在本坛下载的AES算法源码,这个算法的加密模式 填充模式 偏移量等参数 和代码中如何具体对应。上位机不是用C开发 现在两头加密解密怎么也对应不起来 ,懂加密算法的帮忙看看 指点一二 非常感谢!
#define BPOLY 0x1b //!< Lower 8 bits of (x^8+x^4+x^3+x+1), ie. (x^4+x^3+x+1).
#define BLOCKSIZE 16 //!< Block size in number of bytes.
#define KEY_COUNT 3
#if KEY_COUNT == 1
#define KEYBITS 128 //!< Use AES128.
#elif KEY_COUNT == 2
#define KEYBITS 192 //!< Use AES196.
#elif KEY_COUNT == 3
#define KEYBITS 256 //!< Use AES256.
#else
#error Use 1, 2 or 3 keys!
#if KEYBITS == 128
#define ROUNDS 10 //!< Number of rounds.
#define KEYLENGTH 16 //!< Key length in number of bytes.
#elif KEYBITS == 192
#define ROUNDS 12 //!< Number of rounds.
#define KEYLENGTH 24 //!< // Key length in number of bytes.
#elif KEYBITS == 256
#define ROUNDS 14 //!< Number of rounds.
#define KEYLENGTH 32 //!< Key length in number of bytes.
#else
#error Key must be 128, 192 or 256 bits!
#define EXPANDED_KEY_SIZE (BLOCKSIZE * (ROUNDS+1)) //!< 176, 208 or 240 bytes.
unsigned char AES_Key_Table[32] =
0xd0, 0x94, 0x3f, 0x8c, 0x29, 0x76, 0x15, 0xd8,
0x20, 0x40, 0xe3, 0x27, 0x45, 0xd8, 0x48, 0xad,
0xea, 0x8b, 0x2a, 0x73, 0x16, 0xe9, 0xb0, 0x49,
0x45, 0xb3, 0x39, 0x28, 0x0a, 0xc3, 0x28, 0x3c,
unsigned char block1[256]; //!< Workspace 1.
unsigned char block2[256]; //!< Worksapce 2.
unsigned char tempbuf[256];
unsigned char *powTbl; //!< Final location of exponentiation lookup table.
unsigned char *logTbl; //!< Final location of logarithm lookup table.
unsigned char *sBox; //!< Final location of s-box.
unsigned char *sBoxInv; //!< Final location of inverse s-box.
unsigned char *expandedKey; //!< Final location of expanded key.
void CalcPowLog(unsigned char *powTbl, unsigned char *logTbl)
unsigned char i = 0;
unsigned char t = 1;
do {
// Use 0x03 as root for exponentiation and logarithms.
powTbl[i] = t;
logTbl[t] = i;
i++;
// Muliply t by 3 in GF(2^8).
t ^= (t << 1) ^ (t & 0x80 ? BPOLY : 0);
}while( t != 1 ); // Cyclic properties ensure that i < 255.
powTbl[255] = powTbl[0]; // 255 = '-0', 254 = -1, etc.
void CalcSBox( unsigned char * sBox )
unsigned char i, rot;
unsigned char temp;
unsigned char result;
// Fill all entries of sBox[].
i = 0;
do {
//Inverse in GF(2^8).
if( i > 0 )
temp = powTbl[ 255 - logTbl[i] ];
temp = 0;
// Affine transformation in GF(2).
result = temp ^ 0x63; // Start with adding a vector in GF(2).
for( rot = 0; rot < 4; rot++ )
// Rotate left.
temp = (temp<<1) | (temp>>7);
// Add rotated byte in GF(2).
result ^= temp;
// Put result in table.
sBox[i] = result;
} while( ++i != 0 );
void CalcSBoxInv( unsigned char * sBox, unsigned char * sBoxInv )
unsigned char j = 0;
// Iterate through all elements in sBoxInv using i.
do {
// Search through sBox using j.
do {
// Check if current j is the inverse of current i.
if( sBox[ j ] == i )
// If so, set sBoxInc and indicate search finished.
sBoxInv[ i ] = j;
j = 255;
} while( ++j != 0 );
void CycleLeft( unsigned char * row )
// Cycle 4 bytes in an array left once.
unsigned char temp = row[0];
row[0] = row[1];
row[1] = row[2];
row[2] = row[3];
row[3] = temp;
void InvMixColumn( unsigned char * column )
unsigned char r0, r1, r2, r3;
r0 = column[1] ^ column[2] ^ column[3];
r1 = column[0] ^ column[2] ^ column[3];
r2 = column[0] ^ column[1] ^ column[3];
r3 = column[0] ^ column[1] ^ column[2];
column[0] = (column[0] << 1) ^ (column[0] & 0x80 ? BPOLY : 0);
column[1] = (column[1] << 1) ^ (column[1] & 0x80 ? BPOLY : 0);
column[2] = (column[2] << 1) ^ (column[2] & 0x80 ? BPOLY : 0);
column[3] = (column[3] << 1) ^ (column[3] & 0x80 ? BPOLY : 0);
r0 ^= column[0] ^ column[1];
r1 ^= column[1] ^ column[2];
r2 ^= column[2] ^ column[3];
r3 ^= column[0] ^ column[3];
r0 ^= column[0] ^ column[2];
r1 ^= column[1] ^ column[3];
r2 ^= column[0] ^ column[2];
r3 ^= column[1] ^ column[3];
column[0] ^= column[1] ^ column[2] ^ column[3];
r0 ^= column[0];
r1 ^= column[0];
r2 ^= column[0];
r3 ^= column[0];
column[0] = r0;
column[1] = r1;
column[2] = r2;
column[3] = r3;
void SubBytes( unsigned char * bytes, unsigned char count )
do {
*bytes = sBox[ *bytes ]; // Substitute every byte in state.
bytes++;
} while( --count );
void InvSubBytesAndXOR( unsigned char * bytes, unsigned char * key, unsigned char count )
do {
// *bytes = sBoxInv[ *bytes ] ^ *key; // Inverse substitute every byte in state and add key.
*bytes = block2[ *bytes ] ^ *key; // Use block2 directly. Increases speed.
bytes++;
key++;
} while( --count );
void InvShiftRows( unsigned char * state )
unsigned char temp;
// Note: State is arranged column by column.
// Cycle second row right one time.
temp = state[ 1 + 3*4 ];
state[ 1 + 3*4 ] = state[ 1 + 2*4 ];
state[ 1 + 2*4 ] = state[ 1 + 1*4 ];
state[ 1 + 1*4 ] = state[ 1 + 0*4 ];
state[ 1 + 0*4 ] = temp;
// Cycle third row right two times.
temp = state[ 2 + 0*4 ];
state[ 2 + 0*4 ] = state[ 2 + 2*4 ];
state[ 2 + 2*4 ] = temp;
temp = state[ 2 + 1*4 ];
state[ 2 + 1*4 ] = state[ 2 + 3*4 ];
state[ 2 + 3*4 ] = temp;
// Cycle fourth row right three times, ie. left once.
temp = state[ 3 + 0*4 ];
state[ 3 + 0*4 ] = state[ 3 + 1*4 ];
state[ 3 + 1*4 ] = state[ 3 + 2*4 ];
state[ 3 + 2*4 ] = state[ 3 + 3*4 ];
state[ 3 + 3*4 ] = temp;
void InvMixColumns( unsigned char * state )
InvMixColumn( state + 0*4 );
InvMixColumn( state + 1*4 );
InvMixColumn( state + 2*4 );
InvMixColumn( state + 3*4 );
void XORBytes( unsigned char * bytes1, unsigned char * bytes2, unsigned char count )
do {
*bytes1 ^= *bytes2; // Add in GF(2), ie. XOR.
bytes1++;
bytes2++;
} while( --count );
void CopyBytes( unsigned char * to, unsigned char * from, unsigned char count )
do {
*to = *from;
to++;
from++;
} while( --count );
void KeyExpansion( unsigned char * expandedKey )
unsigned char temp[4];
unsigned char i;
unsigned char Rcon[4] = { 0x01, 0x00, 0x00, 0x00 }; // Round constant.
unsigned char * key = AES_Key_Table;
// Copy key to start of expanded key.
i = KEYLENGTH;
do {
*expandedKey = *key;
expandedKey++;
key++;
} while( --i );
// Prepare last 4 bytes of key in temp.
expandedKey -= 4;
temp[0] = *(expandedKey++);
temp[1] = *(expandedKey++);
temp[2] = *(expandedKey++);
temp[3] = *(expandedKey++);
// Expand key.
i = KEYLENGTH;
while( i < BLOCKSIZE*(ROUNDS+1) )
// Are we at the start of a multiple of the key size?
if( (i % KEYLENGTH) == 0 )
CycleLeft( temp ); // Cycle left once.
SubBytes( temp, 4 ); // Substitute each byte.
XORBytes( temp, Rcon, 4 ); // Add constant in GF(2).
*Rcon = (*Rcon << 1) ^ (*Rcon & 0x80 ? BPOLY : 0);
// Keysize larger than 24 bytes, ie. larger that 192 bits?
#if KEYLENGTH > 24
// Are we right past a block size?
else if( (i % KEYLENGTH) == BLOCKSIZE ) {
// Add bytes in GF(2) one KEYLENGTH away.
XORBytes( temp, expandedKey - KEYLENGTH, 4 );
// Copy result to current 4 bytes.
*(expandedKey++) = temp[ 0 ];
*(expandedKey++) = temp[ 1 ];
*(expandedKey++) = temp[ 2 ];
*(expandedKey++) = temp[ 3 ];
i += 4; // Next 4 bytes.
void InvCipher( unsigned char * block, unsigned char * expandedKey )
unsigned char round = ROUNDS-1;
expandedKey += BLOCKSIZE * ROUNDS;
XORBytes( block, expandedKey, 16 );
expandedKey -= BLOCKSIZE;
do {
InvShiftRows( block );
InvSubBytesAndXOR( block, expandedKey, 16 );
InvMixColumns( block );
} while( --round );
void aesDecInit(void)
powTbl = block1;
logTbl = block2;
CalcPowLog( powTbl, logTbl );
sBox = tempbuf;
CalcSBox( sBox );
expandedKey = block1;
KeyExpansion( expandedKey );
sBoxInv = block2; // Must be block2.
CalcSBoxInv( sBox, sBoxInv );
void aesDecrypt( unsigned char * buffer, unsigned char * chainBlock )
unsigned char temp[ BLOCKSIZE ];
CopyBytes( temp, buffer, BLOCKSIZE );
InvCipher( buffer, expandedKey );
XORBytes( buffer, chainBlock, BLOCKSIZE );
CopyBytes( chainBlock, temp, BLOCKSIZE );
unsigned char Multiply( unsigned char num, unsigned char factor )
unsigned char mask = 1;
unsigned char result = 0;
while( mask != 0 )
// Check bit of factor given by mask.
if( mask & factor )
// Add current multiple of num in GF(2).
result ^= num;
// Shift mask to indicate next bit.
mask <<= 1;
// Double num.
num = (num << 1) ^ (num & 0x80 ? BPOLY : 0);
return result;
unsigned char DotProduct( unsigned char * vector1, unsigned char * vector2 )
result ^= Multiply( *vector1++, *vector2++ );
result ^= Multiply( *vector1 , *vector2 );
return result;
void MixColumn( unsigned char * column )
unsigned char row[8] = {0x02, 0x03, 0x01, 0x01, 0x02, 0x03, 0x01, 0x01};
// Prepare first row of matrix twice, to eliminate need for cycling.
unsigned char result[4];
// Take dot products of each matrix row and the column vector.
result[0] = DotProduct( row+0, column );
result[1] = DotProduct( row+3, column );
result[2] = DotProduct( row+2, column );
result[3] = DotProduct( row+1, column );
// Copy temporary result to original column.
column[0] = result[0];
column[1] = result[1];
column[2] = result[2];
column[3] = result[3];
void MixColumns( unsigned char * state )
void ShiftRows( unsigned char * state )
unsigned char temp;
// Cycle second row left one time.
temp = state[ 1 + 0*4 ];
state[ 1 + 0*4 ] = state[ 1 + 1*4 ];
state[ 1 + 1*4 ] = state[ 1 + 2*4 ];
state[ 1 + 2*4 ] = state[ 1 + 3*4 ];
state[ 1 + 3*4 ] = temp;
// Cycle third row left two times.
// Cycle fourth row left three times, ie. right once.
temp = state[ 3 + 3*4 ];
state[ 3 + 3*4 ] = state[ 3 + 2*4 ];
state[ 3 + 2*4 ] = state[ 3 + 1*4 ];
state[ 3 + 1*4 ] = state[ 3 + 0*4 ];
state[ 3 + 0*4 ] = temp;
void Cipher( unsigned char * block, unsigned char * expandedKey )
expandedKey += BLOCKSIZE;
do {
SubBytes( block, 16 );
ShiftRows( block );
} while( --round );
ShiftRows( block );
void aesEncInit(void)
powTbl = block1;
logTbl = tempbuf;
sBox = block2;
CalcSBox( sBox );
void aesEncrypt( unsigned char * buffer, unsigned char * chainBlock )
CopyBytes( chainBlock, buffer, BLOCKSIZE );
#include <string.h>
void AES_Test(void)
unsigned char dat[16]="0123456789ABCDEF";
unsigned char chainCipherBlock[16];
unsigned char i;
for(i=0;i<32;i++) AES_Key_Table[i]=i;//做运算之前先要设置好密钥,这里只是设置密钥的DEMO。
memset(chainCipherBlock,0x00,sizeof(chainCipherBlock));
aesEncInit();//在执行加密初始化之前可以为AES_Key_Table赋值有效的密码数据
aesEncrypt(dat, chainCipherBlock);//AES加密,数组dat里面的新内容就是加密后的数据。
//aesEncrypt(dat+16, chainCipherBlock);//AES源数据大于16字节时,把源数据的指针+16就好了
memset(chainCipherBlock,0x00,sizeof(chainCipherBlock));//这里要重新初始化清空
aesDecInit();//在执行解密初始化之前可以为AES_Key_Table赋值有效的密码数据
aesDecrypt(dat, chainCipherBlock);//AES解密,密文数据存放在dat里面,经解密就能得到之前的明文。
//aesDecrypt(dat+16, chainCipherBlock);//AES源数据大于16字节时,把源数据的指针+16就好了
