确实是够用就行,MDK还是4.0的飘过。
发表于 2014-10-8 20:31:16 来自手机 | 显示全部楼层
昨天搞定了iar 7.3 今天晚点编译下cmsis dsp库 看看汇编怎么优化的 哈哈
发表于 2014-11-11 09:24:36 | 显示全部楼层
没用过IAR 好用吗
发表于 2014-11-11 09:26:29 | 显示全部楼层
这样 不知道是好 还是不好
发表于 2014-11-16 09:10:45 | 显示全部楼层
你要是昨天就破解出来了该多好
发表于 2014-11-18 10:26:57 | 显示全部楼层
比比谁的破解快
发表于 2014-11-18 10:32:08 | 显示全部楼层
我擦。。不过作为电工,一直没有更新软件的动力
发表于 2014-11-18 16:00:13 | 显示全部楼层
要‘能用’才行哈哈
发表于 2014-11-19 08:47:01 | 显示全部楼层
好啊 ,正版的好搞不
发表于 2014-11-25 13:30:56 | 显示全部楼层
4用了好多年了
发表于 2014-11-25 14:07:33 | 显示全部楼层
IAR作为非厂方,做得很好
发表于 2015-5-9 12:03:18 | 显示全部楼层
lz有rtl的库文件么,应该是源代码 恩恩
 楼主| 发表于 2015-5-9 15:02:59 | 显示全部楼层
RTL现在作为MDK的中间件库,没源代码
发表于 2015-5-9 15:08:30 | 显示全部楼层
感觉更新完后差别不大
发表于 2015-5-9 20:23:20 | 显示全部楼层
英蓓特网站介绍说pro版本有rtl的源代码,但是网上还没见人发过。。。
GMT+8, 2024-4-25 10:20
