下面是我今天调试的时候的一些打印信息,您帮我看看有什么问题?
VPU initialized
[ 4.813972] mxc_asrc registered
[ 4.817357] Galcore version 4.6.9.9754
[ 4.821189] galcore options:
[ 4.826205] irqLine = 41
[ 4.831867] registerMemBase = 0x00130000
[ 4.836207] registerMemSize = 0x00004000
[ 4.840605] irqLine2D = 42
[ 4.844250] registerMemBase2D = 0x00134000
[ 4.850604] registerMemSize2D = 0x00004000
[ 4.856999] irqLineVG = 43
[ 4.862657] registerMemBaseVG = 0x02204000
[ 4.869011] registerMemSizeVG = 0x00004000
[ 4.873397] contiguousSize = 536870912
[ 4.877655] contiguousBase = 0x5E400000
[ 4.882047] bankSize = 0x00000000
[ 4.886386] fastClear = -1
[ 4.890162] compression = -1
[ 4.893862] signal = 48
[ 4.897512] baseAddress = 0x10000000
[ 4.901852] physSize = 0x00000000
[ 4.906243] logFileSize = 0 KB
[ 4.910160] powerManagement = 1
[ 4.913710] gpuProfiler = 0
[ 4.916965] coreClock = 156000000
[ 4.942404] gcmkONERROR: status=-21(gcvSTATUS_INVALID_REQUEST) @ gckVGHARDWARE_SetPowerManagementState(1676)
[ 4.952396] _ProcessInterrupt: Error -21 incrementing the semaphore #13.
[ 4.959200] revserved_memory_account:viv_gpu registerd
[ 11.895352] ERROR: v4l2 capture: slave not found!
[ 11.902295] ERROR: v4l2 capture: slave not found!
[ 11.907851] ERROR: v4l2 capture: slave not found!
[ 12.865862] gcmkONERROR: status=-16(gcvSTATUS_OUT_OF_RESOURCES) @ gckOS_CopyFromUserData(5174)
[ 12.874623] gcmkONERROR: status=-16(gcvSTATUS_OUT_OF_RESOURCES) @ gckKERNEL_OpenUserData(3151)
[ 12.883397] gcmkONERROR: status=-16(gcvSTATUS_OUT_OF_RESOURCES) @ gckCONTEXT_Update(1455)
[ 12.891783] gcmkONERROR: status=-16(gcvSTATUS_OUT_OF_RESOURCES) @ gckCOMMAND_Commit(1340)
[ 12.900099] gcmkONERROR: status=-16(gcvSTATUS_OUT_OF_RESOURCES) @ gckKERNEL_Dispatch(1407)
[ 14.003444] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
[ 20.865718] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 25.378237] period 0 ,timeout is 0, wake up is :0
[ 25.389151] period 0 ,timeout is 0, wake up is :0
[ 29.883303] request_suspend_state: wakeup (3->0) at 29655829005 (1970-01-02 00:00:08.999792334 UTC)
[ 29.892724] cpufreq_interactive_input_connect: connect to max11801_ts
我把kernel_imx/drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_types.h
文件中的gcdDEBUG宏定义,定义为下面:这样是不是所有的debug都打开。但这时候android系统就启动不起来了。android的所有进程都没有启动。
#define gcdDEBUG gcdDEBUG_ALL |
