回复: 9
马老师,麻烦给钦点一下,状态机按键,逼上绝路了!!
发表于 2010-7-3 11:02:12 | 显示全部楼层 |阅读模式
小弟的程序,基于状态机的4*4键盘,最简单的想按键弹起时返回键值,但是看了老久了,就是找不出毛病,麻烦给看看吧,快疯了!!!
#define uchar unsigned char
#define uint unsigned int
#define     NO_KEY           0x00
#define key_k1 '1'
#define key_k2 '2'
#define key_k3 '3'
#define key_k4 '4'
#define key_k5 '5'
#define key_k6 '6'
#define key_k7 '7'
#define key_k8 '8'
#define key_k9 '9'
#define key_k0 '0'
#define key_k10 'A'
#define key_k11 'B'
#define key_k12 'C'
#define key_k13 'D'
#define key_k14 'E'
#define key_k15 'F'
char Key_time_ok;
void initialize_timer(void)
     TCNT0=0x00; // {(0xff-0x70)+1}*1024*(1/14.7456MHz)=10ms
TCCR0=0x06; // 定时器0 prescaler=1024
TIMSK=0x01; // OCIE0=1,定时器0溢出标志
SREG = 0x80;          //使能全局中断
#pragma interrupt_handler timer0:17
void timer0(void)
  TCNT0=0x00;
  Key_time_ok=1;
uchar GetKeyCode(void)
        uchar i;
        DDRC=0xf0; //高4位输出,低4位输入
    PORTC=0x0f;//高4位输出0,低4位带上拉输入
    //delay_nms(1);
    waitsomeNOP();   //等待8个时钟周期(NOP)
    i=PINC&0x0f;
    /*获取行地址*/
    DDRC=0x0f;//高4位输入,低4位输出
    PORTC=0xf0;//低4位输出0,高4位带上拉输入
    //delay_nms(1);
        waitsomeNOP();
    i|=PINC&0xf0;
return i;
uchar get_key(void)
    static char KeyState   = 0;        //按键状态
    static char KeyPrev1   = 0;        //上一次按键
static char KeyPrev    = 0;        //新一次按键
    char KeyPress  = NO_KEY;           //按键值
    char KeyReturn = NO_KEY;           //按键返回值
    KeyPress = GetKeyCode();
    switch(KeyState)
        //按键初始态00
        case 0:
            if( KeyPress !=NO_KEY )
                KeyState = 1;
KeyPrev1  = KeyPress;
            break;
        //按键确认态01
        case 1:
                //与上次按键不同,是乱码
                if(KeyPrev1  != KeyPress)
                    KeyState  = 0;
                    KeyState  = 2;
        switch (KeyPress)                        // 与状态1的相同,确认按键
                        {              // 键盘编码,返回编码值
                           case 0Xdb: KeyPrev = key_k0; break;
   case 0X77: KeyPrev = key_k1; break;
                           case 0X7b: KeyPrev = key_k2; break;
                           case 0X7d: KeyPrev = key_k3; break;
                           case 0X7e: KeyPrev = key_k4; break;
                           case 0Xb7: KeyPrev = key_k5; break;
                           case 0Xbb: KeyPrev = key_k6; break;
                           case 0Xbd: KeyPrev = key_k7; break;
                           case 0Xbe: KeyPrev = key_k8; break;
                           case 0Xd7: KeyPrev = key_k9; break;
                           case 0Xdd: KeyPrev = key_k10;break;
                           case 0Xde: KeyPrev = key_k11;break;
                           case 0Xe7: KeyPrev = key_k12;break;
                           case 0Xeb: KeyPrev = key_k13;break;
                           case 0Xed: KeyPrev = key_k14;break;
   case 0Xee: KeyPrev = key_k15;break;
   default :break;
            {//按键抬起,是抖动,不响应按键
                KeyState = 0;
            break;
        //按键释放态10
        case 2:
            if(KeyPress == NO_KEY )
                KeyState   = 0;
                KeyReturn  =  KeyPrev;             //返回按键抬起值
            break;
        default :break;
return KeyReturn;
void main()
  initialize_timer();
       Uchar MMtemp;
       if(Key_time_ok==1)
            Key_time_ok=0;
    MMtemp=get_key();           //有按键按下时
    if(MMtemp=='1')
    sendbyte(0xff);
发表于 2014-2-12 09:45:27 | 显示全部楼层
sbk100 发表于 2014-2-11 14:25
你先去学学static的用法吧
哦,不好意思,没注意后面的        case 0:
                KeyState = 1;
发表于 2014-2-11 14:25:00 | 显示全部楼层
const_J 发表于 2014-2-11 09:13
有一个地方,我没看懂
uchar get_key(void)
你先去学学static的用法吧
发表于 2014-2-11 09:13:49 | 显示全部楼层
有一个地方,我没看懂
uchar get_key(void)
    switch(KeyState)
        //按键初始态00
        case 0:
                KeyState = 1;
KeyState           初始化为0,之后没有被修改过。switch语句永远执行   case 0:      ,你再怎么按,都不会有反应
发表于 2013-12-23 10:09:20 | 显示全部楼层
状态机学习。。。。
发表于 2013-10-8 11:47:37 | 显示全部楼层
状态机学习中
发表于 2010-7-6 15:14:17 | 显示全部楼层
马老师的按键状态机如下:
    状态0:
       按键输出;
              NOP();
              NOP();
       按键输出;
              读键端口
          if (有按键按下)
                  转状态1
    状态1:
       读键端口
          if (前后两次相同)
                  置按键标志
                  转状态2,等等按键释放
         转状态0
    状态2:
       按键输出;
              读键端口
       if (按键已经释放)  ---> 读到的按键值==NO_KEY
         转状态0
    你仔细对照一下,程序是否和上面的状态机一致?
发表于 2010-7-4 15:00:53 | 显示全部楼层
。。。不想说  也没工夫看你程序
发表于 2010-7-3 13:32:04 | 显示全部楼层
回复【楼主位】june2008
马老师,小弟的程序………………
马老大,学生的程序………………
就这么搭配。
发表于 2010-7-3 13:17:43 | 显示全部楼层
先检查你连线有没有错误,再一个你的问题是什么?
GMT+8, 2024-5-6 21:11
