前篇:基于FFT算法的LCR http://www.amobbs.com/thread-5590156-1-1.html
频率范围:1Hz~100kHz ( 0.01Hz step );
阻抗范围:10m~10M Ohm ( 1k ref only );
丢掉PSD和PGA,忘掉DFT、FFT和LMS算法吧,只需2个运放 + ADC/DAC,100k lcr meter带回家
核心算法类似soft define radio 中的数字下变频(数字IQ解调),更准确的定义是 DLIA(Digital Lock-in amplifier,数字锁定放大器);
其实就是将原来模拟器件完成的信号处理整个搬到了数字域,利用浮点运算能力 降低硬件复杂程度,
相对于PSD方法,动态范围更高,当信号转换到数字域后,就无需再考虑噪声和失调,动态范围超过100dB;
相对于FFT、LMS算法,16bit 4096point 已经算比较高了,而DLIA可以用浮点的 乘法器/CIC/FIR/IIR,DFT:Vi/Vq = 4095/0,DLIA: Vi/Vq = 4.0952341E3 / 1.234354E-2;
此外 n=4096 fs=100khz 的FFT 分辨率≈24hz,而DLIA 不存在限制 举个栗子:80,000.00 Hz ~ 80,001.00 Hz扫频,分辨率0.01Hz;
自己绕的变压器:
10nF 1kHz 1%建立时间:
更多图片
硬件相关:
标准(100k):
4 x OPA + 2 x ADC + 1 x DAC + MCU (> 80 DMIPS);
最低(20k):
2 x OPA + USB Audio Codec (such as PCM2904);
开发版(100k):
主控制器:STM32F411CE ( > 80 DMIPS), CNY 24
ADC/DAC:TLV320AIC3204 (TI audio codec), CNY 10
AFE:AD8065, 4 x CNY 4
DEBUGGER:CMSIS-DAP for STM32F072 with CDC / J-Link OB-STM32F072-CortexM, CNY 20
接口:USB VCP (via DEBUGGER) or 蓝牙串口 (Simple Shell, Data format: JSON)
Hardware:100k ZLCR.rev.c.pdf
Software:Firmware for stm32f4xx
软件相关:
Python / C# / Matlab / Windows UWP
通信格式:
- uart tx:
- zlcr -raw -f 1000\n
- uart rx:
- {"FREQ":1.000000e+03,"a":-2.304493e+03,"b":-5.388904e+03,"c":-2.319749e+03,"d":-5.420242e+03}\n
- {"FREQ":1.000000e+03,"a":-2.304510e+03,"b":-5.388904e+03,"c":-2.319749e+03,"d":-5.419875e+03}\n
- {"FREQ":1.000000e+03,"a":-2.304507e+03,"b":-5.388909e+03,"c":-2.319749e+03,"d":-5.421182e+03}\n
- {"FREQ":1.000000e+03,"a":-2.304502e+03,"b":-5.388918e+03,"c":-2.319749e+03,"d":-5.423528e+03}\n
- uart tx:
- zlcr -f 1000\n
- uart rx:
- {"FREQ":1.000000e+03,"MAG":9.937274e-01,"PHASE":-1.291339e-04}\n
- {"FREQ":1.000000e+03,"MAG":9.940118e-01,"PHASE":-2.515127e-04}\n
- {"FREQ":1.000000e+03,"MAG":9.941343e-01,"PHASE":-3.042429e-04}\n
- {"FREQ":1.000000e+03,"MAG":9.939352e-01,"PHASE":-2.185376e-04}\n
扩展(up to 20M):
运放构成的auto-balancing bridge并不适合100k以上的测试频率,所以设计了数字桥路平衡控制系统,产生两个激励信号(2 x AD9834) ,通过检测不平衡电压/电流(HPF + 40dB AMP + DLIA),由控制算法调整激励信号幅度和相位,使桥路趋近平衡;同时利用ADC + DLIA 检测V(DUT) & I(DUT),计算复阻抗,测量结果在桥路达到平衡后误差最小;
ADC采样率和计算量增大的问题,解决方案是欠采样(中频采样)。大学时候做过STM32F4欠采样第20奈奎斯特区 观察到明显的孔径抖动 SNR会降低,再往上bandwidth就不够了。对于V(DUT) I(DUT)这种窄带信号,欠采样 + PSD/DLIA 是性能和成本的平衡;
对于ΣΔADC,设计了简单的采样保持器 ( 4 x TS5A3159A 未验证);
此外AD9834不能控制幅度,设计通过PWM(AF OD mode)调整 I(FSADJSET) 进行幅度控制,相位利用抖动实现16bit;
最后,发个还未验证的版本 20M ZLCR.rev.a.pdf
ref:
Keysight Technologies Impedance Measurement Handbook
抛砖引玉 基于DSP的LCR表试制 供大家参考
MT-002: 奈奎斯特准则对数据采样系统设计有何意义
MS-2698:使用同步检测进行精密低电平测量
基于DLIA的交流阻抗谱测量系统关键技术研究
