Mbed Crypto is an open source cryptographic library that supports a wide range of cryptographic operations, including:
* Key management
* Hashing
* Symmetric cryptography
* Asymmetric cryptography
* Message authentication (MAC)
* Key generation and derivation
* Authenticated encryption with associated data (AEAD)
The Mbed Crypto library is a reference implementation of the cryptography interface of the Arm Platform Security Architecture (PSA). It is written in portable C.
The Mbed Crypto library is distributed under the Apache License, version 2.0.
#### Platform Security Architecture (PSA)
Arm's Platform Security Architecture (PSA) is a holistic set of threat models,
security analyses, hardware and firmware architecture specifications, and an open source firmware reference implementation. PSA provides a recipe, based on industry best practice, that enables you to design security into both hardware and firmware consistently. Part of the API provided by PSA is the cryptography interface, which provides access to a set of primitives.
### Using Mbed Crypto
* [Getting the Mbed Crypto library](#getting-the-mbed-crypto-library)
* [Building the Mbed Crypto library](#building-the-mbed-crypto-library)
* [Using the Mbed Crypto library](#using-the-mbed-crypto-library)
* [Importing a key](#importing-a-key)
* [Signing a message using RSA](#signing-a-message-using-RSA)
* [Encrypting or decrypting using symmetric ciphers](#encrypting-or-decrypting-using-symmetric-ciphers)
* [Hashing a message](#hashing-a-message)
* [Deriving a new key from an existing key](#deriving-a-new-key-from-an-existing-key)
* [Generating a random value](#generating-a-random-value)
* [Authenticating and encrypting or decrypting a message](#authenticating-and-encrypting-or-decrypting-a-message)
* [Generating and exporting keys](#generating-and-exporting-keys)
* [More about the Mbed Crypto library](#more-about-the-mbed-crypto-library)
**Prerequisites to building the library with the provided makefiles:**
* GNU Make.
* A C toolchain (compiler, linker, archiver).
* Python 2 or Python 3 (either works) to generate the test code.
* Perl to run the tests.
If you have a C compiler such as GCC or Clang, just run `make` in the top-level directory to build the library, a set of unit tests and some sample programs.
To select a different compiler, set the `CC` variable to the name or path of the compiler and linker (default: `cc`) and set `AR` to a compatible archiver (default: `ar`); for example:
make CC=arm-linux-gnueabi-gcc AR=arm-linux-gnueabi-ar
The provided makefiles pass options to the compiler that assume a GCC-like command line syntax. To use a different compiler, you may need to pass different values for `CFLAGS`, `WARNINGS_CFLAGS` and `LDFLAGS`.
To run the unit tests on the host machine, run `make test` from the top-level directory. If you are cross-compiling, copy the test executable from the `tests` directory to the target machine.
### Using the Mbed Crypto library
To use the Mbed Crypto APIs, call `psa_crypto_init()` before calling any other API. This initializes the library.
### Importing a key
To use a key for cryptography operations in Mbed Crypto, you need to first
import it. The import operation returns the identifier of the key for use
with other function calls.
**Prerequisites to importing keys:**
* Initialize the library with a successful call to `psa_crypto_init()`.
This example shows how to import a key:
```C
void import_a_key(const uint8_t *key, size_t key_len)
psa_status_t status;
psa_key_attributes_t attributes = PSA_KEY_ATTRIBUTES_INIT;
psa_key_id_t key_id;
printf("Import an AES key...\t");
fflush(stdout);
/* Initialize PSA Crypto */
status = psa_crypto_init();
if (status != PSA_SUCCESS) {
printf("Failed to initialize PSA Crypto\n");
return;
/* Import the key */
status = psa_import_key(&attributes, key, key_len, &key_id);
printf("Failed to import key\n");
return;
printf("Imported a key\n");
/* Free the attributes */
psa_reset_key_attributes(&attributes);
/* Destroy the key */
psa_destroy_key(key_id);
mbedtls_psa_crypto_free();
### Signing a message using RSA
Mbed Crypto supports encrypting, decrypting, signing and verifying messages using public key signature algorithms, such as RSA or ECDSA.
**Prerequisites to performing asymmetric signature operations:**
* Have a valid key with appropriate attributes set:
* Usage flag `PSA_KEY_USAGE_SIGN_HASH` to allow signing.
* Usage flag `PSA_KEY_USAGE_VERIFY_HASH` to allow signature verification.
* Algorithm set to the desired signature algorithm.
This example shows how to sign a hash that has already been calculated:
```C
void sign_a_message_using_rsa(const uint8_t *key, size_t key_len)
uint8_t hash[32] = {0x50, 0xd8, 0x58, 0xe0, 0x98, 0x5e, 0xcc, 0x7f,
0x60, 0x41, 0x8a, 0xaf, 0x0c, 0xc5, 0xab, 0x58,
0x7f, 0x42, 0xc2, 0x57, 0x0a, 0x88, 0x40, 0x95,
0xa9, 0xe8, 0xcc, 0xac, 0xd0, 0xf6, 0x54, 0x5c};
uint8_t signature[PSA_SIGNATURE_MAX_SIZE] = {0};
size_t signature_length;
printf("Sign a message...\t");
fflush(stdout);
return;
return;
/* Sign message using the key */
status = psa_sign_hash(key_id, PSA_ALG_RSA_PKCS1V15_SIGN_RAW,
hash, sizeof(hash),
signature, sizeof(signature),
&signature_length);
printf("Failed to sign\n");
return;
printf("Signed a message\n");
### Using symmetric ciphers
Mbed Crypto supports encrypting and decrypting messages using various symmetric cipher algorithms (both block and stream ciphers).
**Prerequisites to working with the symmetric cipher API:**
* Have a symmetric key. This key's usage flags must include `PSA_KEY_USAGE_ENCRYPT` to allow encryption or `PSA_KEY_USAGE_DECRYPT` to allow decryption.
**To encrypt a message with a symmetric cipher:**
1. Allocate an operation (`psa_cipher_operation_t`) structure to pass to the cipher functions.
1. Initialize the operation structure to zero or to `PSA_CIPHER_OPERATION_INIT`.
1. Call `psa_cipher_encrypt_setup()` to specify the algorithm and the key to be used.
1. Call either `psa_cipher_generate_iv()` or `psa_cipher_set_iv()` to generate or set the initialization vector (IV). We recommend calling `psa_cipher_generate_iv()`, unless you require a specific IV value.
1. Call `psa_cipher_update()` with the message to encrypt. You may call this function multiple times, passing successive fragments of the message on successive calls.
1. Call `psa_cipher_finish()` to end the operation and output the encrypted message.
This example shows how to encrypt data using an AES (Advanced Encryption Standard) key in CBC (Cipher Block Chaining) mode with no padding (assuming all prerequisites have been fulfilled):
```c
void encrypt_with_symmetric_ciphers(const uint8_t *key, size_t key_len)
enum {
block_size = PSA_BLOCK_CIPHER_BLOCK_LENGTH(PSA_KEY_TYPE_AES),
psa_algorithm_t alg = PSA_ALG_CBC_NO_PADDING;
uint8_t plaintext[block_size] = SOME_PLAINTEXT;
uint8_t iv[block_size];
size_t iv_len;
uint8_t output[block_size];
size_t output_len;
psa_cipher_operation_t operation = PSA_CIPHER_OPERATION_INIT;
printf("Encrypt with cipher...\t");
fflush(stdout);
return;
/* Import a key */
psa_set_key_usage_flags(&attributes, PSA_KEY_USAGE_ENCRYPT);
psa_set_key_algorithm(&attributes, alg);
psa_set_key_type(&attributes, PSA_KEY_TYPE_AES);
psa_set_key_bits(&attributes, 128);
printf("Failed to import a key\n");
return;
/* Encrypt the plaintext */
status = psa_cipher_encrypt_setup(&operation, key_id, alg);
printf("Failed to begin cipher operation\n");
return;
status = psa_cipher_generate_iv(&operation, iv, sizeof(iv), &iv_len);
printf("Failed to generate IV\n");
return;
status = psa_cipher_update(&operation, plaintext, sizeof(plaintext),
output, sizeof(output), &output_len);
printf("Failed to update cipher operation\n");
return;
status = psa_cipher_finish(&operation, output + output_len,
sizeof(output) - output_len, &output_len);
printf("Failed to finish cipher operation\n");
return;
printf("Encrypted plaintext\n");
/* Clean up cipher operation context */
psa_cipher_abort(&operation);
**To decrypt a message with a symmetric cipher:**
1. Call `psa_cipher_decrypt_setup()` to specify the algorithm and the key to be used.
1. Call `psa_cipher_set_iv()` with the IV for the decryption.
1. Call `psa_cipher_finish()` to end the operation and output the decrypted message.
This example shows how to decrypt encrypted data using an AES key in CBC mode with no padding
```c
void decrypt_with_symmetric_ciphers(const uint8_t *key, size_t key_len)
enum {
uint8_t ciphertext[block_size] = SOME_CIPHERTEXT;
uint8_t iv[block_size] = ENCRYPTED_WITH_IV;
size_t output_len;
printf("Decrypt with cipher...\t");
fflush(stdout);
return;
/* Import a key */
psa_set_key_usage_flags(&attributes, PSA_KEY_USAGE_DECRYPT);
return;
/* Decrypt the ciphertext */
status = psa_cipher_decrypt_setup(&operation, key_id, alg);
return;
status = psa_cipher_set_iv(&operation, iv, sizeof(iv));
printf("Failed to set IV\n");
return;
status = psa_cipher_update(&operation, ciphertext, sizeof(ciphertext),
return;
return;
printf("Decrypted ciphertext\n");
#### Handling cipher operation contexts
After you've initialized the operation structure with a successful call to `psa_cipher_encrypt_setup()` or `psa_cipher_decrypt_setup()`, you can terminate the operation at any time by calling `psa_cipher_abort()`.
The call to `psa_cipher_abort()` frees any resources associated with the operation, except for the operation structure itself.
Mbed Crypto implicitly calls `psa_cipher_abort()` when:
* A call to `psa_cipher_generate_iv()`, `psa_cipher_set_iv()` or `psa_cipher_update()` fails (returning any status other than `PSA_SUCCESS`).
* A call to `psa_cipher_finish()` succeeds or fails.
After an implicit or explicit call to `psa_cipher_abort()`, the operation structure is invalidated; in other words, you cannot reuse the operation structure for the same operation. You can, however, reuse the operation structure for a different operation by calling either `psa_cipher_encrypt_setup()` or `psa_cipher_decrypt_setup()` again.
You must call `psa_cipher_abort()` at some point for any operation that is initialized successfully (by a successful call to `psa_cipher_encrypt_setup()` or `psa_cipher_decrypt_setup()`).
Making multiple sequential calls to `psa_cipher_abort()` on an operation that is terminated (either implicitly or explicitly) is safe and has no effect.
### Hashing a message
Mbed Crypto lets you compute and verify hashes using various hashing
algorithms.
**Prerequisites to working with the hash APIs:**
**To calculate a hash:**
1. Allocate an operation structure (`psa_hash_operation_t`) to pass to the hash functions.
1. Initialize the operation structure to zero or to `PSA_HASH_OPERATION_INIT`.
1. Call `psa_hash_setup()` to specify the hash algorithm.
1. Call `psa_hash_update()` with the message to encrypt. You may call this function multiple times, passing successive fragments of the message on successive calls.
1. Call `psa_hash_finish()` to calculate the hash, or `psa_hash_verify()` to compare the computed hash with an expected hash value.
This example shows how to calculate the SHA-256 hash of a message:
```c
psa_algorithm_t alg = PSA_ALG_SHA_256;
psa_hash_operation_t operation = PSA_HASH_OPERATION_INIT;
unsigned char input[] = { 'a', 'b', 'c' };
unsigned char actual_hash[PSA_HASH_MAX_SIZE];
size_t actual_hash_len;
printf("Hash a message...\t");
fflush(stdout);
return;
/* Compute hash of message */
status = psa_hash_setup(&operation, alg);
printf("Failed to begin hash operation\n");
return;
status = psa_hash_update(&operation, input, sizeof(input));
printf("Failed to update hash operation\n");
return;
status = psa_hash_finish(&operation, actual_hash, sizeof(actual_hash),
&actual_hash_len);
printf("Failed to finish hash operation\n");
return;
printf("Hashed a message\n");
/* Clean up hash operation context */
psa_hash_abort(&operation);
return;
/* Verify message hash */
return;
return;
status = psa_hash_verify(&operation, expected_hash, expected_hash_len);
printf("Failed to verify hash\n");
return;
printf("Verified a hash\n");
The API provides the macro `PSA_HASH_LENGTH`, which returns the expected hash length (in bytes) for the specified algorithm.
#### Handling hash operation contexts
After a successful call to `psa_hash_setup()`, you can terminate the operation at any time by calling `psa_hash_abort()`. The call to `psa_hash_abort()` frees any resources associated with the operation, except for the operation structure itself.
Mbed Crypto implicitly calls `psa_hash_abort()` when:
1. A call to `psa_hash_update()` fails (returning any status other than `PSA_SUCCESS`).
1. A call to `psa_hash_finish()` succeeds or fails.
1. A call to `psa_hash_verify()` succeeds or fails.
After an implicit or explicit call to `psa_hash_abort()`, the operation structure is invalidated; in other words, you cannot reuse the operation structure for the same operation. You can, however, reuse the operation structure for a different operation by calling `psa_hash_setup()` again.
You must call `psa_hash_abort()` at some point for any operation that is initialized successfully (by a successful call to `psa_hash_setup()`) .
Making multiple sequential calls to `psa_hash_abort()` on an operation that has already been terminated (either implicitly or explicitly) is safe and has no effect.
### Generating a random value
Mbed Crypto can generate random data.
**Prerequisites to generating random data:**
<span class="notes">**Note:** To generate a random key, use `psa_generate_key()` instead of `psa_generate_random()`.</span>
This example shows how to generate ten bytes of random data by calling `psa_generate_random()`:
```C
uint8_t random[10] = { 0 };
printf("Generate random...\t");
fflush(stdout);
return;
status = psa_generate_random(random, sizeof(random));
printf("Failed to generate a random value\n");
return;
printf("Generated random data\n");
/* Clean up */
### Deriving a new key from an existing key
Mbed Crypto provides a key derivation API that lets you derive new keys from
existing ones. The key derivation API has functions to take inputs, including
other keys and data, and functions to generate outputs, such as new keys or
other data.
You must first initialize and set up a key derivation context,
provided with a key and, optionally, other data. Then, use the key derivation context to either read derived data to a buffer or send derived data directly to a key slot.
See the documentation for the particular algorithm (such as HKDF or the TLS1.2 PRF) for
information about which inputs to pass when, and when you can obtain which outputs.
**Prerequisites to working with the key derivation APIs:**
* Use a key with the appropriate attributes set:
* Usage flags set for key derivation (`PSA_KEY_USAGE_DERIVE`)
* Key type set to `PSA_KEY_TYPE_DERIVE`.
* Algorithm set to a key derivation algorithm
(for example, `PSA_ALG_HKDF(PSA_ALG_SHA_256)`).
**To derive a new AES-CTR 128-bit encryption key into a given key slot using HKDF
with a given key, salt and info:**
1. Set up the key derivation context using the `psa_key_derivation_setup()`
function, specifying the derivation algorithm `PSA_ALG_HKDF(PSA_ALG_SHA_256)`.
1. Provide an optional salt with `psa_key_derivation_input_bytes()`.
1. Provide info with `psa_key_derivation_input_bytes()`.
1. Provide a secret with `psa_key_derivation_input_key()`, referencing a key that
can be used for key derivation.
1. Set the key attributes desired for the new derived key. We'll set
the `PSA_KEY_USAGE_ENCRYPT` usage flag and the `PSA_ALG_CTR` algorithm for this
example.
1. Derive the key by calling `psa_key_derivation_output_key()`.
1. Clean up the key derivation context.
printf("Derive a key (HKDF)...\t");
fflush(stdout);
return;
/* Import a key for use in key derivation. If such a key has already been
* generated or imported, you can skip this part. */
psa_set_key_usage_flags(&attributes, PSA_KEY_USAGE_DERIVE);
psa_set_key_type(&attributes, PSA_KEY_TYPE_DERIVE);
status = psa_import_key(&attributes, key, sizeof(key), &base_key);
return;
/* Derive a key */
status = psa_key_derivation_setup(&operation, alg);
printf("Failed to begin key derivation\n");
return;
status = psa_key_derivation_set_capacity(&operation, capacity);
printf("Failed to set capacity\n");
return;
status = psa_key_derivation_input_bytes(&operation,
PSA_KEY_DERIVATION_INPUT_SALT,
salt, sizeof(salt));
printf("Failed to input salt (extract)\n");
return;
status = psa_key_derivation_input_key(&operation,
PSA_KEY_DERIVATION_INPUT_SECRET,
base_key);
printf("Failed to input key (extract)\n");
return;
PSA_KEY_DERIVATION_INPUT_INFO,
info, sizeof(info));
printf("Failed to input info (expand)\n");
return;
psa_set_key_algorithm(&attributes, PSA_ALG_CTR);
status = psa_key_derivation_output_key(&attributes, &operation,
&derived_key);
printf("Failed to derive key\n");
return;
printf("Derived key\n");
/* Clean up key derivation operation */
psa_key_derivation_abort(&operation);
/* Destroy the keys */
psa_destroy_key(derived_key);
psa_destroy_key(base_key);
### Authenticating and encrypting or decrypting a message
Mbed Crypto provides a simple way to authenticate and encrypt with associated data (AEAD), supporting the `PSA_ALG_CCM` algorithm.
**Prerequisites to working with the AEAD cipher APIs:**
* The key attributes for the key used for derivation must have the `PSA_KEY_USAGE_ENCRYPT` or `PSA_KEY_USAGE_DECRYPT` usage flags.
return;
output_size = sizeof(input_data);
output_data = (uint8_t *)malloc(output_size);
if (!output_data) {
printf("Out of memory\n");
return;
/* Import a key */
psa_set_key_algorithm(&attributes, PSA_ALG_CCM);
status = psa_import_key(&attributes, key_data, sizeof(key_data), &key_id);
return;
/* Authenticate and decrypt */
status = psa_aead_decrypt(key_id, PSA_ALG_CCM,
nonce, sizeof(nonce),
additional_data, sizeof(additional_data),
input_data, sizeof(input_data),
output_data, output_size,
&output_length);
printf("Failed to authenticate and decrypt %ld\n", status);
return;
printf("Authenticated and decrypted\n");
/* Clean up */
free(output_data);
### Generating and exporting keys
Mbed Crypto provides a simple way to generate a key or key pair.
**Prerequisites to using key generation and export APIs:**
**To generate an ECDSA key:**
1. Set the desired key attributes for key generation by calling
`psa_set_key_algorithm()` with the chosen ECDSA algorithm (such as
`PSA_ALG_DETERMINISTIC_ECDSA(PSA_ALG_SHA_256)`). You only want to export the public key, not the key pair (or private key); therefore, do not set `PSA_KEY_USAGE_EXPORT`.
1. Generate a key by calling `psa_generate_key()`.
1. Export the generated public key by calling `psa_export_public_key()`:
```C
enum {
key_bits = 256,
size_t exported_length = 0;
static uint8_t exported[PSA_KEY_EXPORT_ECC_PUBLIC_KEY_MAX_SIZE(key_bits)];
printf("Generate a key pair...\t");
fflush(stdout);
return;
/* Generate a key */
psa_set_key_usage_flags(&attributes, PSA_KEY_USAGE_SIGN_HASH);
PSA_ALG_DETERMINISTIC_ECDSA(PSA_ALG_SHA_256));
PSA_KEY_TYPE_ECC_KEY_PAIR(PSA_ECC_FAMILY_SECP_R1));
psa_set_key_bits(&attributes, key_bits);
status = psa_generate_key(&attributes, &key_id);
printf("Failed to generate key\n");
return;
status = psa_export_public_key(key_id, exported, sizeof(exported),
&exported_length);
printf("Failed to export public key %ld\n", status);
return;
