回复: 199
AMCNC-03的稳定速度达到了32米/分钟,比01机快64倍
头像被屏蔽
发表于 2014-12-5 09:50:57 来自手机 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
出10入210汤圆
发表于 2014-12-5 09:51:44 | 显示全部楼层
,占沙发!
发表于 2014-12-5 09:53:15 | 显示全部楼层
精品将要诞生了
出0入50汤圆
发表于 2014-12-5 10:00:07 | 显示全部楼层
终于看到基本靠谱的参考价格了
发表于 2014-12-5 10:04:02 | 显示全部楼层
>国外市场?
>售价会在10-20万人民币?
The Tormach PCNC 1100 USD$7000 and above, This particular one is listed as USD$8,480.00 (with some options):
http://www.tormach.com/product_pcnc_main.html
Major feature:
A 3-axis personal CNC mill with control software. Loaded with the features you want: over 1/2 ton cast iron and steel construction, 1.5 HP sensorless vector spindle drive, precision ground ballscrews, and more.
Computer Controlled Spindle Speed and Direction
Precision R8 spindle – 5000 RPM Vector Technology
Ground P4 Ballscrews and Single Shot Lubrication
34" x 9.5" Table
Provides both manual & automatic operations
12 mos. factory warranty
Iron and Frame Design
Each PCNC 1100 CNC mill has over half a ton of cast iron and steel that is precisely placed to achieve maximum frame rigidity in a footprint that's about the size of a traditional manual milling machine.
The sliding dovetailed ways are hand-scraped and designed to withstand high loads and dampen vibrations. The ways have bonded PTFE filled acetyl sliding surfaces, hand scraped by skilled machine builders. Similar to brand name compounds such as Turcite® or Rulon®, PTFE compounds provide low friction and long life.
出0入25汤圆
发表于 2014-12-5 10:04:43 | 显示全部楼层
恭喜,十年磨一剑,终于要完成了。
发表于 2014-12-5 10:07:45 | 显示全部楼层
Some pictures and videos will help a lot.
发表于 2014-12-5 10:08:56 | 显示全部楼层
心动啊。
出0入21汤圆
发表于 2014-12-5 10:09:35 | 显示全部楼层
终于用伺服了。
发表于 2014-12-5 10:10:57 | 显示全部楼层
恭喜,精品即将亮相
头像被屏蔽
 楼主| 发表于 2014-12-5 10:11:27 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
出50入0汤圆
发表于 2014-12-5 10:18:30 | 显示全部楼层
恭喜老大
发表于 2014-12-5 10:19:31 | 显示全部楼层
The Tormach PCNC 1100 is made of iron and steel and very well priced.
The local tachshop has one at Detroit:
http://www.techshop.ws/index.html
发表于 2014-12-5 10:20:24 | 显示全部楼层
要是能上张图就更好了。
发表于 2014-12-5 10:22:00 | 显示全部楼层
2W??? 交流伺服四个,到时候真有的卖了,会考虑购买的
发表于 2014-12-5 10:24:17 | 显示全部楼层
mark精品
发表于 2014-12-5 10:28:06 | 显示全部楼层
nb,64倍就是32米/分钟,533mm/秒
头像被屏蔽
 楼主| 发表于 2014-12-5 10:30:04 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
出610入42汤圆
发表于 2014-12-5 10:33:43 | 显示全部楼层
也许,有人可以买两台来创业,做做代加工。还可以自己玩
发表于 2014-12-5 10:36:59 | 显示全部楼层
要开卖的节奏
发表于 2014-12-5 10:41:22 | 显示全部楼层
哇哦!酷
发表于 2014-12-5 10:43:03 | 显示全部楼层
恭喜老大,海外市场发来贺电~
发表于 2014-12-5 10:45:25 | 显示全部楼层
可喜可贺!
真是五年磨一剑!
头像被屏蔽
 楼主| 发表于 2014-12-5 10:48:49 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 11:02:07 | 显示全部楼层
armok 发表于 2014-12-5 10:48
是的,现在的1秒钟,是以前的1分钟。
需要机械加工的精度极为精密,才可以做到这个速度。 ...
关键是什么时候能出来呀?等的心焦
发表于 2014-12-5 11:13:21 | 显示全部楼层
非常期待,这个有点猛
发表于 2014-12-5 11:19:29 | 显示全部楼层
最大加工尺寸是多少?
头像被屏蔽
 楼主| 发表于 2014-12-5 11:20:44 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 11:24:14 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 11:30:11 | 显示全部楼层
动心了。。。
发表于 2014-12-5 11:34:29 | 显示全部楼层
来个图片看下
发表于 2014-12-5 11:37:19 | 显示全部楼层
求图片,看看呐
发表于 2014-12-5 11:57:55 | 显示全部楼层
The local tachshop has one at  ...
那个只是个基本价格,想让机器运行起来,自己看看还需要多少配件吧:
http://www.tormach.com/store/ind ... 00_Packages_Starter
Enter a quantity for each item you would like to add to your shopping cart or wish list then click the 'Add To Cart' or 'Add To Wish List' button at the bottom of the listing to proceed. Required fields are marked with a star (*).
Quantity        Item
32085 - PCNC 1100 Series 3
Tormach 1100 Series 3 Personal CNC
Price: $8,480.00
Oiler Options
30490 - Manual Oiler for PCNC 1100
32383 - Automatic Oiler for PCNC 1100 - Add $209.00
30297 - PCNC 1100 Deluxe Machine Stand w/ Coolant Kit
Price: $1,644.50
30286 - Machine Arm
Machine Arm
Price: $295.00
34437 - Cable Kit for Tormach PCNC 1100 / PCNC 770
Cable Integration Kit for Tormach PCNC 1100 / Tormach PCNC 770.
Price: $39.95
31446 - Lifting Bar
Lifting Bar
Price: $93.21
34917 - Tormach Machine Controller w/Mach3
Price: $715.00
30616 - Shuttle Jog Controller
Shuttle Jog Controller. A USB connected electronic handwheel; use for positioning and manual cutting operations.
Price: $84.02
30615 - Standard LCD Monitor
Standard 17" LCD Monitor; VESA mount compatible.
Price: $162.80
31371 - Mini Keyboard
Mini Keyboard
Price: $19.80
31384 - Cover for Mini Keyboard
Cover for Mini Keyboard. Silcone Overlay; protects keyboard from chips, coolant and grime.
Price: $9.63
31289 - USB Bulkhead Port Assembly
USB Bulkhead Port Assembly for Deluxe Stand.
Price: $32.88
31947 - Basic 3 Piece Indicator Set
Basic 3 Piece Indicator Set includes Dial Test Indicator, Dial Indicator, and Universal Magnetic Base.
Price: $75.16
31759 - 5" CNC Vise
5" CNC Vise. Compact Vise with replaceable jaw plates, includes bridge clamp set.
Price: $295.00
31789 - 2pc Vise Alignment Keys with Screws for 5" CNC Vise
2pc Vise Alignment Keys with Screws for 5" Machinist Vise
Price: $14.03
32580 - 58 PC Pro Quality Steel Clamp Kit
58 Piece Pro Quality Steel Clamp Kit for 5/8" T-slots.
Price: $64.63
32284 - CNC Operator's Set with Tool Assistant Set
Price: $795.00
33479 - 1/4"-90�
90� Cobalt Steel Spot Drills: 1/4"-90�
Price: $4.10
33481 - 3/8"-90�
90� Cobalt Steel Spot Drills: 3/8"-90�
Price: $5.90
33489 - 1/16" - 1/2 " Jobber Length Drill Set (by 64ths)
General Purpose High Speed Steel Jobber Length Drills. TiN Coated. : 1/16 - 1/2 " by 64ths
Price: $72.76
33465 - 2 Flute HSS End Mill Set (5 Pieces)
2 Flute HSS End Mill Set includes 1/8", 3/16", 1/4" 5/16", and 3/8" Diameter End Mills. Regular Length, Single End,Weldon Shank, Uncoated.
Price: $32.18
31386 - Machine Oil
Way Oil, meets ISO VG 68. 1 gallon.
Price: $34.50
31750 - Synthetic Coolant - 1 Gal.
Synthetic Coolant - 1 Gal. Concentrated, makes 20 gallons of coolant.
Price: $25.03
头像被屏蔽
 楼主| 发表于 2014-12-5 12:12:11 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 12:15:40 | 显示全部楼层
哎呀,加工面积比预想的小了一些。不过这样总重量也就小了许多,在家里摆放移动都很方便。其实02机用了两年多,真正需要加工的零件超过200X150的也不多。
发表于 2014-12-5 12:17:13 | 显示全部楼层
顶下,另外请教下雕刻机能否精密铣一些铝制部件,当然是保证安全的前提下
头像被屏蔽
 楼主| 发表于 2014-12-5 12:20:38 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 12:21:59 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 12:22:39 | 显示全部楼层
armok 发表于 2014-12-5 12:20
这一台AMCNC-03的定位是工业级的,非常适合每天24小时,每年365天铣铝使用。
当然,它的定位是雕刻机, ...
我记得以前说过铣铝,可以一刀铣2mm深的。
发表于 2014-12-5 12:24:15 | 显示全部楼层
十分期待,希望能入手一台。
头像被屏蔽
 楼主| 发表于 2014-12-5 12:24:57 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
出150入8汤圆
发表于 2014-12-5 12:26:53 | 显示全部楼层
刻个电路板那不是很快? 没用过雕刻机,但是耳朵很厉害,害怕雕刻声音。
头像被屏蔽
 楼主| 发表于 2014-12-5 12:27:14 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 12:30:31 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 12:42:35 | 显示全部楼层
64倍啊,不得了
像这样真正底层的机电一体化项目应该是很好未来前景的。
只要有一定的发展机遇,在技术上能够严谨的坚持应该有望开出一朵自己的“德马吉”之花。
出0入36汤圆
发表于 2014-12-5 12:46:19 | 显示全部楼层
啥时候开卖?
发表于 2014-12-5 12:46:41 | 显示全部楼层
算算,一秒钟快接近0.5m了,想象一下,都觉得很快啊。
出5入0汤圆
发表于 2014-12-5 12:50:29 | 显示全部楼层
armok 发表于 2014-12-5 12:30
应该会比01机快10倍左右。
合理的设计雕刻路径,比如: 使用阴雕法(即将没有用的地方,全部铺铜,使用0 ...
“立等可取”,这个表述可以想象到其速度,呵呵
站长发力出精品啊
发表于 2014-12-5 13:09:29 | 显示全部楼层
非常期待啊
发表于 2014-12-5 13:10:03 | 显示全部楼层
赞立等可取
发表于 2014-12-5 13:17:19 | 显示全部楼层
这节奏的话  是全民普及风暴哦!阿莫出品必属精品
发表于 2014-12-5 13:24:41 | 显示全部楼层
armok 发表于 2014-12-5 11:24
这一台是小型的,200*150*100(长,宽,高)。
如果觉得这个尺寸不够大,可以稍等一下AMCNC-04机,会是4 ...
04机比较期待,这个加工幅面就够了
头像被屏蔽
 楼主| 发表于 2014-12-5 13:41:13 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 13:45:20 | 显示全部楼层
armok 发表于 2014-12-5 13:41
其实03机已经绝大部分人够用了。
当然每个人都希望是1米行程。但1米行程的机器要重达10吨,要30平方地方 ...
不用那么大,其实,目前03也能满足当前使用。 买这个其实主要是加工铝件
发表于 2014-12-5 13:50:21 来自手机 | 显示全部楼层
非常给力啊,期待
头像被屏蔽
 楼主| 发表于 2014-12-5 13:58:54 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 14:03:25 | 显示全部楼层
我上次去北京的展会上看到很多雕刻机和加工设备包括雕刻机在内,都用u槽电机和平板电机了,速度非常快。莫大可以研究一下哈。
发表于 2014-12-5 14:11:00 | 显示全部楼层
确实是好东西
发表于 2014-12-5 14:50:15 | 显示全部楼层
非常期待!
头像被屏蔽
 楼主| 发表于 2014-12-5 15:08:36 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 15:14:44 | 显示全部楼层
高手呀
发表于 2014-12-5 15:17:34 | 显示全部楼层
这可是个好消息!看来要准备工作台和电脑了。
发表于 2014-12-5 15:19:19 | 显示全部楼层
再问一句,新机器是原来的并口接口还是新的USB接口?
出50入0汤圆
发表于 2014-12-5 15:33:22 | 显示全部楼层
这个价格,这个参数,怎么说呢,太冲击了
发表于 2014-12-5 15:45:15 | 显示全部楼层
感觉这个参数真好
发表于 2014-12-5 15:48:02 | 显示全部楼层
老大什么时候出个入门级的啊
发表于 2014-12-5 15:51:18 来自手机 | 显示全部楼层
抢先国外市场,也是需要扬眉吐气的时候了。
出0入59汤圆
发表于 2014-12-5 15:56:48 | 显示全部楼层
05机=机机复机机?
发表于 2014-12-5 16:01:13 | 显示全部楼层
阿莫弄个演示视频给大伙开开眼
发表于 2014-12-5 16:03:56 来自手机 | 显示全部楼层
速度真快哈,加工效率大大提高了
发表于 2014-12-5 16:04:40 | 显示全部楼层
期待中
发表于 2014-12-5 16:15:12 | 显示全部楼层
恭喜莫大
发表于 2014-12-5 16:21:22 | 显示全部楼层
非常值得等待!
发表于 2014-12-5 16:25:54 | 显示全部楼层
32米每分钟 恐怖啊。  记得马扎克的超高速攻赚中心也没这么块
发表于 2014-12-5 16:33:36 | 显示全部楼层
行业又要洗牌了
头像被屏蔽
 楼主| 发表于 2014-12-5 16:35:36 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 16:42:22 | 显示全部楼层
准备银子败一台创业,我想主要加工铜金属,有没问题?
发表于 2014-12-5 16:42:51 | 显示全部楼层
站长开始预售吧....
出0入26汤圆
发表于 2014-12-5 16:52:22 | 显示全部楼层
能加工铝或铜,两万元的价格可以接受。我的小公司有些铝件和铜件都是发外的,数量不是很多,价格奇高。
发表于 2014-12-5 16:54:03 | 显示全部楼层
armok 发表于 2014-12-5 16:35
并口的速度怎么可以支持32米/分钟?
哈哈!那就是USB口的了!!!
这真是又一个好消息!!!买电脑不用纠结了!
头像被屏蔽
 楼主| 发表于 2014-12-5 16:55:20 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 17:03:12 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 17:04:45 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2014-12-5 17:07:15 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 17:20:14 | 显示全部楼层
比得我心里痒痒啊,恭喜先~~~
发表于 2014-12-5 18:12:40 | 显示全部楼层
效率高,才有效益啊,期盼
发表于 2014-12-5 18:25:56 | 显示全部楼层
刀尖受不了的
头像被屏蔽
 楼主| 发表于 2014-12-5 18:36:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 19:10:54 | 显示全部楼层
                 恭喜了
发表于 2014-12-5 19:30:57 | 显示全部楼层
恭喜莫大
发表于 2014-12-5 20:04:21 | 显示全部楼层
恭喜恭喜
发表于 2014-12-5 20:12:02 | 显示全部楼层
创业利器?
发表于 2014-12-5 20:22:52 | 显示全部楼层
应该会比01机快10倍左右。
期待能在3月的展览会上看见,那展览会在华南区算是上档次的展览会了.
发表于 2014-12-5 20:47:08 | 显示全部楼层
这个可是个精品呀,要是能推出个入门级的,低配版的就好了,否则个人diy搞不起这么高大上的
头像被屏蔽
 楼主| 发表于 2014-12-5 20:51:12 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-5 20:58:50 | 显示全部楼层
出来后我们实验室买一台!不错!!
发表于 2014-12-5 21:11:34 | 显示全部楼层
这个版块今天帖子很多,必然有重要消息。
发表于 2014-12-5 22:53:08 | 显示全部楼层
如此高的切削速度,不可思议。如果用来雕刻pcb,岂不是10分钟左右1块板?
发表于 2014-12-5 22:57:07 | 显示全部楼层
>u槽电机和平板电机
What is it?
头像被屏蔽
 楼主| 发表于 2014-12-5 23:19:51 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-4-26 21:12
