回复: 15
新手qtouch问题
发表于 2012-5-5 21:11:47 | 显示全部楼层
Gorgon_Meducer 发表于 2011-8-23 13:10
官方用户手册下载了么?
官方用户手册有一步一步来的设置介绍。感觉你是没有正确配置阿。 ...
能不能教教我,AVR和Qtouch,点亮一个灯的程序,我用的是ATmega16A
初学者,见谅
发表于 2012-5-7 10:53:20 | 显示全部楼层
#include <avr/io.h>
#include <avr/interrupt.h>
#define __delay_cycles(10)     __builtin_avr_delay_cycles(10)
#define __enable_interrupt()  sei()
/*  now include touch api.h with the localization defined above */
#include "touch_api.h"
                            manifest constants
                            type definitions
                                prototypes
/*  initialise host app, pins, watchdog, etc    */
static void init_system( void );
/*  configure timer ISR to fire regularly   */
static void init_timer_isr( void );
/*  Assign the parameters values to global configuration parameter structure    */
static void qt_set_parameters( void );
/*  Configure the sensors */
static void config_sensors(void);
/*  Configure the sensors for  Keys configuration */
    static void config_keys(void);
                            Structure Declarations
                                    macros
#define GET_SENSOR_STATE(SENSOR_NUMBER) qt_measure_data.qt_touch_status.sensor_states[(SENSOR_NUMBER/8)] & (1 << (SENSOR_NUMBER % 8))
#define GET_ROTOR_SLIDER_POSITION(ROTOR_SLIDER_NUMBER) qt_measure_data.qt_touch_status.rotor_slider_values[ROTOR_SLIDER_NUMBER]
                                global variables
/* Timer period in msec. */
uint16_t qt_measurement_period_msec = 25u;
                                extern variables
/* This configuration data structure parameters if needs to be changed will be
   changed in the qt_set_parameters function */
extern qt_touch_lib_config_data_t qt_config_data;
/* touch output - measurement data */
extern qt_touch_lib_measure_data_t qt_measure_data;
/* Get sensor delta values */
extern int16_t qt_get_sensor_delta( uint8_t sensor);
                                static variables
/* flag set by timer ISR when it's time to measure touch */
static volatile uint8_t time_to_measure_touch = 0u;
/* current time, set by timer ISR */
static volatile uint16_t current_time_ms_touch = 0u;
Purpose :   main code entry point
Input   :   n/a
Output  :   n/a
Notes   :
int main( void )
    /*status flags to indicate the re-burst for library*/
    uint16_t status_flag = 0u;
    uint16_t burst_flag = 0u;
    init_system();
    /* Configure the Sensors as keys or Keys With Rotor/Sliders in this function */
    config_sensors();
    /* initialise touch sensing */
    qt_init_sensing();
    /*  Set the parameters like recalibration threshold, Max_On_Duration etc in this function by the user */
    qt_set_parameters( );
    init_timer_isr();
    /*  Address to pass address of user functions   */
    /*  This function is called after the library has made capacitive measurements,
    *   but before it has processed them. The user can use this hook to apply filter
    *   functions to the measured signal values.(Possibly to fix sensor layout faults)    */
    qt_filter_callback = 0;
    /* enable interrupts */
    __enable_interrupt();
// /* loop forever */
//    for( ; ; )
//        if( time_to_measure_touch )
            /*  clear flag: it's time to measure touch  */
//            time_to_measure_touch = 0u;
//            do {
                /*  one time measure touch sensors    */
//                status_flag = qt_measure_sensors( current_time_ms_touch );
//               burst_flag = status_flag & QTLIB_BURST_AGAIN;
  /* Time-critical host application code goes here */
//                   }while (burst_flag) ;
  /*  Time Non-critical host application code goes here  */
                                        qt_measure_sensors( current_time_ms_touch) ;
                if(qt_measure_data.qt_touch_status.sensor_states[0]&0x01)
                         PORTC&=~(1<<PC0);//A灯亮
                         PORTC|=(1<<PC0);//A灯灭
Purpose :   Configure the sensors
Input   :   n/a
Output  :   n/a
Notes   :   n/a
        config_keys();
Purpose :   Configure the sensors as keys only
Input   :   n/a
Output  :   n/a
Notes   :   n/a
    /*  enable sensors 0..3: keys on channels 0..3  */
    qt_enable_key( CHANNEL_0, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_1, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_2, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_3, AKS_GROUP_1, 10u, HYST_6_25 );
    /*  enable sensors 4..7: keys on channels 4..7   */
    qt_enable_key( CHANNEL_4, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_5, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_6, AKS_GROUP_1, 10u, HYST_6_25 );
    qt_enable_key( CHANNEL_7, AKS_GROUP_1, 10u, HYST_6_25 );
Purpose :   initialise host app, pins, watchdog, etc
Input   :   n/a
Output  :   n/a
Notes   :
    /*  disable pull-ups    */
    MCUCR |= (1u << PUD);
Purpose :   timer 1 compare ISR
Input   :   n/a
Output  :   n/a
Notes   :
ISR(TIMER1_COMPA_vect)
    /*  set flag: it's time to measure touch    */
    time_to_measure_touch = 1u;
    /*  update the current time */
    current_time_ms_touch += qt_measurement_period_msec;
Purpose :   This will fill the default threshold values in the configuration
            data structure.But User can change the values of these parameters .
Input   :   n/a
Output  :   n/a
Notes   :   initialize configuration data for processing
    /*  This will be modified by the user to different values   */
    qt_config_data.qt_di              = DEF_QT_DI;
    qt_config_data.qt_neg_drift_rate  = DEF_QT_NEG_DRIFT_RATE;
    qt_config_data.qt_pos_drift_rate  = DEF_QT_POS_DRIFT_RATE;
    qt_config_data.qt_max_on_duration = DEF_QT_MAX_ON_DURATION;
    qt_config_data.qt_drift_hold_time = DEF_QT_DRIFT_HOLD_TIME;
    qt_config_data.qt_recal_threshold = DEF_QT_RECAL_THRESHOLD;
    qt_config_data.qt_pos_recal_delay = DEF_QT_POS_RECAL_DELAY;
编译之后是:
Build started 7.5.2012 at 10:50:08
avr-gcc -I"C:\Program Files\Atmel\Atmel_QTouch_Libraries_4.4\Generic_QTouch_Libraries\include" -I"C:\Program Files\Atmel\Atmel_QTouch_Libraries_4.4\Generic_QTouch_Libraries\debug" -I"C:\Program Files\Atmel\Atmel_QTouch_Libraries_4.4\Generic_QTouch_Librarie
s\AVR_Tiny_Mega_XMega\QTouch\common_files" -I"C:\Program Files\Atmel\Atmel_QTouch_Libraries_4.4\Generic_QTouch_Libraries\AVR_Tiny_Mega_XMega\QTouch\library_files"  -mmcu=atmega16 -Wall -gdwarf-2 -std=gnu99 -DQT_DELAY_CYCLES=1 -D_QTOUCH_ -DSNSK1=A -DQT_NUM_
CHANNELS=8 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums  -DSNS1=A -Wp,-M,-MP,-MT,11111.o,-MF,dep/11111.o.d  -c   ../11111.c -o 11111.o
../11111.c:45:24: "10" may not appear in macro parameter list
../11111.c: In function `main':
../11111.c:133: warning: unused variable `status_flag'
../11111.c:134: warning: unused variable `burst_flag'
../11111.c: At top level:
../11111.c:282: warning: return type defaults to `int'
../11111.c: In function `ISR':
../11111.c:282: warning: type of "TIMER1_COMPA_vect" defaults to "int"
../11111.c:288: warning: control reaches end of non-void function
../11111.c:67: warning: 'init_timer_isr' used but never defined
make: *** [11111.o] Error 1
Build failed with 1 errors and 6 warnings...
不知道哪儿错了,怎么改?
GMT+8, 2024-5-2 19:09
