安装包比较大,请自行到autodesk网站下载
http://www.autodesk.com/products/eagle/overview
从7.x到8.0的升级
最主要的功能更新时增加了一个Design Blocks功能,可以把经常使用的sch/pcb保存成一个dbl模块,使用时直接paste。
8.0以前的版本,虽然电路图可以拷贝粘贴,但是pcb布线没法同步粘贴过来,还是要重新布线,有这个design block就省事了。
还有些小的功能更新也很实用,可以设置鼠标自动group,不用每次选择元件点group按钮了。新的slice命令也很实用。
Release notes for EAGLE 8.0.1
* Editions:
- The Standard Edition of EAGLE now supports four signal layers instead
of two.
* MITER command:
- When interactively mitering a corner, the miter edge now closely
follows the mouse cursor location.
* Miscellaneous:
- Added example for BGA Autorouter.
- Proxy servers are now supported (mirrors system proxy settings).
- Check for internet connection will now timeout after 10s.
* Bugfixes:
- Fixed running ULPs and loading drawings under specific LANG or
LC_NUMERIC environments.
- EAGLE for Mac now stores drawing files not inside a project correctly in the
EAGLE install directory and avoids permission errors.
- Repainting errors when routing after moving objects are fixed.
- Only when group is not empty the Delete key kicks off DELETE operations.
- Fixed Mac installer background image cutoff
- Mac installer now updates Launchpad shortcuts correctly.
- Printing now works correctly on linux.
- Fixed a bug regarding leaking UDP sockets on linux to avoid 'Too many
files open' error message.
- Avoid BGA Autorouter crash on Mac and sporadically on Linux/Windows with
particular example files.
- Fixed as an issue that would un-use all libraries when opening a project
without any project-specific libraries.
- Using the spacebar while actively routing will now skip over signal layers that
have been disabled (not displayed) through the Layer Settings.
Release notes for EAGLE 8.0.0
* Platforms:
- EAGLE for Windows, Linux, and Mac is available as 64 bit package.
32 bit is no longer supported.
* Licensing:
- Licensing now changed to subscription.
* Editions:
- EAGLE is available as a full package containing the modules Schematic Editor,
Layout Editor, and Autorouter in Free, Standard and Premium Edition.
* Design Blocks:
- A Design Block is intended to represent a kind of designed module consisting
of a schematic and its consistent layout which can be easily reused in EAGLE.
Design Blocks are imported with the PASTE DBL command.
It?s possible to select objects in schematic and board which are consistent
and save them as a Design Block.
* Autorouter:
- The Autorouter offers a new option (command AUTO BGA) to automatically route
a BGA fanout. It supports micro vias, if enabled. The user decides about the
signals to be routed and about the layers the signals should be routed in.
* LINE command:
- LINE replaces the WIRE command. For compatibility reasons WIRE is supported
furthermore.
* NET command:
- When drawing a net in the schematic and approaching a pin the net wire
automatically snaps into the pin's connection point.
* ROUTE command:
- The ROUTE command starts at any object (pad, via, smd, line) without having
to press the Ctrl key.
- Each wire segment that has been fixed in the current routing process can be
undone step by step with the Backspace key.
- Approaching a routing target an electrical snap indicator is shown within
the given Snap Length.
- A via is immediately displayed as soon as the routing layer is changed. The
following mouse click fixes the via and the wire segment in the new routing
layer.
- Loop Removal: If an already fixed trace is rerouted, the redundant wire path
will be removed automatically.
- Additionally to the middle mouse click, the Space key changes the routing layer
to the next available routing layer.
* SLICE command:
- The new SLICE command cut lines in two with a gap specified by the current
line width. Schematic wires that are sliced become separate nets, similar to
deleting a middle wire segment of the net. In board, the traces maintain their
connectivity. The gap is bridged with an airwire; similar to the RIPUP of a
wire segment.
* WIRE command:
- The WIRE command has been renamed to LINE. For compatibility reasons WIRE may
still be used, e.g. in scripts or User Language programs. |
