回复: 22
NPN输出驱动感性负载,负载不并联续流二极管,改用TVS到地
出20入128汤圆
发表于 2017-2-24 18:34:55 | 显示全部楼层 |阅读模式
NPN输出驱动感性负载,负载不并联续流二极管,改用在输出管脚,并联一个TVS到地,是否可以,如下图所示的某PLC示意图所示:
个人认为续流二极管,也是把管脚的高电压导通到VCC,然后由VCC下的各个负载分摊掉,本质是“导向+消耗”;
而此处采用TVS,直接就在管脚处对地“消耗”,保护了引脚,个人认为是可行的,不知道是否正确;请知道的大神说说看,谢谢!
出0入442汤圆
发表于 2017-2-24 18:39:53 来自手机 | 显示全部楼层
谁告诉你那是tvs了?画法不一致而已。
出20入128汤圆
 楼主| 发表于 2017-2-24 18:44:42 | 显示全部楼层
wye11083 发表于 2017-2-24 18:39
谁告诉你那是tvs了?画法不一致而已。
如果那个是续流二极管,好像不是接在CE间的吧?而是要并联在负载两端的
出20入128汤圆
 楼主| 发表于 2017-2-24 18:50:41 | 显示全部楼层
平时常见的,是这样反向并联在负载两端的续流二极管
发表于 2017-2-24 20:35:50 | 显示全部楼层
TVS击穿里,电阻低,负载会继续通电,危险
出75入90汤圆
发表于 2017-2-24 21:06:40 | 显示全部楼层
NUD3112This device is used to switch inductive loads such as relays,
solenoids incandescent lamps, and small DC motors without the need
of a free−wheeling diode. The device integrates all necessary items
such as the MOSFET switch, ESD protection, and Zener clamps. It
accepts logic level inputs thus allowing it to be driven by a large
variety of devices including logic gates, inverters, and
microcontrollers.
Features
• Provides a Robust Driver Interface Between D.C. Relay Coil and
Sensitive Logic Circuits
• Optimized to Switch Relays of 12 V Rail
• Capable of Driving Relay Coils Rated up to 6.0 W at 12 V
• Internal Zener Eliminates the Need of Free−Wheeling Diode
• Internal Zener Clamp Routes Induced Current to Ground for Quieter
Systems Operation
• Low VDS(ON) Reduces System Current Drain
• Pb−Free Package is Available
Typical Applications
• Telecom: Line Cards, Modems, Answering Machines, FAX
• Computers and Office: Photocopiers, Printers, Desktop Computers
• Consumer: TVs and VCRs, Stereo Receivers, CD Players, Cassette
Recorders
• Industrial: Small Appliances, Security Systems, Automated Test
Equipment, Garage Door Openers
发表于 2017-2-24 21:26:09 来自手机 | 显示全部楼层
应该是稳压二极管
发表于 2017-2-24 22:14:52 | 显示全部楼层
TVS击穿后,是导通的,导通的,导通的。说三遍
出20入128汤圆
 楼主| 发表于 2017-2-24 22:23:05 | 显示全部楼层
solenoids incandescent lamps, a ...
老大推荐的智能器件不错,不过功率比较小,我现在需要用到的场合是24V,2A的场合,路数30几路,布续流二极管的PCB都好烦,所以想省下续流,改成输出对地接TVS的方案
出20入128汤圆
 楼主| 发表于 2017-2-24 22:27:00 | 显示全部楼层
对于过高的电压,是导通,不过还是会有电压钳位的吧?也是是将过高的反向电动势,消耗至TVS管的电压钳位值,等过高的反向电动势消耗了,恢复至正常电压,此时TVS是不导通的
出20入128汤圆
 楼主| 发表于 2017-2-24 22:27:50 | 显示全部楼层
xiaobendan 发表于 2017-2-24 21:26
应该是稳压二极管
稳压管用在这里,是不行的吧。。。。稳压管,必须搭配限流电阻使用,不然它自己就先挂了
发表于 2017-2-25 01:32:37 来自手机 | 显示全部楼层
应该是快恢复二极管,保护三极管不被反向击穿
发表于 2017-2-25 07:27:03 | 显示全部楼层
z123 发表于 2017-2-24 22:27
稳压管用在这里,是不行的吧。。。。稳压管,必须搭配限流电阻使用,不然它自己就先挂了 ...
你哪里看到他直接接电源了?
你的这个接近开关,输出端不是接负载是接电源吗?
我也没说这个稳压管的电压值是低于24V的啊
发表于 2017-2-25 07:28:14 | 显示全部楼层
你一楼的图纸上面可是有画负载的,你打算不接负载直接接电源?可是有啥用?三极管也会烧掉的吧
出20入128汤圆
 楼主| 发表于 2017-2-25 11:19:03 | 显示全部楼层
这个应该不对的,类似MOS管自带有寄生二极管,不外接续流的话,一样坏的
出20入128汤圆
 楼主| 发表于 2017-2-25 11:22:24 | 显示全部楼层
xiaobendan 发表于 2017-2-25 07:27
你哪里看到他直接接电源了?
我也没说这个稳压管的电压 ...
哦,是我说的不大清楚~~
对于关断时产生的反向感应电动势来说,那个稳压管就是直接接在这个电压上的,功率可能不太够~~~这种情况下,好像是TVS管,来的符合些
发表于 2017-2-25 11:58:41 | 显示全部楼层
明确的说可以,TVS等效于稳压管,只是速度更快
还有一种接法是将输出和24V电源端串二极管,输出->24+-》24-  -》 5v- ->5V+ ->负载
发表于 2017-2-25 12:01:03 | 显示全部楼层
第二种方法如果输出电源带二极管防逆流 那么就无效了
发表于 2017-2-25 13:14:54 | 显示全部楼层
z123 发表于 2017-2-25 11:22
哦,是我说的不大清楚~~
对于关断时产生的反向感应电动势来说,那个稳压管就是直接接在这个电压上的,功 ...
反电势的时间功率有多少?
发表于 2017-2-25 13:50:31 | 显示全部楼层
就是个稳压二极管吧
出20入128汤圆
 楼主| 发表于 2017-2-25 17:43:27 | 显示全部楼层
还有一种接法是将输出和24V电源端串二极管,输出->24+-》2 ...
老大可以说的更详细些么?看不太明白,谢谢!
出20入128汤圆
 楼主| 发表于 2017-2-25 17:45:10 | 显示全部楼层
xiaobendan 发表于 2017-2-25 13:14
反电势的时间功率有多少?
好吧,对于稳压管,总觉得功率小,不够~~~
对于此处能用稳压管,肯定更可以用TVS管了吧~~
出20入128汤圆
 楼主| 发表于 2017-2-25 17:48:11 | 显示全部楼层
NFotxb 发表于 2017-2-25 13:50
就是个稳压二极管吧
这个符号,可以是稳压管,也可以是TVS管,不过用在此处,都是起到电压钳位作用
不过个人觉得TVS管功率更大,能承受更大的电流吧?稳压管,都是弱不经风的样子。。。。。
比如对于负载为24/5A这样的线圈来说
GMT+8, 2024-3-29 13:45
