发表于 2015-12-5 22:12:21
我一直用AES。。。。。。。贴上我用的~~也是网上扒的~~修改了一下~~~
- ** 文件名: AES.c
- ** 版本: 1.0
- ** 工作环境: RealView MDK-ARM 4.23
- ** 作者: 陈志强
- ** 生成日期: 2012-4-24
- ** 功能:
- ** 相关文件:
- ** 修改日志:
- ** 注意事项:
- 加密算法采用AES ,此加密算法来源于网络
- #include "stm32f10x.h"
- #include "aes.h"
- #include <string.h>
- *全局变量:
- *全局说明:
- #define BPOLY 0x1b //!< Lower 8 bits of (x^8+x^4+x^3+x+1), ie. (x^4+x^3+x+1).
- #define BLOCKSIZE 16 //4*4矩阵,AES一次只能对16字节加密//!< Block size in number of bytes.
- #define KEY_COUNT 3
- #if KEY_COUNT == 1
- #define KEYBITS 128 //!< Use AES128. 密钥宽度
- #elif KEY_COUNT == 2
- #define KEYBITS 192 //!< Use AES196.
- #elif KEY_COUNT == 3
- #define KEYBITS 256 //!< Use AES256.
- #else
- #error "Use 1, 2 or 3 keys!"
- #endif
- #if KEYBITS == 128
- #define ROUNDS 10 //!< Number of rounds.循环迭代次数
- #define KEYLENGTH 16 //!< Key length in number of bytes.
- #elif KEYBITS == 192
- #define ROUNDS 12 //!< Number of rounds.
- #define KEYLENGTH 24 //!< // Key length in number of bytes.
- #elif KEYBITS == 256
- #define ROUNDS 14 //!< Number of rounds. 循环迭代次数
- #define KEYLENGTH 32 //!< Key length in number of bytes.
- #else
- #error "Key must be 128, 192 or 256 bits!"
- #endif
- #define EXPANDED_KEY_SIZE (BLOCKSIZE * (ROUNDS+1)) //!< 176, 208 or 240 bytes.
- //密钥
- unsigned char AES_Key_Table[32] =
- 0x04,0x40,0x04,0x48,0x08,0x58,0x08,0x60,
- 0x18,0xC0,0x29,0x40,0x4A,0x44,0x08,0x44,
- 0x09,0x3C,0x01,0x00,0xFF,0xFE,0x01,0x00,
- 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00
- unsigned char block1[256]; //!< Workspace 1.
- unsigned char block2[256]; //!< Worksapce 2.
- unsigned char tempbuf[256];
- unsigned char *powTbl; //!< Final location of exponentiation lookup table.
- unsigned char *logTbl; //!< Final location of logarithm lookup table.
- unsigned char *sBox; //!< Final location of s-box.
- unsigned char *sBoxInv; //!< Final location of inverse s-box.
- unsigned char *expandedKey; //!< Final location of expanded key.
- void CalcPowLog(unsigned char *powTbl, unsigned char *logTbl)
- unsigned char i = 0;
- unsigned char t = 1;
- do {
- // Use 0x03 as root for exponentiation and logarithms.
- powTbl[i] = t;
- logTbl[t] = i;
- i++;
- // Muliply t by 3 in GF(2^8).
- t ^= (t << 1) ^ (t & 0x80 ? BPOLY : 0);
- }while( t != 1 ); // Cyclic properties ensure that i < 255.
- powTbl[255] = powTbl[0]; // 255 = '-0', 254 = -1, etc.
- //获取置换S-盒
- void CalcSBox( unsigned char * sBox )
- unsigned char i, rot;
- unsigned char temp;
- unsigned char result;
- // Fill all entries of sBox[].
- i = 0;
- do {
- //Inverse in GF(2^8).
- if( i > 0 )
- temp = powTbl[ 255 - logTbl[i] ];
- else
- temp = 0;
- // Affine transformation in GF(2).
- result = temp ^ 0x63; // Start with adding a vector in GF(2).
- for( rot = 0; rot < 4; rot++ )
- // Rotate left.
- temp = (temp<<1) | (temp>>7);
- // Add rotated byte in GF(2).
- result ^= temp;
- // Put result in table.
- sBox[i] = result;
- } while( ++i != 0 );
- //获取解谜替换S盒(用于解密)
- void CalcSBoxInv( unsigned char * sBox, unsigned char * sBoxInv )
- unsigned char j = 0;
- // Iterate through all elements in sBoxInv using i.
- do {
- // Search through sBox using j.
- do {
- // Check if current j is the inverse of current i.
- if( sBox[ j ] == i )
- // If so, set sBoxInc and indicate search finished.
- sBoxInv[ i ] = j;
- j = 255;
- } while( ++j != 0 );
- void CycleLeft( unsigned char * row )
- // Cycle 4 bytes in an array left once.
- unsigned char temp = row[0];
- row[0] = row[1];
- row[1] = row[2];
- row[2] = row[3];
- row[3] = temp;
- //列混合反变换(用于解密)
- void InvMixColumn( unsigned char * column )
- unsigned char r0, r1, r2, r3;
- r0 = column[1] ^ column[2] ^ column[3];
- r1 = column[0] ^ column[2] ^ column[3];
- r2 = column[0] ^ column[1] ^ column[3];
- r3 = column[0] ^ column[1] ^ column[2];
- column[0] = (column[0] << 1) ^ (column[0] & 0x80 ? BPOLY : 0);
- column[1] = (column[1] << 1) ^ (column[1] & 0x80 ? BPOLY : 0);
- column[2] = (column[2] << 1) ^ (column[2] & 0x80 ? BPOLY : 0);
- column[3] = (column[3] << 1) ^ (column[3] & 0x80 ? BPOLY : 0);
- r0 ^= column[0] ^ column[1];
- r1 ^= column[1] ^ column[2];
- r2 ^= column[2] ^ column[3];
- r3 ^= column[0] ^ column[3];
- r0 ^= column[0] ^ column[2];
- r1 ^= column[1] ^ column[3];
- r2 ^= column[0] ^ column[2];
- r3 ^= column[1] ^ column[3];
- column[0] ^= column[1] ^ column[2] ^ column[3];
- r0 ^= column[0];
- r1 ^= column[0];
- r2 ^= column[0];
- r3 ^= column[0];
- column[0] = r0;
- column[1] = r1;
- column[2] = r2;
- column[3] = r3;
- //字节替换
- void SubBytes( unsigned char * bytes, unsigned char count )
- do {
- *bytes = sBox[ *bytes ]; // Substitute every byte in state.
- bytes++;
- } while( --count );
- // 用于解密的字节反替换
- void InvSubBytesAndXOR( unsigned char * bytes, unsigned char * key, unsigned char count )
- do {
- // *bytes = sBoxInv[ *bytes ] ^ *key; // Inverse substitute every byte in state and add key.
- *bytes = block2[ *bytes ] ^ *key; // Use block2 directly. Increases speed.
- bytes++;
- key++;
- //用于解密的行位移反变换
- void InvShiftRows( unsigned char * state )
- // Note: State is arranged column by column.
- // Cycle second row right one time.
- temp = state[ 1 + 3*4 ];
- state[ 1 + 3*4 ] = state[ 1 + 2*4 ];
- state[ 1 + 2*4 ] = state[ 1 + 1*4 ];
- state[ 1 + 1*4 ] = state[ 1 + 0*4 ];
- state[ 1 + 0*4 ] = temp;
- // Cycle third row right two times.
- temp = state[ 2 + 0*4 ];
- state[ 2 + 0*4 ] = state[ 2 + 2*4 ];
- state[ 2 + 2*4 ] = temp;
- temp = state[ 2 + 1*4 ];
- state[ 2 + 1*4 ] = state[ 2 + 3*4 ];
- state[ 2 + 3*4 ] = temp;
- // Cycle fourth row right three times, ie. left once.
- temp = state[ 3 + 0*4 ];
- state[ 3 + 0*4 ] = state[ 3 + 1*4 ];
- state[ 3 + 1*4 ] = state[ 3 + 2*4 ];
- state[ 3 + 2*4 ] = state[ 3 + 3*4 ];
- state[ 3 + 3*4 ] = temp;
- //用于解密的行混合反变换
- void InvMixColumns( unsigned char * state )
- InvMixColumn( state + 0*4 );
- InvMixColumn( state + 1*4 );
- InvMixColumn( state + 2*4 );
- InvMixColumn( state + 3*4 );
- void XORBytes( unsigned char * bytes1, unsigned char * bytes2, unsigned char count )
- do {
- *bytes1 ^= *bytes2; // Add in GF(2), ie. XOR.
- bytes1++;
- bytes2++;
- void CopyBytes( unsigned char * to, unsigned char * from, unsigned char count )
- do {
- *to = *from;
- to++;
- from++;
- void KeyExpansion( unsigned char * expandedKey )
- unsigned char temp[4];
- unsigned char i;
- unsigned char Rcon[4] = { 0x01, 0x00, 0x00, 0x00 }; // Round constant.
- unsigned char * key = AES_Key_Table;//获取我们的密钥,然后生成密钥调度表
- // Copy key to start of expanded key.
- i = KEYLENGTH;
- do {
- *expandedKey = (*key)+1; //自己加了1
- expandedKey++;
- key++;
- } while( --i );
- // Prepare last 4 bytes of key in temp.
- expandedKey -= 4;
- temp[0] = *(expandedKey++);
- temp[1] = *(expandedKey++);
- temp[2] = *(expandedKey++);
- temp[3] = *(expandedKey++);
- // Expand key.
- i = KEYLENGTH;
- while( i < BLOCKSIZE*(ROUNDS+1) )
- // Are we at the start of a multiple of the key size?
- if( (i % KEYLENGTH) == 0 )
- CycleLeft( temp ); // Cycle left once.
- SubBytes( temp, 4 ); // Substitute each byte.
- XORBytes( temp, Rcon, 4 ); // Add constant in GF(2).
- *Rcon = (*Rcon << 1) ^ (*Rcon & 0x80 ? BPOLY : 0);
- // Keysize larger than 24 bytes, ie. larger that 192 bits?
- #if KEYLENGTH > 24
- // Are we right past a block size?
- else if( (i % KEYLENGTH) == BLOCKSIZE ) {
- #endif
- // Add bytes in GF(2) one KEYLENGTH away.
- XORBytes( temp, expandedKey - KEYLENGTH, 4 );
- // Copy result to current 4 bytes.
- *(expandedKey++) = temp[ 0 ];
- *(expandedKey++) = temp[ 1 ];
- *(expandedKey++) = temp[ 2 ];
- *(expandedKey++) = temp[ 3 ];
- i += 4; // Next 4 bytes.
- //解密输入函数
- void InvCipher( unsigned char * block, unsigned char * expandedKey )
- unsigned char round = ROUNDS-1;
- expandedKey += BLOCKSIZE * ROUNDS;
- XORBytes( block, expandedKey, 16 );
- expandedKey -= BLOCKSIZE;
- do {
- InvShiftRows( block );
- InvSubBytesAndXOR( block, expandedKey, 16 );
- InvMixColumns( block );
- } while( --round );
- void aesDecInit(void)
- powTbl = block1;
- logTbl = block2;
- CalcPowLog( powTbl, logTbl );
- sBox = tempbuf;
- CalcSBox( sBox );
- expandedKey = block1;
- KeyExpansion( expandedKey );
- sBoxInv = block2; // Must be block2.
- CalcSBoxInv( sBox, sBoxInv );
- void aesDecrypt( unsigned char * buffer, unsigned char * chainBlock )
- unsigned char temp[ BLOCKSIZE ];
- CopyBytes( temp, buffer, BLOCKSIZE );
- InvCipher( buffer, expandedKey );
- XORBytes( buffer, chainBlock, BLOCKSIZE );
- CopyBytes( chainBlock, temp, BLOCKSIZE );
- unsigned char Multiply( unsigned char num, unsigned char factor )
- unsigned char mask = 1;
- unsigned char result = 0;
- while( mask != 0 )
- // Check bit of factor given by mask.
- if( mask & factor )
- // Add current multiple of num in GF(2).
- result ^= num;
- // Shift mask to indicate next bit.
- mask <<= 1;
- // Double num.
- num = (num << 1) ^ (num & 0x80 ? BPOLY : 0);
- return result;
- unsigned char DotProduct( unsigned char * vector1, unsigned char * vector2 )
- result ^= Multiply( *vector1++, *vector2++ );
- result ^= Multiply( *vector1 , *vector2 );
- return result;
- //行混合变换
- void MixColumn( unsigned char * column )
- unsigned char row[8] = {0x02, 0x03, 0x01, 0x01, 0x02, 0x03, 0x01, 0x01};
- // Prepare first row of matrix twice, to eliminate need for cycling.
- unsigned char result[4];
- // Take dot products of each matrix row and the column vector.
- result[0] = DotProduct( row+0, column );
- result[1] = DotProduct( row+3, column );
- result[2] = DotProduct( row+2, column );
- result[3] = DotProduct( row+1, column );
- // Copy temporary result to original column.
- column[0] = result[0];
- column[1] = result[1];
- column[2] = result[2];
- column[3] = result[3];
- void MixColumns( unsigned char * state )
- MixColumn( state + 0*4 );
- MixColumn( state + 1*4 );
- MixColumn( state + 2*4 );
- MixColumn( state + 3*4 );
- //行位移变换
- void ShiftRows( unsigned char * state )
- // Cycle second row left one time.
- temp = state[ 1 + 0*4 ];
- state[ 1 + 0*4 ] = state[ 1 + 1*4 ];
- state[ 1 + 1*4 ] = state[ 1 + 2*4 ];
- state[ 1 + 2*4 ] = state[ 1 + 3*4 ];
- state[ 1 + 3*4 ] = temp;
- // Cycle third row left two times.
- // Cycle fourth row left three times, ie. right once.
- temp = state[ 3 + 3*4 ];
- state[ 3 + 3*4 ] = state[ 3 + 2*4 ];
- state[ 3 + 2*4 ] = state[ 3 + 1*4 ];
- state[ 3 + 1*4 ] = state[ 3 + 0*4 ];
- state[ 3 + 0*4 ] = temp;
- //加密输入函数
- void Cipher( unsigned char * block, unsigned char * expandedKey )
- expandedKey += BLOCKSIZE;
- do {
- SubBytes( block, 16 );//字节替换
- ShiftRows( block ); //行位移变换
- MixColumns( block ); //行混合变换
- } while( --round );//对明文进行14次迭代加密
- void aesEncInit(void)
- powTbl = block1;
- logTbl = tempbuf;
- sBox = block2;
- CalcSBox( sBox );//获取SBOX
- KeyExpansion( expandedKey );//获取密钥扩展历程(密钥调度表)
- void aesEncrypt( unsigned char * buffer, unsigned char * chainBlock )
- XORBytes( buffer, chainBlock, BLOCKSIZE );//用密钥调度表对明文块一个一个字节异或!
- Cipher( buffer, expandedKey );//获取密码
- CopyBytes( chainBlock, buffer, BLOCKSIZE );//将密码输出
- //加密
- void AES_Enc(unsigned char *buffer)
- unsigned char chainCipherBlock[16];
- memset(chainCipherBlock,0x00,sizeof(chainCipherBlock));
- //aesEncInit();/* 在执行加密初始化之前可以为AES_Key_Table赋值有效的密码数据 */
- aesEncrypt(buffer, chainCipherBlock);/* AES加密,数组dat里面的新内容就是加密后的数据。 */
- //解密
- void AES_Dec(unsigned char *buffer)
- memset(chainCipherBlock,0x00,sizeof(chainCipherBlock));/* 这里要重新初始化清空 */
- //aesEncInit();
- aesDecrypt(buffer, chainCipherBlock);/* AES解密,密文数据存放在dat里面,经解密就能得到之前的明文。 */
