IIRValue >>= 1; /* skip pending bit in IIR */
IIRValue &= 0x07; /* check bit 1~3, interrupt identification */
if ( IIRValue == IIR_RLS ) /* Receive Line Status */
LSRValue = LPC_UART0->LSR;
if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
/* There are errors or break interrupt */
/* Read LSR will clear the interrupt */
UART0Status = LSRValue;
Dummy = LPC_UART0->RBR; /* Dummy read on RX to clear
interrupt, then bail out */
return;
if ( LSRValue & LSR_RDR ) /* Receive Data Ready */
/* If no error on RLS, normal ready, save into the data buffer. */
/* Note: read RBR will clear the interrupt */
UART0Buffer[UART0Count] = LPC_UART0->RBR;
UART0Count++;
if ( UART0Count == BUFSIZE )
UART0Count = 0; /* buffer overflow */
else if ( IIRValue == IIR_RDA ) /* Receive Data Available */
UART0Count++;
else if ( IIRValue == IIR_CTI ) /* Character timeout indicator */
/* Character Time-out indicator */
UART0Status |= 0x100; /* Bit 9 as the CTI error */
else if ( IIRValue == IIR_THRE ) /* THRE, transmit holding register empty */
/* THRE interrupt */
LSRValue = LPC_UART0->LSR; /* Check status in the LSR to see if
valid data in U0THR or not */
if ( LSRValue & LSR_THRE )
UART0TxEmpty = 1;
UART0TxEmpty = 0;
LSRValue = LPC_UART1->LSR;
UART1Status = LSRValue;
Dummy = LPC_UART1->RBR; /* Dummy read on RX to clear
return;
UART1Buffer[UART1Count] = LPC_UART1->RBR;
UART1Count++;
if ( UART1Count == BUFSIZE )
UART1Count = 0; /* buffer overflow */
UART1Count++;
UART1Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART1->LSR; /* Check status in the LSR to see if
UART1TxEmpty = 1;
UART1TxEmpty = 0;
** Function name: UARTInit
** Descriptions: Initialize UART port, setup pin select,
** clock, parity, stop bits, FIFO, etc.
** parameters: portNum(0 or 1) and UART baudrate
** Returned value: true or false, return false only if the
** interrupt handler can't be installed to the
** VIC table
uint32_t UARTInit( uint32_t PortNum, uint32_t baudrate )
uint32_t Fdiv;
uint32_t pclkdiv, pclk;
if ( PortNum == 0 )
LPC_PINCON->PINSEL0 &= ~0x000000F0;
LPC_PINCON->PINSEL0 |= 0x00000050; /* RxD0 is P0.3 and TxD0 is P0.2 */
/* By default, the PCLKSELx value is zero, thus, the PCLK for
all the peripherals is 1/4 of the SystemFrequency. */
/* Bit 6~7 is for UART0 */
pclkdiv = (LPC_SC->PCLKSEL0 >> 6) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
pclk = SystemFrequency/4;
break;
case 0x01:
pclk = SystemFrequency;
break;
case 0x02:
pclk = SystemFrequency/2;
break;
case 0x03:
pclk = SystemFrequency/8;
break;
/* Bit 8,9 are for UART1 */
pclkdiv = (LPC_SC->PCLKSEL0 >> 8) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
break;
case 0x01:
break;
case 0x02:
break;
case 0x03:
break;
** Function name: UARTSend
** Descriptions: Send a block of data to the UART 0 port based
** on the data length
** parameters: portNum, buffer pointer, and data length
** Returned value: None
void UARTSend( uint32_t portNum, uint8_t *BufferPtr, uint32_t Length )
if ( portNum == 0 )
while ( Length != 0 )
/* THRE status, contain valid data */
while ( !(UART0TxEmpty & 0x01) );
LPC_UART0->THR = *BufferPtr;
UART0TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
while ( !(UART1TxEmpty & 0x01) );
LPC_UART1->THR = *BufferPtr;
UART1TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
return;
** End Of File
下面是我修改的:
* uart.c: UART API file for NXP LPC17xx Family Microprocessors
* Copyright(C) 2009, NXP Semiconductor
* All rights reserved.
* History
* 2009.05.27 ver 1.00 Prelimnary version, first Release
#include "lpc17xx.h"
#include "type.h"
#include "uart.h"
return;
UART0Count++;
UART0Count++;
UART0TxEmpty = 1;
UART0TxEmpty = 0;
return;
UART1Count++;
UART1Count++;
UART1TxEmpty = 1;
UART1TxEmpty = 0;
LSRValue = LPC_UART2->LSR;
UART2Status = LSRValue;
Dummy = LPC_UART2->RBR; /* Dummy read on RX to clear
return;
UART2Buffer[UART2Count] = LPC_UART2->RBR;
UART2Count++;
if ( UART2Count == BUFSIZE )
UART2Count = 0; /* buffer overflow */
UART2Count++;
UART2Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART2->LSR; /* Check status in the LSR to see if
UART2TxEmpty = 1;
UART2TxEmpty = 0;
LSRValue = LPC_UART3->LSR;
UART3Status = LSRValue;
Dummy = LPC_UART3->RBR; /* Dummy read on RX to clear
return;
UART3Buffer[UART3Count] = LPC_UART3->RBR;
UART3Count++;
if ( UART3Count == BUFSIZE )
UART3Count = 0; /* buffer overflow */
UART3Count++;
UART3Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART3->LSR; /* Check status in the LSR to see if
UART3TxEmpty = 1;
UART3TxEmpty = 0;
** VIC table
uint32_t Fdiv;
if ( PortNum == 0 )
switch ( pclkdiv )
case 0x00:
default:
break;
case 0x01:
break;
case 0x02:
break;
case 0x03:
break;
switch ( pclkdiv )
case 0x00:
default:
break;
case 0x01:
break;
case 0x02:
break;
case 0x03:
break;
/* Bit 16,17 are for UART2 */
pclkdiv = (LPC_SC->PCLKSEL1 >> 16) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
break;
case 0x01:
break;
case 0x02:
break;
case 0x03:
break;
pclkdiv = (LPC_SC->PCLKSEL1 >> 18) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
break;
case 0x01:
break;
case 0x02:
break;
case 0x03:
break;
if ( portNum == 0 )
BufferPtr++;
Length--;
else if ( portNum == 1 )
BufferPtr++;
Length--;
else if ( portNum == 2 )
while ( !(UART2TxEmpty & 0x01) );
LPC_UART2->THR = *BufferPtr;
UART2TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
while ( !(UART3TxEmpty & 0x01) );
LPC_UART3->THR = *BufferPtr;
UART3TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
return;
** End Of File
