点亮LM7222SGLU液晶屏(控制芯片T7932)
(转载请注明出自http://avr.cnta.net,谢谢)
手中一片LM7222SGLU液晶屏(驱动芯片为T7932和T7933,分辨率150X32),研究了一下,用MEGA16驱动点亮。
1
2
3
LCD引脚定义:
1.- NC
2.- Vou Contrast(接负压)
3.- RST reset
4.- CS3 Chip select, columns 101-150
5.- CS2 Chip select, columns 51-100
6.- CS1 Chip select, columns 1-50
7.- VLED Connected to VDD
8.- D7
9.- D6
10.- D5
11.- D4
12.- D3
13.- D2
14.- D1
15.- D0
16.- VDD Logic Power Supply 5V
17.- D/I
18.- /RW(RD)
19.- /WR--------E
20.- GND
BASCOM源码:
BASCOM-AVR 1.11.9.0编译通过,子程序:写地址及命令putaddress , 写显示字节putdata,读显示字节readdata,读状态字节readstatus,画点pointset,清屏clslcd。
$regfile = "m16def.dat" ' specify the used micro
$crystal = 7372800
$baud = 115200 ' use baud rate
$hwstack = 32 ' default use 32 for the hardware stack
$swstack = 10 ' default use 10 for the SW stack
$framesize = 40 ' default use 40 for the frame space
'Fuse Data H:DB L:3F
Config Portb = Output
Config Portc = Output
Config Portd = Output
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 8
Pwm1a = 128
Config Serialin = Buffered , Size = 128
Config Serialout = Buffered , Size = 128
Enable Interrupts
E Alias Portb.0
Rd Alias Portb.1
Di Alias Portb.2
Cs1 Alias Portb.3
Cs2 Alias Portb.4
Cs3 Alias Portb.5
Rst Alias Portb.6
Outdata Alias Portc
Getdata Alias Pinc
80 / 68 = L : 68.series Mpu
本lcd已固定设置为68模式
D / I = H : Data Db0 To Db7 Is Display Data.
D / I = L : Data Db0 To Db7 Is Instruction Data.
E R / W = L Write Data : Data Of Db0 To Db7 Latch To The Input Register At The Falling Edge Of E.
E R / W = H Read Data : Data Of Db0 To Db7 Output To Mpu When E = H
Rd R / W = H : Data Output To Mpu When E = H And Cs2 , Cs3 = H.
Rd R / W = L : The Input Register Can Accept Data When Cs2 , Cs3 = H Or Cs1 = H.
Rst = L Sets Display Off , And Sets Mode To Y.address Counter.
Maintains This State Until Changed By Another Command.
Declare Function Readstatus() As Byte
Declare Function Readdata() As Byte
Declare Sub Putdata(byval Od As Byte )
Declare Sub Putaddress(byval Ad As Byte )
Declare Sub Clslcd()
Declare Sub Pointset(byval X As Byte , Byval Y As Byte , Byval Color As Byte )
Dim S As String * 16
Dim Bitstring As String * 1
Dim Bytestring As String * 2
Dim Scrindex As Byte
Dim Datatype As Byte
Dim Gd As Byte
Dim Screen As Byte , Page As Byte , Py As Byte , Dispdata As Byte , Address As Byte
Dim I As Integer , J As Integer
Dim Sgle As Single
Dim Angle As Single
Dim Cx As Byte , Cy As Byte
Rst = 0
Cs1 = 1
Cs2 = 1
Cs3 = 1
Waitms 1
Rst = 1
'display on '00111001
'display off '00111000
Call Putaddress(&B00111001)
0000111110 Start Page 0 : See Fig. 3.a
0001111110 Start Page 1 : See Fig. 3.b
0010111110 Start Page 2 : See Fig. 3.c
0011111110 Start Page 3 : See Fig. 3.d
Call Putaddress(&B00111110)
'00111011 Up mode
'00111010 Down Mode
Call Putaddress(&B00111011)
'The Receive String define
'XDHH#
'X-Data Type ,0-instruction data. 1-display data. 7-CLS
'D-Chip select 1,2,3
'HH-Data
'Cls
Call Clslcd
'Line
For Cy = 1 To 31
Call Pointset(75 , Cy , 1)
Next
For Cx = 59 To 91
Call Pointset(cx , 16 , 1)
Next
'Circle
For I = 0 To 359
Sgle = I / 2
Sgle = Sgle * 360
Sgle = Sgle / 3.1416
Angle = Sin(sgle)
Angle = Angle * 13
J = Round(angle)
Cx = 75 + J
Angle = Cos(sgle)
Angle = Angle * 12
J = Round(angle)
Cy = 16 + J
Call Pointset(cx , Cy , 1)
Next
Do
'Set The Start Page 0
Cs1 = 1 : Cs2 = 1 : Cs3 = 1
S = ""
Do
Bitstring = Waitkey()
S = S + Bitstring
Loop Until Bitstring = "#"
'CS1 Chip select, columns 1-50
'CS2 Chip select, columns 51-100
'CS3 Chip select, columns 101-150
Bitstring = Mid(s , 2 , 1)
Cs1 = 0 : Cs2 = 0 : Cs3 = 0
Select Case Bitstring
Case "1"
Cs1 = 1
Case "2"
Cs2 = 1
Case "3"
Cs3 = 1
End Select
'Data Type ,0-instruction data. 1-display data. 7-CLS
Bitstring = Left(s , 1)
Bytestring = Mid(s , 3 , 2)
Gd = Hexval(bytestring)
Case "0" 'instruction data.
Call Putaddress(gd)
Case "1" 'display data.
Call Putdata(gd)
Case "7"
Call Clslcd
Case "O"
Call Putaddress(&B00111001) 'display on '00111001
Case "C"
Call Putaddress(&B00111000) 'display off '00111000
Case "R"
Rst = 0
Case "S"
Rst = 1
End Select
Print "!";
Loop
End
Sub Clslcd()
For Gd = 0 To 49
Call Putaddress(gd)
Call Putdata(&B0)
Next
For Gd = 64 To 113
Call Putaddress(gd)
Call Putdata(0)
Next
For Gd = 128 To 177
Call Putaddress(gd)
Call Putdata(0)
Next
For Gd = 192 To 241
Call Putaddress(gd)
Call Putdata(0)
Next
End Sub
E = 0
Rd = 0
Di = 1
nop
E = 1
nop
Outdata = Od
nop
E = 0
Nop
Rd = 0
Di = 0
End Sub
Local Rdata As Byte
Ddrc = 0
E = 0
Rd = 0
Di = 0
nop
Rd = 1
Di = 1
nop
E = 1
nop
Rdata = Getdata
nop
E = 0
nop
Rd = 0
Di = 0
Ddrc = &HFF
Readdata = Rdata
End Function
E = 0
Rd = 0
Di = 0
nop
E = 1
nop
Outdata = Ad
nop
E = 0
nop
Rd = 1
End Sub
Local Status As Byte
Ddrc = 0
E = 0
Rd = 0
Di = 0
nop
Rd = 1
nop
E = 1
nop
Status = Getdata
nop
E = 0
nop
Rd = 0
Ddrc = &HFF
Readstatus = Status
End Function
Sub Pointset(x As Byte , Y As Byte , Color As Byte )
Call Putaddress(&B00111110) 'Set The Start Page 0
'Set Screen index
Screen = X \ 50
Incr Screen
Select Case Screen
Case 1
Cs1 = 1
Case 2
Cs2 = 1
Case 3
Cs3 = 1
End Select
'Data Address
Page = Y \ 8
X = X Mod 50
Address = Page * 64
Address = Address + X
'get display data
Call Putaddress(address)
Dispdata = Readdata()
'new display data
Py = Y Mod 8
Py = 2 ^ Py
If Color = 1 Then
Dispdata = Dispdata Or Py
Else
Py = Not Py
Dispdata = Dispdata And Py
End If
'write display data
Call Putdata(dispdata)
End Sub
上位机演示程序:
写了个上位机写屏测试演示程序,采用RS232与Mega16通讯。点击此处下载ourdev_215219.zip(文件大小:1.17M)
界面如下图:
1
相关资料:
T7932手册:点击此处打开ourdev_215220.pdf(文件大小:405K)
T7933手册:点击此处打开ourdev_215221.pdf(文件大小:208K) |
