如题<stm32g030f使用TIM1_PWM_DMA丢信号,频率降了一半有遇到过的吗?>
使用定时器直接产生固定脉宽的pwm信号正常,100hz,
但是使用DMA时,发送了10组pwm数据,竟然出现了5个波形,频率也减了一半,成了50hz
请问坛友有遇到过的吗?
- static void MX_TIM1_Init(void)
- /* USER CODE BEGIN TIM1_Init 0 */
- /* USER CODE END TIM1_Init 0 */
- TIM_MasterConfigTypeDef sMasterConfig = {0};
- TIM_OC_InitTypeDef sConfigOC = {0};
- TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
- /* USER CODE BEGIN TIM1_Init 1 */
- /* USER CODE END TIM1_Init 1 */
- htim1.Instance = TIM1;
- htim1.Init.Prescaler = 4800;//48000;//0;
- htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
- htim1.Init.Period = 100-1;//59;
- htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
- htim1.Init.RepetitionCounter = 0;
- htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
- if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
- Error_Handler();
- sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
- sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
- sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
- if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
- Error_Handler();
- sConfigOC.OCMode = TIM_OCMODE_PWM1;
- sConfigOC.Pulse = 50;//占空比
- sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
- sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
- sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
- sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
- sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
- if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
- Error_Handler();
- sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
- sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
- sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
- sBreakDeadTimeConfig.DeadTime = 0;
- sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
- sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
- sBreakDeadTimeConfig.BreakFilter = 0;
- sBreakDeadTimeConfig.BreakAFMode = TIM_BREAK_AFMODE_INPUT;
- sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
- sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
- sBreakDeadTimeConfig.Break2Filter = 0;
- sBreakDeadTimeConfig.Break2AFMode = TIM_BREAK_AFMODE_INPUT;
- sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
- if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN TIM1_Init 2 */
- /* USER CODE END TIM1_Init 2 */
- HAL_TIM_MspPostInit(&htim1);
- static void MX_DMA_Init(void)
- /* DMA controller clock enable */
- __HAL_RCC_DMA1_CLK_ENABLE();
- /* DMA interrupt init */
- /* DMA1_Channel1_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
- /* DMA1_Channel2_3_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(DMA1_Channel2_3_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(DMA1_Channel2_3_IRQn);
- void HAL_TIM_PWM_MspInit(TIM_HandleTypeDef* htim_pwm)
- if(htim_pwm->Instance==TIM1)
- /* USER CODE BEGIN TIM1_MspInit 0 */
- //GPIO_InitTypeDef GPIO_InitStruct = {0};
- /* USER CODE END TIM1_MspInit 0 */
- /* Peripheral clock enable */
- __HAL_RCC_TIM1_CLK_ENABLE();
- /* TIM1 DMA Init */
- /* TIM1_CH1 Init */
- hdma_tim1_ch1.Instance = DMA1_Channel2;
- hdma_tim1_ch1.Init.Request = DMA_REQUEST_TIM1_CH1;
- hdma_tim1_ch1.Init.Direction = DMA_MEMORY_TO_PERIPH;
- hdma_tim1_ch1.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_tim1_ch1.Init.MemInc = DMA_MINC_ENABLE;
- hdma_tim1_ch1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
- hdma_tim1_ch1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
- hdma_tim1_ch1.Init.Mode = DMA_NORMAL;
- hdma_tim1_ch1.Init.Priority = DMA_PRIORITY_HIGH;
- if (HAL_DMA_Init(&hdma_tim1_ch1) != HAL_OK)
- Error_Handler();
- __HAL_LINKDMA(htim_pwm,hdma[TIM_DMA_ID_CC1],hdma_tim1_ch1);
- /* USER CODE BEGIN TIM1_MspInit 1 */
- /* USER CODE END TIM1_MspInit 1 */
- unsigned int timeDmaBuf[50];
- void pwm_dma_test(void){
- unsigned char i;
- TIM_PWM_DMA_SW = 0;
- for(i=0;i<10;i++){
- timeDmaBuf[i] = i*10+10;
- HAL_TIM_PWM_Start_DMA(&htim1,TIM_CHANNEL_1,(uint32_t*)timeDmaBuf,10);
- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_DMA_Init();
- MX_SPI1_Init();
- MX_TIM14_Init();
- MX_TIM1_Init();
- /* USER CODE BEGIN 2 */
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- pwm_dma_test();
- HAL_Delay(200);
- /* USER CODE END 3 */
复制代码 |
