#pragma access
#include "macrodriver.h"
#include "System.h"
/* Start user code for include definition. Do not edit comment generated here */
/* End user code for include definition. Do not edit comment generated here */
#include "user_define.h"
#pragma section @@DATA E000H
int a1;
int a2;
int a3;
void main( void )
/* Start user code. Do not edit comment generated here */
while (1)
/* End user code. Do not edit comment generated here */
程序
"C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\bin\cc78k0.exe" -cF054780 -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff main.c
main.c(8) : CC78K0 warning W0837: Output assembler source file , not object file
Compilation complete, 0 error(s) and 1 warning(s) found.
"C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\bin\cc78k0.exe" -cF054780 -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff systeminit.c
Compilation complete, 0 error(s) and 0 warning(s) found.
"C:\Program Files (x86)\NEC Electronics Tools\RA78K0\V4.01\bin\ra78k0.exe" -cF054780 -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff option.asm
Assembly complete, 0 error(s) and 0 warning(s) found.
"C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\bin\cc78k0.exe" -cF054780 -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff System.c
"C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\bin\cc78k0.exe" -cF054780 -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff System_user.c
"C:\Program Files (x86)\NEC Electronics Tools\RA78K0\V4.01\bin\lk78k0.exe" -y"C:\Program Files\NEC Electronics Tools\DEV" -_msgoff -oa.lmf "C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\lib78k0\s0l.rel" -go298 -pa.map -bcl0.lib -bcl0f.lib -i"C:\Program Files (x86)\NEC Electronics Tools\CC78K0\V4.00\lib78k0" -dlk.dr -s main.rel systeminit.rel option.rel System.rel System_user.rel
78K0 Linker V4.01 [ 2 Nov 2007]
Copyright(C) NEC Electronics Corporation 1990,2007
RA78K0 error F3006: File not found 'main.rel'
Program Aborted.
Build Total error(s) : 1 Total warning(s) : 1
报错 |
