出现这个问题 涉及到3个文件
main.c 内容:
#include <p33FJ32MC204.h>
#include "conf_bit.h"
#include "conf_osc.h"
#include "car_rtdm_test.h"
#include "RTDM.h"
#include "RTDMUSER.h"
int main(){
conf_osc();
conf_bit();
test_rtdm();
return 0;
conf_bit.h
#ifndef CONF_BIT_H
#define CONF_BIT_H
extern int conf_bit(void);
#endif /* CONF_BIT_H*/
conf_bit.c
extern int conf_bit(void){
/* 配置位信息 */
/* Configuration bits */
_FOSCSEL(FNOSC_FRCPLL); // Start with FRC will switch to Primary (XT, HS, EC) Oscillator with PLL
_FOSC(FCKSM_CSECMD & OSCIOFNC_ON & POSCMD_NONE); // Clock Switching Enabled and Fail Safe Clock Monitor is disable
// Primary Oscillator Mode: XT Crystal
//_FOSC(FCKSM_CSECMD & OSCIOFNC_OFF & POSCMD_NONE);
_FBS (BSS_NO_FLASH & BWRP_WRPROTECT_OFF);
/* no Boot sector and
write protection disabled */
_FWDT (FWDTEN_OFF);
/* Turn off Watchdog Timer */
_FGS (GSS_OFF & GCP_OFF & GWRP_OFF);
/* Set Code Protection Off for the General Segment */
_FPOR (PWMPIN_ON & HPOL_ON & LPOL_OFF & FPWRT_PWR128 );
//_FPOR (PWMPIN_ON & HPOL_ON & LPOL_OFF & FPWRT_PWR128 &ALTI2C_OFF);
/* PWM mode is Port registers
PWM high active high& low active low
alternate I2C mapped to SDA1/SCL1
FPOR power on reset 128ms
I2C mapped to SDA1/SCL1*/ //Add by hua 2014-9-1
_FICD (ICS_PGD3 & JTAGEN_OFF);
/* Use PGC3/PGD3 for programming and debugging
JTAG Enable Bit: JTAG is disabled
return 0;
现在编译报错:
build/default/production/_ext/1445274692/main.o(.text+0x2): In function `.LSM1':
: undefined reference to `_conf_osc'
build/default/production/_ext/1445274692/main.o(.text+0x4): In function `.LSM2':
: undefined reference to `_conf_bit'
make[2]: *** [dist/default/production/rtdm.X.production.hex] Error 255
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
nbproject/Makefile-default.mk:148: recipe for target 'dist/default/production/rtdm.X.production.hex' failed
make[2]: Leaving directory 'E:/kp/soft/soft_git/dspic/prj/rtdm.X'
nbproject/Makefile-default.mk:75: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/kp/soft/soft_git/dspic/prj/rtdm.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 2s) |
