回复: 8
机器人新干线-------时下最流行的机器人!
发表于 2006-3-31 22:09:17 | 显示全部楼层 |阅读模式
推   介1:Robonova-1 Kit
概    述:
    This exciting new humanoid robot offers educators, students and robotic hobbyists a complete robot package. The stable ROBONOVA-I can walk, run, do flips, cartwheels, dance moves and once programmed, is ready to compete in any Robo One Class “J” competition. Available two ways, as a kit, so you can enjoy building your robot yourself, or as a pre-assembled, “RTW”, “ready to walk” instant gratification robot.
图片资料:
相关宣传:
相关站点:
     http://www.hitecrobotics.com/robonova/overview.htm
如何工作?
1、The Key - “Easy to Operate”
ROBONOVA-1, Robot Programming Made Easy.
Users of this exciting robot package have an opportunity to learn robot technology first hand. Programming is simple with the supplied RoboScript and RoboBasic software via the included PC interface cable.
2、Flexible Applications for All Users in the kit
RoboScript & RoboRemocon
    Beginners to robot programming technology will be pleased to use the supplied RoboScript programming software. Without knowing any programming language at all users can create operational subroutines with the click of a mouse.
Use the RoboRemocon software to control your ROBONOVA-1 with the operational data created with RoboScript.
RoboBasic
    RoboBasic is a programming tool based on the BASIC programming language and is provided for the more advanced users. Containing specific commands for simple robot operation, RoboBasic can also be used in conjuction with RoboScript to increase the performance of the supplied Micom controller board.
Catch & Play Function
Easy Programming Technique
    The simplest way to program ROBONOVA-1 is with the “catch and play” function. Using RoboScript or RoboBasic, just move the robot into any position and click the mouse to “capture” that position. Move the robot into another position and repeat the process. The software then links these “captured” positions and once activated, smoothly transitions the robot’s movements through these programmed positions.
Functional Extensions
    ROBONOVA-1 can be retrofitted with several accessory modules and ancillary items to customize its functionality. By adding additional servos and brackets, the head and waist can turn and “gripping” hands can be used. Gyros, acceleration sensors, speech functions, R/C control accessories and more can also be added as they become available.
(未完待续)
-----此内容被superhtw于2006-03-31,22:21:33编辑过
发表于 2006-3-31 22:22:50 | 显示全部楼层
无聊。。。。又是舵机
 楼主| 发表于 2006-4-1 10:34:47 | 显示全部楼层
不用舵机的也有,下面一款:
    据说在2004年全球销量最火。
    但是,多关节复杂动作设计的robot不能没有R/C SERVO MOTOR.1楼不妨多加演练,不要气馁!
 楼主| 发表于 2006-4-1 11:19:27 | 显示全部楼层
SuperHTW强力推荐:Robonova-1精彩表演,堪称顶级,不得不看...
   http://www.hitecrobotics.com/Tony%20information/Dance_troupe_HR.wmv
发表于 2006-4-1 16:37:24 | 显示全部楼层
太牛了。
 楼主| 发表于 2006-5-1 11:29:20 | 显示全部楼层
如此牛的robot,回复飞鱼的人寥寥无几,是因为难度?造价?技术?或者... ...
   其实仿生是人类研发机器人的最原始目的,也是永远不变的主题!
   建议有兴趣的爱好者一起研究此课题,对技术的提高、理念的创新、知识的提升都有不错的功效!
-----此内容被superhtw于2006-05-01,11:41:32编辑过
发表于 2007-3-25 22:38:51 | 显示全部楼层
实在太牛!!!!!!!!!!!!
发表于 2007-4-2 18:18:17 | 显示全部楼层
这东西难度不在结构,而在于控制运动的算法
发表于 2007-4-3 15:13:19 | 显示全部楼层
真牛!
GMT+8, 2024-4-27 08:07
