回复: 0
程序跑进rt_timer_check函数中出不来了
发表于 2016-2-3 09:07:06 | 显示全部楼层 |阅读模式
做了个程序用来接收TCP数据然后通过DMA发送出去,但是跑个一两天,程序就会进入rt_timer_check中出不来。导致无法正常接收TCP发来的数据。
我看了下while (!rt_list_isempty(&rt_timer_list[RT_TIMER_SKIP_LIST_LEVEL-1]))这个判断导致的。
在这个循环中一直判断if ((current_tick - t->timeout_tick) < RT_TICK_MAX/2) 然后stop timer。
我没太研究过这个函数是做什么的,我想知道造成这样问题的原因是什么,如何解决。
附接收TCP数据函数
                /* accept any icoming connection */
                netconn_accept(tcpconn, &newconn);
                if(newconn)
                    struct netbuf *inbuf;
                    char *buf;
                    u16_t buflen;
                    while(netconn_err(newconn) == ERR_OK)
                        ad9789_read_block_num_temp = ad9789_read_block_num>>(10-AD9789_CONVERT_MOVE);
                        ad9789_read_block_num_temp &= 0x3f;
                        ad9789_write_block_num = ad9789_write_add>>10;
                        if((ad9789_write_block_num != ad9789_read_block_num_temp)&&(ad9789_write_block_num != ((ad9789_read_block_num_temp-1)&0x3f))&&(ad9789_write_block_num != ((ad9789_read_block_num_temp-2)&0x3f)))
                            /* Read the data from the port, blocking if nothing yet there.
                            We assume the request (the part we care about) is in one netbuf */
                            err = netconn_recv(newconn, &inbuf);
                            if(inbuf != NULL)
                                netbuf_data(inbuf, (void**)&buf, &buflen);
                                if(((unsigned long)(ad9789_write_add) + buflen) > 0xffff)
                                    memcpy(&udp_receive_buffer1_2[ad9789_write_add], buf, (0xffff-ad9789_write_add+1));
                                    memcpy(udp_receive_buffer1_2, &buf[(0xffff-ad9789_write_add+1)], buflen-(0xffff-ad9789_write_add+1));
                                    ad9789_write_add = buflen-(0xffff-ad9789_write_add+1);
                                    memcpy(&udp_receive_buffer1_2[ad9789_write_add], buf, buflen);
                                    ad9789_write_add += buflen;
                                /* Delete the buffer (netconn_recv gives us ownership,
                                so we have to make sure to deallocate the buffer) */
                                netbuf_delete(inbuf);
                            delay_ms(5);
                    /* Close the connection (server closes in HTTP) */
                    netconn_close(newconn);
                    /* delete connection */
                    netconn_delete(newconn);
是接收TCP数据然后通过DMA向AD9789发送的函数,我在想是不是因为netconn_recv没有设置超时等待时间导致的……请各位指导。
GMT+8, 2024-4-25 15:42
