回复: 14
轻松一下,利用计算圆周率PI的程序测试MCU的性能
发表于 2006-2-26 02:01:50 | 显示全部楼层 |阅读模式
今天在网上看到了计算PI的一种快速算法和程序。我稍微作了一些修改,理论上可以放到任何的平台上编译执行。
#define NUMBERS                5000
long long base[NUMBERS / 12 + 10];
long long calc[NUMBERS / 12 + 10];
long long result[NUMBERS / 12 + 10];
void CalculatePI(long long *total, long number)
    long a, i, j, step;
    long array = number / 12 + 3;
    long long remain, q;
    long head, devide, devidedouble, loop, start;
    double ratio;
    for(i = 0; i <= array; i ++)
        total = 0;
    for (step = 0; step < 2; step ++)
        devide = (!step) ? 5 : 239;
        devidedouble = devide * devide;
        remain = 1;
        for(i = 0;i <= array; i ++)
            base=remain / devide;
//            remain=(remain%devide)*1000000000000LL;
/**/        remain=(remain - base * devide) * 1000000000000LL;
        loop = (long)(number * log(10) / log(devide) + 1);
        ratio = log(devide) / log(10) / 12;
        start;
            calc = 0;
        for(j = 1;j <= loop; j++, j++)
            start = (long)(j * ratio);
            remain = 0;
            if(!(j & 2))
                for(i = start; i <= array;)
                    a=i;
//                    calc+=remain/j;
//                    remain=(remain%j)*1000000000000LL+base[++i];
/**/                q = remain / j;
/**/                calc += q;
/**/                remain -= q * j;
/**/                remain = remain * 1000000000000LL + base[++i];
                    while(calc[a] >= 1000000000000LL)
                        calc[a] -= 1000000000000LL;
                        calc[--a] ++;
                    a=i;
//                    calc-=remain/j;
/**/                calc -= q;
                    while(calc[a] < 0)
                        calc[a] += 1000000000000LL;
                        calc[-- a] --;
            remain = 0;
            if(!step)
                head = j/12 + 2;
                for (i = start;(i <= array) && (i <= head);)
                    base = remain / devidedouble;
//                    remain=(remain%devidedouble)*1000000000000LL+base[++i];
/**/                remain -= base * devidedouble;
/**/                remain = remain * 1000000000000LL + base[++ i];
                for(i = start;i <= array;)
                    base=remain / devidedouble;
        if(!step)
            total[array] += calc[array] * 16;
            for(i = array - 1;i >= 0;i --)
                total += total[i + 1] / 1000000000000LL + calc * 16;
                total[i + 1] %= 1000000000000LL;
            long long tail;
            total[array] -= calc[array] * 4;
            for (i = array - 1;i >= 0;i --)
                tail = total[i + 1] % 1000000000000LL;
                total += total[i + 1] / 1000000000000LL - ((tail < 0) ? 1 : 0) - calc * 4;
                total[i + 1] = tail + ((tail < 0) ? 1000000000000LL : 0);
调用时采用语句:CalculatePI(result, NUMBERS),结果保存在long long型的数组result中,其中result[0]存放的是数字3,result[1]以后的以整数形式存放PI的小数部分,每个整数对应12位的小数。
我分别在PC上和ARM7(LPC2142)上测试了程序的运算速度,结果如下:
  CPU       主频        RAM        编译器          计算5000位小数的时间
P4 2.4C     2.4GHz   512M DDR400   BCB 6.0                 0.912s
C4 2.4D     2.4GHz   512M DDR333   BCB 6.0                 1.285s
LPC2142     60MHz    16K SRAM    Keil ARM 2.50a,全优化    9.698s
由于代码太大,无法在我的M8515上测试,有兴趣的可以试试在AVR上的速度。迟些我也想试试在DSP上的速度如何。
发表于 2006-2-26 11:49:57 | 显示全部楼层
这样也行呀?计算结果应该跟编译器和优化等级有关哦。
 楼主| 发表于 2006-2-26 12:17:03 | 显示全部楼层
是啊,通过类似的测试,可以大致了解一下在不同平台上实现同样功能的性能差别,以及在同一MCU上不同编译器的差别(例如我就发现KARM 2.32(采用Keil编译器)比KARM 2.50(采用RealView编译器)慢很多而且不能得到正确结果),还可以比较同一编译器,不同MCU上运行的差别(例如比较各种ARM7)。
发表于 2006-2-26 13:08:28 | 显示全部楼层
我还有M128的板(外扩32KByte SRAM)
调用void CalculatePI(long long *total, long number) 就行了吗?
 楼主| 发表于 2006-2-26 13:23:35 | 显示全部楼层
当然可以,程序代码大概20多K。你把
这3个全局变量定义到外部SRAM就可以了。
然后用定时器来算算运行时间。
 楼主| 发表于 2006-2-26 14:12:28 | 显示全部楼层
刚才在VC下编译运行了一次,在C4 2.4D,512M DDR的配置下运行居然只需要0.176s,比BCB6.0的版本快了7倍多!
发表于 2014-7-10 14:56:26 | 显示全部楼层
qwernet 发表于 2006-2-26 13:23
当然可以,程序代码大概20多K。你把
我放在LPC1768上,编译不过,报错啊.
//--------------------------------------         if(!step)
                                                        head = j/12 + 2;
                                                    base = remain / devidedouble;   //################数组不能这样这样用吧
//                      remain -= base * devidedouble;
//                      remain = remain * 1000000000000LL + base[++ i];
                 base= (remain / devidedouble);
数组
发表于 2014-7-10 15:34:13 | 显示全部楼层
试一下ADI的blackfin DSP,应该也在1秒左右。
 楼主| 发表于 2014-7-10 16:16:35 | 显示全部楼层
见鬼了,当年贴上来的代码,所有“[ i ]”都贴丢了。。。
 楼主| 发表于 2014-7-10 16:19:14 | 显示全部楼层
我明白了,原来“【i】”在现在的论坛里变成了斜体格式代码,所以全部都丢了。。。
发表于 2014-7-10 16:25:13 | 显示全部楼层
qwernet 发表于 2014-7-10 16:19
我明白了,原来“【i】”在现在的论坛里变成了斜体格式代码,所以全部都丢了。。。 ...
楼主,你好.我正想测试下手头的NXP CORTEX-M0+的,为了避免出错,能够将这个函数以及他的具体用法,放到记事本,传上来!?多谢!
出300入477汤圆
发表于 2014-7-10 17:41:06 | 显示全部楼层
PC,BCB XE5 64位编译器,Win7 64位系统,CPU是I7-4700MQ,2.4G
最高优化,计算时间 28-29ms
切换为BCB XE5 32位编译器,最高优化,计算时间500ms
BCB64位的进步真大!
出300入477汤圆
发表于 2014-7-10 17:45:34 | 显示全部楼层
[ 本帖最后由 redroof 于 2014-7-10 17:46 编辑 ]\n\n[quote][size=2][url=forum.php?mod=redirect&goto=findpost&pid=7675106&ptid=589912][color=#999999]redroof 发表于 2014-7-10 17:41[/color][/url][/size]
最高优化,计算时间 28-29ms
切换为BCB XE ...[/quote]
据说地球上最好的编译器是Intel的ICC
不知道哪位有新的64位版的ICC,可以编译这个代码来试试看
楼主的代码的正确处理方法是:
显示网页代码,然后把<i>替换成[i]
然后再用浏览器打开,正常拷出里面的内容就行了
我试过,可以编译,计算结果也正确
出5入110汤圆
发表于 2020-8-27 12:07:09 | 显示全部楼层
找圆周率的计算方法,找到这里,用VS2015 顺便测试了一下。
感觉挺有意思,虽然 没看懂,
使用的电脑 计算一次用时不超过50ms
win10 64位
CPU E3-1230 V2@3.30GHz
编辑后的code 重新传了一遍
  1. // CalculatePI.cpp : 定义控制台应用程序的入口点。
  2. //
  3. #include "stdafx.h"
  4. #include "math.h"
  5. #define NUMBERS 5000
  6. long long base[NUMBERS / 12 + 10];
  7. long long calc[NUMBERS / 12 + 10];
  8. long long result[NUMBERS / 12 + 10];
  9. void CalculatePI(long long *total, long number)
  10. {
  11.         long a, i, j, step;
  12.         long array = number / 12 + 3;
  13.         long long remain, q;
  14.         long head, devide, devidedouble, loop, start;
  15.         double ratio;
  16.         for (i = 0; i <= array; i++)
  17.                 total[i] = 0;
  18.         for (step = 0; step < 2; step++)
  19.         {
  20.                 devide = (!step) ? 5 : 239;
  21.                 devidedouble = devide * devide;
  22.                 remain = 1;
  23.                 for (i = 0; i <= array; i++)
  24.                 {
  25.                         base[i] = remain / devide;
  26.                         //            remain=(remain%devide)*1000000000000LL;
  27.                         /**/ remain = (remain - base[i] * devide) * 1000000000000LL;
  28.                 }
  29.                 loop = (long)(number * log(10) / log(devide) + 1);
  30.                 ratio = log(devide) / log(10) / 12;
  31.                 start;
  32.                 for (i = 0; i <= array; i++)
  33.                         calc[i] = 0;
  34.                 for (j = 1; j <= loop; j++, j++)
  35.                 {
  36.                         start = (long)(j * ratio);
  37.                         remain = 0;
  38.                         if (!(j & 2))
  39.                                 for (i = start; i <= array;)
  40.                                 {
  41.                                         a = i;
  42.                                         //                    calc+=remain/j;
  43.                                         //                    remain=(remain%j)*1000000000000LL+base[++i];
  44.                                         /**/ q = remain / j;
  45.                                         /**/ calc[i] += q;
  46.                                         /**/ remain -= q * j;
  47.                                         /**/ remain = remain * 1000000000000LL + base[++i];
  48.                                         while (calc[a] >= 1000000000000LL)
  49.                                         {
  50.                                                 calc[a] -= 1000000000000LL;
  51.                                                 calc[--a]++;
  52.                                         }
  53.                                 }
  54.                         else
  55.                                 for (i = start; i <= array;)
  56.                                 {
  57.                                         a = i;
  58.                                         //                    calc-=remain/j;
  59.                                         //                    remain=(remain%j)*1000000000000LL+base[++i];
  60.                                         /**/ q = remain / j;
  61.                                         /**/ calc[i] -= q;
  62.                                         /**/ remain -= q * j;
  63.                                         /**/ remain = remain * 1000000000000LL + base[++i];
  64.                                         while (calc[a] < 0)
  65.                                         {
  66.                                                 calc[a] += 1000000000000LL;
  67.                                                 calc[--a]--;
  68.                                         }
  69.                                 }
  70.                         remain = 0;
  71.                         if (!step)
  72.                         {
  73.                                 head = j / 12 + 2;
  74.                                 for (i = start; (i <= array) && (i <= head);)
  75.                                 {
  76.                                         base[i] = remain / devidedouble;
  77.                                         //                    remain=(remain%devidedouble)*1000000000000LL+base[++i];
  78.                                         /**/ remain -= base[i] * devidedouble;
  79.                                         /**/ remain = remain * 1000000000000LL + base[++i];
  80.                                 }
  81.                         }
  82.                         else
  83.                                 for (i = start; i <= array;)
  84.                                 {
  85.                                         base[i] = remain / devidedouble;
  86.                                         //                    remain=(remain%devidedouble)*1000000000000LL+base[++i];
  87.                                         /**/ remain -= base[i] * devidedouble;
  88.                                         /**/ remain = remain * 1000000000000LL + base[++i];
  89.                                 }
  90.                 }
  91.                 if (!step)
  92.                 {
  93.                         total[array] += calc[array] * 16;
  94.                         for (i = array - 1; i >= 0; i--)
  95.                         {
  96.                                 total[i] += total[i + 1] / 1000000000000LL + calc[i] * 16;
  97.                                 total[i + 1] %= 1000000000000LL;
  98.                         }
  99.                 }
  100.                 else
  101.                 {
  102.                         long long tail;
  103.                         total[array] -= calc[array] * 4;
  104.                         for (i = array - 1; i >= 0; i--)
  105.                         {
  106.                                 tail = total[i + 1] % 1000000000000LL;
  107.                                 total[i] += total[i + 1] / 1000000000000LL - ((tail < 0) ? 1 : 0) - calc[i] * 4;
  108.                                 total[i + 1] = tail + ((tail < 0) ? 1000000000000LL : 0);
  109.                         }
  110.                 }
  111.         }
  112. }
  113. //调用时采用语句:CalculatePI(result, NUMBERS),
  114. //结果保存在long long型的数组result中,
  115. //其中result[0]存放的是数字3,
  116. //result[1]以后的以整数形式存放PI的小数部分,
  117. //每个整数对应12位的小数。
  118. int main()
  119. {
  120.         CalculatePI(result, NUMBERS);
  121.         return 0;
  122. }
出10入120汤圆
发表于 2020-8-27 12:15:58 | 显示全部楼层
谁放在世界第一的STC上试一下
GMT+8, 2024-6-2 10:09
