软件介绍:
NemaStudio
NemaStudio provides the professional developer of NMEA products with a very powerful development and testing tool by simulating the output of various nautical instruments and target objects including GPS, AIS and Radar. All instruments, targets and ports can be matched and mixed, meaning you can have multiple instances of several objects transmitting over the same or over different ports simultaneously.
NemaTalker
NemaTalker simulates the output of up to 6 different instruments simultaneously: GPS, Weather, Sounder, Heading, Velocity and Radar, plus a feature to create your own custom formatted sentences.
All output is sent to one dedicated serial port. Input from this port can be logged in an optional log file. The dynamic parameters of each instrument can be controlled via a common set of controls: the "cockpit".
GPSSimul
GPSSimul is a very handy tool for developers of GPS dependent software since it eliminates the need for connecting a physical GPS unit during the development and testing cycle. GPSSimul is also great if you need to test or trial any NMEA compatible device like an autopilot or a software charting program. This is the ideal GPS simulation product for you if you do not require the extensive functionality of NemaStudio or NemaTalker.
官方主页:
http://www.sailsoft.nl/
软件注册展示:
软件注册机展示:
各提供二组授权码。能力范围之内建议多多支持正版。
