如题:
希望对大家有所帮助。
Preface
An embedded system is a device with a computer inside that doesn't look like a
computer. Washing machines, televisions, printers, cars, aircraft, and robots are all
controlled by a computer of some sort, and in some cases, more than one. As these
devices become more complex, and as our expectations of the things that we can do
with them expand, the need for a powerful operating system to control them grows.
Increasingly, Linux is the operating system of choice.
The power of Linux stems from its open source model, which encourages sharing
of code. This means that software engineers from many backgrounds, and often
employed by competing companies, can cooperate to create an operating system
kernel that is up-to-date and tracks the development of the hardware. From this one
code base, there is support from the largest super computers down to a wristwatch.
Linux is only one component of the operating system. Many other components are
needed to create a working system, from basic tools, such as a command shell, to
graphical user interfaces, with web content and communicating with cloud services.
The Linux kernel together with an extensive range of other open source components
allow you to build a system that can function in a wide range of roles.
However, flexibility is a double-edged sword. While it gives a system designer
a wide choice of solutions to a particular problem, it also presents the problem of
knowing which are the best choices. The propose of this book is to describe in detail
how to construct an embedded Linux system using free, open source projects to
produce a robust, reliable, and efficient system. It is based on the experience of the
author as a consultant and trainer over a period of many years, using examples to
illustrate best practices.
PS:这本书在amazon上面快要300RMB了... |
