common.h文件怎样配置,一致在这个文件下报错,defined(CPU_KE06)这个是什么意思?提示错误:- ..\..\..\..\src\cpu\headers\MKE06Z4.h(118): error: #5: cannot open source input file "core_cm0plus.h": No such file or directory
core_cm0plus.h这个文件是cw环境下才有的,从官方库中把keil分离出来就报错找不到这个文件。
- #ifndef _COMMON_H_
- #define _COMMON_H_
- #define swap_bytes(ptrWord) *ptrWord = (*ptrWord >>8) | (*ptrWord<<8)
- typedef unsigned long dword;
- typedef unsigned short word;
- * Debug prints ON (#define) or OFF (#undef)
- #define DEBUG
- #define DEBUG_PRINT
- * Include the generic CPU header file
- #include "arm_cm0.h"
- * Include the platform specific header file
- #if (defined(FRDM_KE02))
- #include "ke02_config.h"
- #elif (defined(FRDM_KE04))
- #include "ke04_config.h"
- #elif (defined(FRDM_KE06))
- #include "ke06_config.h"
- #else
- #error "No valid board defined"
- #endif
- * Include the cpu specific header file
- #if (defined(CPU_KE02))
- #include "MKE02Z2.h"
- #elif (defined(CPU_KE04))
- #include "MKE04Z4.h"
- #elif (defined(CPU_KE06))
- #include "MKE06Z4.h"
- #else
- #error "No valid CPU defined"
- #endif
- * Include any toolchain specfic header files
- #if (defined(__MWERKS__))
- #include "mwerks.h"
- #elif (defined(__DCC__))
- #include "build/wrs/diab.h"
- #elif (defined(__ghs__))
- #include "build/ghs/ghs.h"
- #elif (defined(__GNUC__))
- #if (defined(IAR))
- #include "build/gnu/gnu.h"
- #endif
- #elif (defined(IAR))
- #include "iar.h"
- #elif (defined(KEIL))
- #else
- #warning "No toolchain specific header included"
- #endif
- * Include common utilities
- #include "assert.h"
- #include "io.h"
- #include "startup.h"
- #include "stdlib.h"
- #include "intrinsics.h"
- #endif
- #endif /* _COMMON_H_ */
