发表于 2016-10-6 15:52:09
33.1 Unique device ID register (96 bits)
The unique device identifier is ideally suited:
for use as serial numbers (for example USB string serial numbers or other end applications)
for use as part of the security keys in order to increase the security of code in Flash
memory while using and combining this unique ID with software cryptographic
primitives and protocols before programming the internal Flash memory
to activate secure boot processes, etc.
The 96-bit unique device identifier provides a reference number which is unique for any device and in any context. These bits cannot be altered by the user.
Base address: 0x1FFF F7AC
这是F051数据手册上说的,F030上面更不找不到关于 UNIQUE ID 的相关信息,不过读取该地址还是可以读取到一些信息的,
我读取该地址的末尾字节都是0x20,难道F030是阉割的?只有88 bits? |
