* \brief Look up an authorization entry.
static AUTHINFO *NutHttpAuthLookup(CONST char *dirname, CONST char *login)
AUTHINFO *auth;
for (auth = authList; auth; auth = auth->auth_next) {
if (dirname && (strstr(dirname, auth->auth_dirname) != dirname))
continue;
if (login && strcmp(login, auth->auth_login))
continue;
break;
return auth;
* \brief Register an authorization entry.
* Protect a specified directory from unauthorized access.
* \warning Directories not registered by this function are
* accessible by anyone.
* \param dirname Name of the directory to protect.
* \param login Required login to access this directory. This
* string must contain a user name, followed by
* a colon followed by an uncrypted password.
* \return 0 on success, -1 otherwise.
int NutRegisterAuth(CONST char *dirname, CONST char *login)
AUTHINFO *auth;
/* Allocate a new list element. */
if ((auth = malloc(sizeof(AUTHINFO))) != NULL) {
auth->auth_next = authList;
/* Allocate the path component. */
if ((auth->auth_dirname = strdup(dirname)) != NULL) {
/* Allocate the login component. */
if ((auth->auth_login = strdup(login)) != NULL) {
/* Success. Add element to the list and return. */
authList = auth;
return 0;
/* Allocation failed. */
free(auth->auth_dirname);
free(auth);
return -1;
* \brief Clear all authorization entries.
* Clears all authorization entries and frees the used ressouces.
void NutClearAuth(void)
AUTHINFO *auth;
* \brief Validate an authorization request.
* \note This function is automatically called by the HTTP
* library on incoming requests. Applications do not
* need to call this function.
* \param req Request to be checked.
* \return 0, if access granted, -1 otherwise.
int NutHttpAuthValidate(REQUEST * req)
char *realm;
char *cp = 0;
int rc = -1;
* Get directory by chopping off filename.
realm = req->req_url;
if ((cp = strrchr(realm, '/')) != 0)
*cp = 0;
realm = ".";
