回复: 6
Marvell 88MC200 + 8787 这个平台有人熟悉吗?
发表于 2014-5-10 18:25:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我们想在这个平台上做产品,不知道这个平台开发资料全吗?有没有什么问题
主要应用是蓝牙+WIFI
有Marvell 号称的SoC吗?Marvell Easy-Connect Software
Marvell Easy-Connect Software provides a feature-rich software stack enables OEMs to focus on application-specific software functionality, thus enabling rapid development and reduced software development costs and risks. Marvell Easy-Connect Software SDK includes:
88MC200 SoC support and Peripheral Drivers
FreeRTOS Operating system.
LwIP Embedded TCP/IP Networking stack supporting TCP/IP v4/IPv6 networking with BSD-socket API’s.
OS and networking abstraction layer allowing alternate RTOS and TCP/IP stack usage.
A complete Wi-Fi driver and stack supporting Wi-Fi client mode (802.11 b/g/n and 802.11a depending on the chipset), Wi-Fi Micro-AP mode (supporting 5-10 clients depending on the chipset used), Simultaneous AP/Client mode, Antenna Diversity, WPA-2 PSK security, WPA-2 Enterprise security with EAP-TLS, WPS, and Wi-Fi Direct (P2P), Wake-on-WLAN, and full Wi-Fi power-management.
Power Management Framework simplifying development of low-power applications
Overlay manager to enable more efficient memory usage
Flash storage API, Persistent Storage Manager to store key-value pairs, Read-only file system to serve web-apps, and Flash partition manager to enable flexible partitioning of flash supporting application-specific use-cases.
Advanced networking middleware including DHCP server, HTTP client, HTTP server, Bonjour (mDNS/DNS-SD) responder and querier, and Web-sockets
Cryptography Library, AES and CRC, and TLS/SSL Library supporting TLS v1.2 (client and server mode).
JSON and XML parsers
Marvell Provisioning Framework to sample provisioning applications on Android and iOS to support simple setup of Wi-Fi devices using Mirco-AP mode with web-server, or using Sniffer mode.
Apple’s Wireless Accessory Configuration feature using Apple-licensed MFi technology for simplified out-of-the box setup of Wi-Fi devices.
Marvell application framework to simplify application development.
Debugging and Development support including serial-console, command-line shell, and support for obtaining information system information like threads, sockets, heap usage, etc.
Over-the-air (OTA) Firmware upgrade support
Easy command line Make based build system utilizing GNU ARM Toolchain.
Support for IAR to develop applications.
OpenOCD support for JTAG operations including flashing, loading code into RAM, flashing etc.
Flash programming tools over JTAG and Serial.
Support for Linux, Windows (Cygwin) and MacOS as host-development platforms
Support for Eclipse IDE with CDT including JTAG based debugging with integrated Eclipse debugger and GDB
Sample applications illustrating usage model for different features and API’s.
Complete production-ready reference applications
Support for Wi-Fi testing, and applications to test in manufacturing and certifications.
User-guide and complete reference documentation
Serial-to-Wi-Fi Firmware application that can be used as-is, or customized as appropriate.
Integrated support for a growing number of Cloud partners
Support built in Segger JFLASH for production
 楼主| 发表于 2014-6-10 14:58:10 | 只看该作者
我的QQ,欢迎一起讨论
发表于 2014-6-10 16:01:19 | 只看该作者
北京可以联系 中电器材
 楼主| 发表于 2014-6-13 14:27:01 | 只看该作者
我的 koukou 15341613 一起讨论
欢迎大家来加入。一起讨论,BTW,我刚下载了MC200的SDK正在研究
发表于 2014-6-13 14:28:40 | 只看该作者
tedyyan 发表于 2014-6-13 14:27
我建了一个QQ群名称是Marvell嵌入式开发 157810776
欢迎大家来加入。一起讨论,BTW,我刚下载了MC200的SDK ...
赶紧删了吧
小心ID不保
发表于 2015-1-20 15:00:31 | 只看该作者
MC200的SDK在哪儿找的? 官网上没看到,麻烦给个链接
发表于 2015-1-20 17:20:25 | 只看该作者
晓得了  要签NDA  。。。。过了苹果认证应该可以拿到了
GMT+8, 2024-5-7 11:14
