μC/Probe 4.1.17.0
具体的详细信息我就不介绍了, 以前帖子里面介绍过。
以前的帖子:
1)μC/Probe 4.0.16.10:http://www.amobbs.com/thread-5653233-1-1.html
2)μC/Probe 4.0.16.4:http://www.amobbs.com/thread-5647708-1-1.html
3)μC/Probe 4.0.16.1:http://www.amobbs.com/thread-5647390-1-1.html
4)μC/Probe 3.6.15.700:http://www.amobbs.com/thread-5636836-1-1.html
1、uC/Probe 4.1.17.0 更新说明:
µC/Probe 4.1: a minor release with a brand new ELF parser and Symbol Browser.
The release of µC/Probe Version 4.1, brings a new ELF parser capable of parsing larger ELF files and C++ class members. The new ELF parser is tied to a redesigned Symbol Browser that allows you to associate virtual controls and indicators to embedded target symbols that in previous versions of µC/Probe were not available:
>>Bit Fields (supported by all controls)
>>Full Array (only supported by the Tree Control and the Spreadsheet Control)
>>Element of an Array (supported by all controls)
>>Full Structure (only supported by the Tree Control and the Spreadsheet Control)
>>Member of a Structure (supported by all controls)
>>Mix of all of the above
>>Pointers to all of the above
>>C++ Class Members (supported by all controls)
Furthermore, with the new release of µC/Probe 4.1, Micriµm continues the expansion of its extensive partner ecosystem through the integration of two new communication interfaces:
>>ARM Keil µVision
>>Analog Devices Cross Core Embedded Studio
The new communication interfaces bring µC/Probe to all those embedded targets supported by the aforementioned IDEs. The best part is that these new communication interfaces do not require any special target resident code and they work without the intervention of the embedded target's CPU.
Other improvements in this software update include:
>>New Memory Window Control
Added linear and logarithmic scales to some of the controls (i.e. gauges and charts)
>>Oscilloscope Control Improvements:
>>Export the captured traces as a CSV file
>>Export the captured traces as a PNG file
>>Autofit traces to view
>>Delta Time measurement
>>Delta Amplitude measurement
>>Average measurement (within cursors ∆T)
>>RMS measurement (within cursors ∆T)
>>Min/Max measurement
The µC/Probe 4.1 software update is fully compatible with older workspaces and is completely free for evaluation and for existing users with a valid license.
2、µC/Probe Windows Installer
安装程序:
和谐文件:
和谐方法:
1)安装软件
2)将下载的和谐文件解压后,覆盖安装目录下的同名文件。
3、µC/Probe Embedded Target Code (optional)
4、µC/Probe Embedded Target Code Manual
最后说明一下:
1)和谐软件仅限大家学习和研究使用,如果商用请购买正版软件,因此产生的版权纠纷与本人无关。
2)为了后续大家能继续“研究和学习”新版软件,请大家低调使用,勿大范围扩散,更谢绝转至其他论坛,否则后面新版本和谐不了了大家都没得玩了。
