回复: 2
STM32L431的ADC连续转换无用?CUBEMAX设置的。
出75入8汤圆
发表于 2024-1-4 15:39:21 | 显示全部楼层 |阅读模式
如题:设置为ADC连续转换,结果还是要手动停止才可以。void MX_ADC1_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  /** Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
  hadc1.Init.Resolution = ADC_RESOLUTION_12B;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc1.Init.LowPowerAutoWait = DISABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.NbrOfConversion = 1;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  hadc1.Init.DMAContinuousRequests = DISABLE;
  hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
  hadc1.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_2CYCLES_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
    Error_Handler();
每一次都要停止:
HAL_ADC_Start(&hadc1);
        HAL_ADC_PollForConversion(&hadc1,0x02);     //等待转换完成
                                HAL_ADC_Stop(&hadc1); 如果不停止下次转换就没数据。
出90入372汤圆
发表于 2024-1-4 15:53:08 | 显示全部楼层
hadc1.Init.DMAContinuousRequests = DISABLE;  改为ENABLE
出75入8汤圆
 楼主| 发表于 2024-1-4 16:08:32 | 显示全部楼层
(引用自2楼)
谢谢,单独改这个还是没用,不过我可以用DMA试试,我看了别人的程序,完全不需要启动DMA就可以。
GMT+8, 2024-6-2 09:42
