发表于 2018-8-13 15:33:36
我用的是原来3.14配套的文件系统,整个过程就改变了内核,其它的都没变。
我把飞凌3.14内核打印日志也贴出来
- U-Boot 2015.04-g3989e3c (Dec 14 2017 - 19:04:37)
- CPU: Freescale i.MX6UL rev1.1 at 396 MHz
- CPU: Temperature 42 C
- Reset cause: POR
- Board: MX6UL 14x14 EVK
- I2C: ready
- DRAM: 256 MiB
- NAND: 256 MiB
- MMC: FSL_SDHC: 0
- *** Warning - bad CRC, using default environment
- Display: TFT70AB (800x480)
- Video: 800x480x24
- NAND read: device 0 offset 0x400000, size 0x80000
- 524288 bytes read: OK
- display bmp cfb_console.c
- In: serial
- Out: serial
- Err: serial
- Net: FEC0
- Error: FEC0 address not set.
- Normal Boot
- Hit any key to stop autoboot: 0
- nand boot..........
- NAND read: device 0 offset 0xa00000, size 0x800000
- 8388608 bytes read: OK
- NAND read: device 0 offset 0x700000, size 0x40000
- 262144 bytes read: OK
- Kernel image @ 0x80800000 [ 0x000000 - 0x622460 ]
- ## Flattened Device Tree blob at 83000000
- Booting using the fdt blob at 0x83000000
- Using Device Tree in place at 83000000, end 8300c7c5
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0x0
- [ 0.000000] Linux version 3.14.38-6UL_ga (yhh@Ding) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Wed Aug 8 08:26:13 CST 2018
- [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
- [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
- [ 0.000000] cma: CMA: reserved 64 MiB at 8c000000
- [ 0.000000] Memory policy: Data cache writealloc
- [ 0.000000] PERCPU: Embedded 8 pages/cpu @8bdbf000 s8832 r8192 d15744 u32768
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60928
- [ 0.000000] Kernel command line: console=ttymxc0,115200 cma=64M root=/dev/mtdblock5 rootfstype=yaffs2,calibrate=y
- [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
- [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
- [ 0.000000] Memory: 165640K/245760K available (7922K kernel code, 481K rwdata, 2788K rodata, 396K init, 433K bss, 80120K reserved, 0K highmem)
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- [ 0.000000] vmalloc : 0x90800000 - 0xff000000 (1768 MB)
- [ 0.000000] lowmem : 0x80000000 - 0x90000000 ( 256 MB)
- [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
- [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
- [ 0.000000] .text : 0x80008000 - 0x80a7dcf8 (10712 kB)
- [ 0.000000] .init : 0x80a7e000 - 0x80ae1280 ( 397 kB)
- [ 0.000000] .data : 0x80ae2000 - 0x80b5a760 ( 482 kB)
- [ 0.000000] .bss : 0x80b5a76c - 0x80bc6cf4 ( 434 kB)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
- [ 0.000000] Preemptible hierarchical RCU implementation.
- [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
- [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
- [ 0.000000] NR_IRQS:16 nr_irqs:16 16
- [ 0.000000] Switching to timer-based delay loop
- [ 0.000021] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
- [ 0.002768] clocksource_of_init: no matching clocksources found
- [ 0.003135] Console: colour dummy device 80x30
- [ 0.003183] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
- [ 0.003216] pid_max: default: 32768 minimum: 301
- [ 0.003606] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.003637] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.005174] Initializing cgroup subsys net_cls
- [ 0.005262] CPU: Testing write buffer coherency: ok
- [ 0.005759] /cpus/cpu@0 missing clock-frequency property
- [ 0.005801] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
- [ 0.005861] Setting up static identity map for 0x807855f8 - 0x80785650
- [ 0.040763] Brought up 1 CPUs
- [ 0.040799] SMP: Total of 1 processors activated (6.00 BogoMIPS).
- [ 0.040815] CPU: All CPU(s) started in SVC mode.
- [ 0.042118] devtmpfs: initialized
- [ 0.052537] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- [ 0.053316] pinctrl core: initialized pinctrl subsystem
- [ 0.054257] regulator-dummy: no parameters
- [ 0.059566] NET: Registered protocol family 16
- [ 0.076192] DMA: preallocated 256 KiB pool for atomic coherent allocations
- [ 0.077798] cpuidle: using governor ladder
- [ 0.077830] cpuidle: using governor menu
- [ 0.078198] Use WDOG1 as reset source
- [ 0.096549] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
- [ 0.097256] vdd3p0: 2625 <--> 3400 mV at 3000 mV
- [ 0.098129] cpu: 725 <--> 1450 mV at 1150 mV
- [ 0.098968] vddsoc: 725 <--> 1450 mV at 1175 mV
- [ 0.104224] syscon 20e4000.iomuxc-gpr: regmap [mem 0x020e4000-0x020e7fff] registered
- [ 0.111011] syscon 21ac000.romcp: regmap [mem 0x021ac000-0x021affff] registered
- [ 0.112553] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
- [ 0.119730] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
- [ 0.119761] hw-breakpoint: maximum watchpoint size is 8 bytes.
- [ 0.123846] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
- [ 0.126846] 20dc000.gpc supply pu not found, using dummy regulator
- [ 0.162015] bio: create slab <bio-0> at 0
- [ 0.168610] mxs-dma 1804000.dma-apbh: initialized
- [ 0.169570] can-3v3: 3300 mV
- [ 0.170121] VSD_3V3: 3300 mV
- [ 0.170913] usb_otg1_vbus: 5000 mV
- [ 0.171467] vref-3v3: 3300 mV
- [ 0.172989] gpio_dvfs: 1300 <--> 1400 mV at 1400 mV
- [ 0.174283] i2c-core: driver [max17135] using legacy suspend method
- [ 0.174308] i2c-core: driver [max17135] using legacy resume method
- [ 0.175533] SCSI subsystem initialized
- [ 0.176781] usbcore: registered new interface driver usbfs
- [ 0.176970] usbcore: registered new interface driver hub
- [ 0.177303] usbcore: registered new device driver usb
- [ 0.183089] i2c i2c-0: IMX I2C adapter registered
- [ 0.185559] i2c i2c-1: IMX I2C adapter registered
- [ 0.185857] Linux video capture interface: v2.00
- [ 0.186062] pps_core: LinuxPPS API ver. 1 registered
- [ 0.186083] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- [ 0.186145] PTP clock support registered
- [ 0.188729] MIPI CSI2 driver module loaded
- [ 0.189288] Advanced Linux Sound Architecture Driver Initialized.
- [ 0.191260] Bluetooth: Core ver 2.18
- [ 0.191397] NET: Registered protocol family 31
- [ 0.191419] Bluetooth: HCI device and connection manager initialized
- [ 0.191460] Bluetooth: HCI socket layer initialized
- [ 0.191493] Bluetooth: L2CAP socket layer initialized
- [ 0.191604] Bluetooth: SCO socket layer initialized
- [ 0.193592] Switched to clocksource mxc_timer1
- [ 0.195195] cfg80211: Calling CRDA to update world regulatory domain
- [ 0.219214] NET: Registered protocol family 2
- [ 0.221212] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.221306] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
- [ 0.221397] TCP: Hash tables configured (established 2048 bind 2048)
- [ 0.221515] TCP: reno registered
- [ 0.221550] UDP hash table entries: 256 (order: 1, 8192 bytes)
- [ 0.221611] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
- [ 0.222179] NET: Registered protocol family 1
- [ 0.222931] RPC: Registered named UNIX socket transport module.
- [ 0.222962] RPC: Registered udp transport module.
- [ 0.222979] RPC: Registered tcp transport module.
- [ 0.222995] RPC: Registered tcp NFSv4.1 backchannel transport module.
- [ 0.225882] imx rpmsg driver is registered.
- [ 0.227498] Bus freq driver module loaded
- [ 0.229484] futex hash table entries: 256 (order: 2, 16384 bytes)
- [ 0.249116] VFS: Disk quotas dquot_6.5.2
- [ 0.249815] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
- [ 0.255885] NFS: Registering the id_resolver key type
- [ 0.255994] Key type id_resolver registered
- [ 0.256015] Key type id_legacy registered
- [ 0.256102] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- [ 0.257964] fuse init (API version 7.22)
- [ 0.259236] msgmni has been set to 451
- [ 0.267547] io scheduler noop registered
- [ 0.267579] io scheduler deadline registered
- [ 0.268081] io scheduler cfq registered (default)
- [ 0.269121] imx-weim 21b8000.weim: Driver registered.
- [ 0.274965] backlight.9 supply power not found, using dummy regulator
- [ 0.278097] MIPI DSI driver module loaded
- [ 0.282421] 21c8000.lcdif supply lcd not found, using dummy regulator
- [ 0.282821] mxsfb 21c8000.lcdif: failed to find mxc display driver
- [ 0.283757] mxsfb 21c8000.lcdif: initialized
- [ 0.290944] imx-sdma 20ec000.sdma: no event needs to be remapped
- [ 0.291153] imx-sdma 20ec000.sdma: loaded firmware 3.1
- [ 0.299701] imx-sdma 20ec000.sdma: initialized
- [ 0.301195] Serial: IMX driver
- [ 0.301843] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
- [ 1.042118] console [ttymxc0] enabled
- [ 1.047639] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
- [ 1.057538] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60, base_baud = 5000000) is a IMX
- [ 1.067183] serial: Freescale lpuart driver
- [ 1.075406] imx sema4 driver is registered.
- [ 1.079772] [drm] Initialized drm 1.1.0 20060810
- [ 1.085575] [drm] Initialized vivante 1.0.0 20120216 on minor 0
- [ 1.113177] brd: module loaded
- [ 1.128056] loop: module loaded
- [ 1.134913] spi_gpio spi4.15: gpio-miso property not found, switching to no-rx mode
- [ 1.147150] CAN device driver interface
- [ 1.154505] flexcan 2090000.can: device registered (reg_base=90968000, irq=142)
- [ 1.164706] flexcan 2094000.can: device registered (reg_base=90970000, irq=143)
- [ 1.174275] 20b4000.ethernet supply phy not found, using dummy regulator
- [ 1.182305] pps pps0: new PPS source ptp0
- [ 1.186912] fec 20b4000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
- [ 1.196106] fec 20b4000.ethernet (unregistered net_device): Using random MAC address: 02:82:48:42:41:90
- [ 1.206259] libphy: fec_enet_mii_bus: probed
- [ 1.214403] fec 20b4000.ethernet eth0: registered PHC device 0
- [ 1.221885] 2188000.ethernet supply phy not found, using dummy regulator
- [ 1.229998] pps pps1: new PPS source ptp1
- [ 1.234581] fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
- [ 1.243787] fec 2188000.ethernet (unregistered net_device): Using random MAC address: fa:35:e9:bc:4f:47
- [ 1.255253] fec 2188000.ethernet eth1: registered PHC device 1
- [ 1.262730] PPP generic driver version 2.4.2
- [ 1.267723] PPP BSD Compression module registered
- [ 1.272471] PPP Deflate Compression module registered
- [ 1.277842] usbcore: registered new interface driver asix
- [ 1.283397] usbcore: registered new interface driver cdc_ether
- [ 1.289438] usbcore: registered new interface driver cdc_eem
- [ 1.295386] usbcore: registered new interface driver cdc_ncm
- [ 1.301080] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 1.307676] ehci-mxc: Freescale On-Chip EHCI Host driver
- [ 1.313453] usbcore: registered new interface driver usb-storage
- [ 1.319869] usbcore: registered new interface driver usbserial
- [ 1.325930] usbcore: registered new interface driver usbserial_generic
- [ 1.332591] usbserial: USB Serial support registered for generic
- [ 1.338791] usbcore: registered new interface driver ftdi_sio
- [ 1.344709] usbserial: USB Serial support registered for FTDI USB Serial Device
- [ 1.352162] usbcore: registered new interface driver option
- [ 1.357909] usbserial: USB Serial support registered for GSM modem (1-port)
- [ 1.365038] usbcore: registered new interface driver pl2303
- [ 1.370731] usbserial: USB Serial support registered for pl2303
- [ 1.376872] usbcore: registered new interface driver cdc_xr_usb_serial
- [ 1.383430] xr_usb_serial_common: Exar USB UART (serial port) driver
- [ 1.389971] usbcore: registered new interface driver usb_ehset_test
- [ 1.398597] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
- [ 1.413559] 2184200.usb supply vbus not found, using dummy regulator
- [ 1.423913] ci_hdrc ci_hdrc.1: EHCI Host Controller
- [ 1.428899] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
- [ 1.453690] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
- [ 1.461158] hub 1-0:1.0: USB hub found
- [ 1.465139] hub 1-0:1.0: 1 port detected
- [ 1.471330] mousedev: PS/2 mouse device common for all mice
- [ 1.479058] input: 20cc000.snvs-pwrkey as /devices/soc0/soc.0/2000000.aips-bus/20cc000.snvs-pwrkey/input/input0
- [ 1.489946] snvs_pwrkey 20cc000.snvs-pwrkey: i.MX snvs powerkey probed
- [ 1.497478] edt_ft5x06 0-0038: touchscreen probe failed
- [ 1.502776] edt_ft5x06: probe of 0-0038 failed with error -5
- [ 1.510661] input: iMX6UL TouchScreen Controller as /devices/virtual/input/input2
- [ 1.520243] <<-GTP-INFO->> GTP driver installing...
- [ 1.525672] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
- [ 1.531633] <<-GTP-INFO->> GTP Driver Built@19:48:53, Aug 7 2018
- [ 1.537860] <<-GTP-INFO->> GTP I2C Address: 0x14
- [ 1.543620] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.550523] <<-GTP-ERROR->> GTP i2c test failed time 1.
- [ 1.574687] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.581588] <<-GTP-ERROR->> GTP i2c test failed time 2.
- [ 1.604700] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.611599] <<-GTP-ERROR->> GTP i2c test failed time 3.
- [ 1.634673] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.641570] <<-GTP-ERROR->> GTP i2c test failed time 4.
- [ 1.664884] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.671785] <<-GTP-ERROR->> GTP i2c test failed time 5.
- [ 1.693626] <<-GTP-ERROR->> I2C read failed.
- [ 1.698076] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
- [ 1.704074] <<-GTP-INFO->> GTP Driver Built@19:48:53, Aug 7 2018
- [ 1.710194] <<-GTP-INFO->> GTP I2C Address: 0x5d
- [ 1.715879] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.722818] <<-GTP-ERROR->> GTP i2c test failed time 1.
- [ 1.744724] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.751627] <<-GTP-ERROR->> GTP i2c test failed time 2.
- [ 1.774622] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.781521] <<-GTP-ERROR->> GTP i2c test failed time 3.
- [ 1.786907] usb 1-1: new high-speed USB device number 2 using ci_hdrc
- [ 1.804658] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.811559] <<-GTP-ERROR->> GTP i2c test failed time 4.
- [ 1.834675] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -5!
- [ 1.841574] <<-GTP-ERROR->> GTP i2c test failed time 5.
- [ 1.863614] <<-GTP-ERROR->> I2C read failed.
- [ 1.868315] i2c-core: driver [isl29023] using legacy suspend method
- [ 1.874661] i2c-core: driver [isl29023] using legacy resume method
- [ 1.884554] rtc-rx8010 0-0032: Frequency stop was detected, probably due to a supply voltage drop
- [ 1.893469] rtc-rx8010 0-0032: Update timer was detected
- [ 1.899801] rtc-rx8010 0-0032: bad conditions detected, resetting date
- [ 1.911333] rtc-rx8010 0-0032: rtc core: registered rx8010 as rtc0
- [ 1.919346] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
- [ 1.928121] i2c /dev entries driver
- [ 1.932930] IR NEC protocol handler initialized
- [ 1.937591] IR RC5(x) protocol handler initialized
- [ 1.942410] IR RC6 protocol handler initialized
- [ 1.947106] IR JVC protocol handler initialized
- [ 1.951825] IR Sony protocol handler initialized
- [ 1.956630] IR RC5 (streamzap) protocol handler initialized
- [ 1.963353] IR SANYO protocol handler initialized
- [ 1.968743] hub 1-1:1.0: USB hub found
- [ 1.972643] IR MCE Keyboard/mouse protocol handler initialized
- [ 1.978648] hub 1-1:1.0: 4 ports detected
- [ 1.987176] pxp-v4l2 pxp_v4l2.10: initialized
- [ 1.992010] usbcore: registered new interface driver uvcvideo
- [ 1.997974] USB Video Class driver (1.1.1)
- [ 2.004064] i2c-core: driver [mag3110] using legacy suspend method
- [ 2.010320] i2c-core: driver [mag3110] using legacy resume method
- [ 2.017616] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
- [ 2.026251] Bluetooth: HCI UART driver ver 2.2
- [ 2.030763] Bluetooth: HCI H4 protocol initialized
- [ 2.035628] Bluetooth: HCI BCSP protocol initialized
- [ 2.040616] Bluetooth: HCIATH3K protocol initialized
- [ 2.045949] usbcore: registered new interface driver bcm203x
- [ 2.051825] usbcore: registered new interface driver btusb
- [ 2.057621] usbcore: registered new interface driver ath3k
- [ 2.063314] usbcore: registered new interface driver rtk_btusb
- [ 2.069815] sdhci: Secure Digital Host Controller Interface driver
- [ 2.076080] sdhci: Copyright(c) Pierre Ossman
- [ 2.080463] sdhci-pltfm: SDHCI platform and OF driver helper
- [ 2.089706] mmc0: no vqmmc regulator found
- [ 2.133670] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
- [ 2.188520] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
- [ 2.195001] nand: Micron MT29F2G08ABAEAWP
- [ 2.199043] nand: 256MiB, SLC, page size: 2048, OOB size: 64
- [ 2.205477] gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
- [ 2.212486] Scanning device for bad blocks
- [ 2.523134] 6 ofpart partitions found on MTD device gpmi-nand
- [ 2.528960] Creating 6 MTD partitions on "gpmi-nand":
- [ 2.534081] 0x000000000000-0x000000400000 : "boot"
- [ 2.541587] 0x000000400000-0x000000600000 : "logo"
- [ 2.549052] 0x000000600000-0x000000700000 : "ENV"
- [ 2.556423] 0x000000700000-0x000000a00000 : "DTB"
- [ 2.563966] 0x000000a00000-0x000001200000 : "kernel"
- [ 2.571615] 0x000001200000-0x000010000000 : "rootfs"
- [ 2.579639] gpmi-nand 1806000.gpmi-nand: driver registered.
- [ 2.589705] usbcore: registered new interface driver usbhid
- [ 2.595412] usbhid: USB HID core driver
- [ 2.612824] fsl-asrc 2034000.asrc: driver registered
- [ 2.627249] snd-soc-dummy snd-soc-dummy: ASoC: Failed to create platform debugfs directory
- [ 2.636736] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
- [ 2.645034] imx-wm8960 sound.14: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
- [ 2.652493] imx-wm8960 sound.14: wm8960-hifi <-> 202c000.sai mapping ok
- [ 2.669988] NET: Registered protocol family 26
- [ 2.674590] Netfilter messages via NETLINK v0.30.
- [ 2.679373] nfnl_acct: registering with nfnetlink.
- [ 2.684363] nf_conntrack version 0.5.0 (3612 buckets, 14448 max)
- [ 2.691625] ctnetlink v0.93: registering with nfnetlink.
- [ 2.697375] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
- [ 2.704012] nf_tables_compat: (c) 2012 Pablo Neira Ayuso <pablo@netfilter.org>
- [ 2.711734] xt_time: kernel timezone is -0000
- [ 2.716870] ip_tables: (C) 2000-2006 Netfilter Core Team
- [ 2.722643] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
- [ 2.729227] arp_tables: (C) 2002 David S. Miller
- [ 2.734181] TCP: cubic registered
- [ 2.738805] NET: Registered protocol family 10
- [ 2.745596] sit: IPv6 over IPv4 tunneling driver
- [ 2.751811] NET: Registered protocol family 17
- [ 2.756521] can: controller area network core (rev 20120528 abi 9)
- [ 2.762901] NET: Registered protocol family 29
- [ 2.767560] can: raw protocol (rev 20120528)
- [ 2.771863] can: broadcast manager protocol (rev 20120528 t)
- [ 2.777673] can: netlink gateway (rev 20130117) max_hops=1
- [ 2.783885] Bluetooth: RFCOMM TTY layer initialized
- [ 2.788843] Bluetooth: RFCOMM socket layer initialized
- [ 2.794220] Bluetooth: RFCOMM ver 1.11
- [ 2.798024] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
- [ 2.803361] Bluetooth: BNEP filters: protocol multicast
- [ 2.808688] Bluetooth: BNEP socket layer initialized
- [ 2.813719] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- [ 2.819689] Bluetooth: HIDP socket layer initialized
- [ 2.824830] 8021q: 802.1Q VLAN Support v1.8
- [ 2.829187] Key type dns_resolver registered
- [ 2.835138] cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
- [ 2.857809] gpio_dvfs: disabling
- [ 2.861085] vref-3v3: disabling
- [ 2.864372] usb_otg1_vbus: disabling
- [ 2.867975] VSD_3V3: disabling
- [ 2.871051] can-3v3: disabling
- [ 2.874697] regulator-dummy: disabling
- [ 2.878949] imx mcc test is registered.
- [ 2.884825] rtc-rx8010 0-0032: setting system clock to 1970-01-01 00:00:00 UTC (0)
- [ 2.911266] ALSA device list:
- [ 2.914366] #0: wm8960-audio
- [ 2.918378] yaffs: dev is 32505861 name is "mtdblock5" ro
- [ 2.923997] yaffs: passed flags ""
- [ 3.001622] random: nonblocking pool is initialized
- [ 3.158019] VFS: Mounted root (yaffs2 filesystem) readonly on device 31:5.
- [ 3.165535] devtmpfs: mounted
- [ 3.169358] Freeing unused kernel memory: 396K (80a7e000 - 80ae1000)
- Mounting /proc and /sys
- Starting the hotplug events dispatcher udevd
- Synthesizing initial hotplug even[ 3.569806] udevd (99): /proc/99/oom_adj is deprecated, please use /proc/99/oom_score_adj instead.
- ts
- Setting the hostname to freescale
- Running depmod
- depmod: can't change directory to '3.14.38-6UL_ga': No such file or directory
- Mounting filesystems
- Starting inetd:
- Starting syslogd and klogd
- [ 8.120883] flexcan 2090000.can can0: writing ctrl=0x0e312085
- [ 8.147435] flexcan 2094000.can can1: writing ctrl=0x0e312085
- Reconfiguring network interfaces... ifdown: interface lo not configured
- ifdown: interface eth0 not configured
- ifdown: interface eth1 not configured
- [ 8.354451] fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
- [ 8.404265] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
- [ 8.564849] fec 2188000.ethernet eth1: Freescale FEC PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=20b4000.ethernet:02, irq=-1)
- [ 8.604320] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
- RTNETLINK answers: File exists
- done.
- alsactl: parse:1655: Unable to open file '/data0/imx6_linux/alsa/tmp/share/alsa/init/00main': No such file or directory
- alsactl: set_control:1267: failed to obtain info for control #55 (No such file or directory)
- [ 8.837538] Trying to free nonexistent resource <0000000087b00000-0000000087c76fff>
- Copyright (C) 2006-2016 Forlinx Embedded Technology Co., Ltd All Rights Reserved www.forlinx.com
- freescale login: [ 9.114052] usb 1-1.4: new high-speed USB device number 3 using ci_hdrc
- freescale login:
有freescale login:的表示成功了,4.1内核也是用的这个文件系统。
