回复: 27
[原创/开源]重写AD7124驱动,所有寄存器可直接单独配置
出0入53汤圆
发表于 2020-7-31 21:41:41 | 显示全部楼层
这个芯片稳定性怎么样,lz出货了多少这种芯片?
出0入53汤圆
发表于 2020-8-4 08:02:48 | 显示全部楼层
bolizhicheng204 发表于 2020-7-31 10:29
没仔细看,目测应该没有问题,ADI的手册数据非常可信,我按照全功率最大速度跑,测量外部2.5V基准,不做 ...
增加遇到AD779x系列的都容易 芯片无数据输出,彻底放弃了AD779X系类
出0入53汤圆
发表于 2020-8-4 08:04:38 | 显示全部楼层
ersha4877 发表于 2020-8-3 21:18
有ADS1220的STM32F030的驱动,最近在搞,有点搞不定,谢谢
在stm32f103上测试成功的
  1. #include "includes.h"
  2. #define ADS1x20_CS_GPIO                        GPIOD
  3. #define ADS1x20_SCLK_GPIO                GPIOD
  4. #define ADS1x20_DIN_GPIO                GPIOD
  5. #define ADS1x20_DOUT_GPIO                GPIOD
  6. #define ADS1x20_CS_Pin                        GPIO_Pin_12
  7. #define ADS1x20_SCLK_Pin                GPIO_Pin_11
  8. #define ADS1x20_DIN_Pin                        GPIO_Pin_13
  9. #define ADS1x20_DOUT_Pin                GPIO_Pin_14
  10. #define ADS1x20_CS_Out(x)                x?GPIO_SetBits(ADS1x20_CS_GPIO,ADS1x20_CS_Pin):GPIO_ResetBits(ADS1x20_CS_GPIO,ADS1x20_CS_Pin)
  11. #define ADS1x20_SCLK_Out(x)                x?GPIO_SetBits(ADS1x20_SCLK_GPIO,ADS1x20_SCLK_Pin):GPIO_ResetBits(ADS1x20_SCLK_GPIO,ADS1x20_SCLK_Pin)
  12. #define ADS1x20_DIN_Out(x)                x?GPIO_SetBits(ADS1x20_DIN_GPIO,ADS1x20_DIN_Pin):GPIO_ResetBits(ADS1x20_DIN_GPIO,ADS1x20_DIN_Pin)
  13. #define ADS1x20_DOUT_Get                GPIO_ReadInputDataBit(ADS1x20_DOUT_GPIO, ADS1x20_DOUT_Pin)
  14. void ADS1x20_Delay(unsigned short x)//单位1us
  15. {
  16.         Delay_us(x);
  17. }
  18. void ADS1x20_Init(void)
  19. {
  20.         GPIO_InitTypeDef GPIO_InitStructure;
  21.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE );
  22.
  23.         //CS
  24.         GPIO_InitStructure.GPIO_Pin = ADS1x20_CS_Pin;
  25.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  26.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.           GPIO_Init(ADS1x20_CS_GPIO, &GPIO_InitStructure);
  28.         //SCLK
  29.         GPIO_InitStructure.GPIO_Pin = ADS1x20_SCLK_Pin;
  30.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  31.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.           GPIO_Init(ADS1x20_SCLK_GPIO, &GPIO_InitStructure);
  33.         //DIN
  34.         GPIO_InitStructure.GPIO_Pin = ADS1x20_DIN_Pin;
  35.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  36.           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  37.           GPIO_Init(ADS1x20_DIN_GPIO, &GPIO_InitStructure);
  38.         //DOUT
  39.         GPIO_InitStructure.GPIO_Pin = ADS1x20_DOUT_Pin;
  40.           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  41.           GPIO_Init(ADS1x20_DOUT_GPIO, &GPIO_InitStructure);
  42. }
  43. //读写ADS1x20
  44. //short:芯片配置
  45. //Chip:芯片内的配置返回
  46. //return:ReadData
  47. unsigned char ADS1x20_ReadWirte(unsigned char Config)
  48. {
  49. unsigned char i;
  50. unsigned short config=0,//配置
  51.                            data=0;//读取ADC
  52. //        ADS1x20_CS_Out(0);
  53.         config = Config;
  54.         for(i=0;i<8;i++)
  55.         {
  56.                 //ADS1x20_Delay(1);
  57.                 ADS1x20_SCLK_Out(1);
  58.                 if(config&0x80)
  59.                 {
  60.                         ADS1x20_DIN_Out(1);
  61.                 }
  62.                 else
  63.                 {
  64.                         ADS1x20_DIN_Out(0);
  65.                 }
  66.                 //ADS1x20_Delay(1);
  67.                 ADS1x20_SCLK_Out(0);
  68.                 data = data<<1;
  69.                 if(ADS1x20_DOUT_Get)
  70.                 {
  71.                         data++;
  72.                 }
  73.
  74.                 config = config<<1;
  75.         }
  76. //        ADS1x20_CS_Out(1);
  77.         return data;
  78. }
  79. //ADS1x20读取AD数据
  80. void ADS1x20_ReadData(unsigned char*Data)
  81. {
  82.         ADS1x20_CS_Out(0);
  83.         ADS1x20_ReadWirte(ADS1x20_RDATA);
  84. #ifdef ADS1120
  85.         *Data++ = ADS1x20_ReadWirte(0xFF);
  86.         *Data++ = ADS1x20_ReadWirte(0xFF);
  87. #else //ADS1220
  88.         *Data++ = ADS1x20_ReadWirte(0xFF);
  89.         *Data++ = ADS1x20_ReadWirte(0xFF);
  90.         *Data++ = ADS1x20_ReadWirte(0xFF);
  91.         *Data++ = ADS1x20_ReadWirte(0xFF);
  92. #endif
  93.         ADS1x20_CS_Out(1);
  94. }
  95. //ADS1x20复位
  96. void ADS1x20_Reset(void)
  97. {
  98.         ADS1x20_CS_Out(0);
  99.         ADS1x20_ReadWirte(ADS1x20_RESET);
  100.         ADS1x20_CS_Out(1);
  101. }
  102. //ADS1x20发送开始转换
  103. void ADS1x20_StartConversion(void)
  104. {
  105.         ADS1x20_CS_Out(0);
  106.         ADS1x20_ReadWirte(ADS1x20_START);
  107.         ADS1x20_CS_Out(1);
  108. }
  109. //低功耗
  110. void ADS1x20_PowerDown(void)
  111. {
  112.     ADS1x20_CS_Out(0);
  113.         ADS1x20_ReadWirte(ADS1x20_POWERDOWN);
  114.         ADS1x20_CS_Out(1);
  115. }
  116. //ADS1x20_ReadRegister:读取寄存器配置
  117. //pData:一次读取ADS1x20的4个寄存器配置
  118. //注:pData返回的数据空间需要4bit
  119. //这里是为了方便一次读出了所有寄存器的值,也可以像写寄存器那样单独读出单个寄存器的值
  120. void ADS1x20_ReadRegister(unsigned char *pData)
  121. {
  122. unsigned char i;
  123.     ADS1x20_CS_Out(0);
  124.     ADS1x20_ReadWirte(ADS1x20_RREG|0x03);
  125.         for (i=0; i< 4; i++)// get the register content
  126.         {
  127.                 *pData++ = ADS1x20_ReadWirte(0xFF);
  128.         }
  129.         ADS1x20_CS_Out(1);
  130. }
  131. //ADS1x20_WriteRegister:写入寄存器配置
  132. //StartAddress:写入寄存器的地址(如:00寄存器则配置为0;03寄存器则配置为3)
  133. //NumRegs:写入n个寄存器数据,从第StartAddress寄存器开始写
  134. //pData:写入寄存器的数据
  135. //如:把01寄存器写0x58 02寄存器写入0x49
  136. //   unsigned char Temp[4];
  137. //   Temp[0] = 0x58;
  138. //   Temp[1] = 0x49;
  139. //   ADS1x20_WriteRegister(1,2,Temp);
  140. void ADS1x20_WriteRegister(unsigned char StartAddress, unsigned char NumRegs, unsigned char * pData)
  141. {
  142. unsigned char i;
  143.         ADS1x20_CS_Out(0);
  144.         ADS1x20_ReadWirte(ADS1x20_WREG | (((StartAddress<<2) & 0x0c) |((NumRegs-1)&0x03)));// send the command byte
  145.         for (i=0; i< NumRegs; i++)// send the data bytes
  146.         {
  147.                 ADS1x20_ReadWirte(*pData);
  148.                 pData++;
  149.         }
  150.         ADS1x20_CS_Out(1);
  151. }
  152. void ADS1x20_ReadChannel(unsigned char Channel,unsigned char*Data)
  153. {
  154. unsigned char Register[4];
  155.         Register[0] = Channel|ADS1x20_00_GAIN6|ADS1x20_00_PGA_BYPASS_E;//通道|放大倍数|PGA旁路
  156.         Register[1] = ADS1x20_01_DR2|ADS1x20_01_MODE0|ADS1x20_01_CM0|ADS1x20_01_TS0|ADS1x20_01_BCS0;//转换速率|速率模式|转换模式|温度还是ADC|电流源开关
  157.         Register[2] = ADS1x20_02_VREF0|ADS1x20_02_FIR1|ADS1x20_02_IDAC0;//参考电压|滤波|恒流源大小
  158.         Register[3] = ADS1x20_03_I1MUX0|ADS1x20_03_I2MUX0|ADS1x20_03_DRDYM1;//恒流源1连接|恒流源2连接|转换结束RDRY和DOUT管脚拉低
  159.         ADS1x20_WriteRegister(0,4,Register);//设置寄存器
  160.         ADS1x20_StartConversion();//转换开始
  161.         while(ADS1x20_DOUT_Get);//等待数据转换结束
  162.         ADS1x20_ReadData(Data);//读取数据
  163. //        ADS1x20_ReadRegister(Register);
  164.         ADS1x20_PowerDown();//低功耗
  165. }
  166. //读取芯片温度
  167. unsigned short ADS1x20_ReadChip(void)
  168. {
  169. unsigned char  Register;
  170. unsigned short temp;
  171.         Register = ADS1x20_01_DR2|ADS1x20_01_MODE0|ADS1x20_01_CM0|ADS1x20_01_TS1|ADS1x20_01_BCS0;//转换速率|速率模式|转换模式|温度还是ADC|电流源开关
  172.         ADS1x20_WriteRegister(1,1,&Register);//设置寄存器
  173.         ADS1x20_StartConversion();//转换开始
  174.         while(ADS1x20_DOUT_Get);//等待数据转换结束
  175.         ADS1x20_CS_Out(0);
  176.         ADS1x20_ReadWirte(ADS1x20_RDATA);//发送读命令
  177.         temp = ADS1x20_ReadWirte(0xFF);//读芯片温度高字节
  178.         temp = temp<<8;
  179.         temp = temp+ADS1x20_ReadWirte(0xFF);//读芯片温度低字节
  180.         ADS1x20_CS_Out(1);
  181. //        ADS1x20_ReadRegister(Register);
  182.         ADS1x20_PowerDown();//低功耗
  183.
  184.         return temp;
  185. }
  186. //读取芯片温度
  187. float ADS1x20_ReadChipTemp(void)
  188. {
  189. unsigned short temp;
  190. float                    Temp;
  191.         temp = ADS1x20_ReadChip();
  192.         Temp = (float)(temp*0.00625);//温度=转换数据*0.03125/5(0.03125/5=0.00625)
  193.         return Temp;
  194. }
  195. #ifdef ADS1120
  196. #else //ADS1220
  197. #endif
  1. #ifndef __ADS1X20_H
  2. #define __ADS1X20_H
  3. #define  ADS1120//如果定义了就是ADS1120如果没定义就是ADS1220
  4. #ifdef ADS1120
  5. #else //ADS1220
  6. #endif
  7. #define ADS1x20_RESET                        0x06//Reset the device
  8. #define ADS1x20_START                      0x08//Start or restart conversions
  9. #define ADS1x20_POWERDOWN                  0x02//Enter power-down mode
  10. #define ADS1x20_RDATA                     0x10//Read data by command
  11. #define ADS1x20_RREG                      0x20//Read nn registers starting at address rr
  12. #define ADS1x20_WREG                       0x40//Write nn registers starting at address rr
  13. //寄存器00
  14. #define ADS1x20_00_MUX0                        0x00//AINP = AIN0, AINN = AIN1 (default)
  15. #define ADS1x20_00_MUX1                        0x10//AINP = AIN0, AINN = AIN2
  16. #define ADS1x20_00_MUX2                        0x20//AINP = AIN0, AINN = AIN3
  17. #define ADS1x20_00_MUX3                        0x30//AINP = AIN1, AINN = AIN2
  18. #define ADS1x20_00_MUX4                        0x40//AINP = AIN1, AINN = AIN3
  19. #define ADS1x20_00_MUX5                        0x50//AINP = AIN2, AINN = AIN3
  20. #define ADS1x20_00_MUX6                        0x60//AINP = AIN1, AINN = AIN0
  21. #define ADS1x20_00_MUX7                        0x70//AINP = AIN3, AINN = AIN2
  22. #define ADS1x20_00_MUX8                        0x80//AINP = AIN0, AINN = AVSS
  23. #define ADS1x20_00_MUX9                        0x90//AINP = AIN1, AINN = AVSS
  24. #define ADS1x20_00_MUXA                        0xA0//AINP = AIN2, AINN = AVSS
  25. #define ADS1x20_00_MUXB                        0xB0//AINP = AIN3, AINN = AVSS
  26. #define ADS1x20_00_MUXC                        0xC0//(VREFPx ?VREFNx) / 4 monitor (PGA bypassed)
  27. #define ADS1x20_00_MUXD                        0xD0//(AVDD ?AVSS) / 4 monitor (PGA bypassed)
  28. #define ADS1x20_00_MUXE                        0xE0//AINP and AINN shorted to (AVDD + AVSS) / 2
  29. #define ADS1x20_00_MUXF                        0xF0//Not used
  30. #define ADS1x20_00_GAIN0                0x00//Gain = 1 (default)
  31. #define ADS1x20_00_GAIN1                0x02//Gain = 2
  32. #define ADS1x20_00_GAIN2                0x04//Gain = 4
  33. #define ADS1x20_00_GAIN3                0x06//Gain = 8
  34. #define ADS1x20_00_GAIN4                0x08//Gain = 16
  35. #define ADS1x20_00_GAIN5                0x0A//Gain = 32
  36. #define ADS1x20_00_GAIN6                0x0C//Gain = 64
  37. #define ADS1x20_00_GAIN7                0x0E//Gain = 128
  38. #define ADS1x20_00_PGA_BYPASS_E        0x00//PGA enabled (default) The PGA is always enabled for gain settings 8 to 128, regardless of the PGA_BYPASS setting.
  39. #define ADS1x20_00_PGA_BYPASS_D        0x01//PGA disabled and bypassed
  40. //寄存器01
  41. //------------------------------------Normal mod------Duty-cycle mode--Turbo mode
  42. #define ADS1x20_01_DR0                        0x00//20 SPS (default)-5 SPS-----------40 SPS
  43. #define ADS1x20_01_DR1                        0x20//45 SPS-----------11.25 SPS-------90 SPS
  44. #define ADS1x20_01_DR2                        0x40//90 SPS-----------22.5 SPS--------180 SPS
  45. #define ADS1x20_01_DR3                        0x60//175 SPS----------44 SPS----------350 SPS
  46. #define ADS1x20_01_DR4                        0x80//330 SPS----------82.5 SPS--------660 SPS
  47. #define ADS1x20_01_DR5                        0xA0//600 SPS----------150 SPS---------1200 SPS
  48. #define ADS1x20_01_DR6                        0xC0//1000 SPS---------250 SPS---------2000 SPS
  49. #define ADS1x20_01_DR7                        0xE0//Not used---------Not used--------Not used
  50. #define ADS1x20_01_MODE0                0x00//Normal mode (256-kHz modulator clock, default)
  51. #define ADS1x20_01_MODE1                0x08//Duty-cycle mode (internal duty cycle of 1:4)
  52. #define ADS1x20_01_MODE2                0x10//Turbo mode (512-kHz modulator clock)
  53. #define ADS1x20_01_MODE3                0x18//Not used
  54. #define ADS1x20_01_CM0                        0x00//Single-shot mode (default)
  55. #define ADS1x20_01_CM1                        0x04//Continuous conversion mode
  56. #define ADS1x20_01_TS0                        0x00//Disables temperature sensor (default)
  57. #define ADS1x20_01_TS1                        0x02//Enables temperature sensor
  58. #define ADS1x20_01_BCS0                        0x00//Current sources off (default)
  59. #define ADS1x20_01_BCS1                        0x01//Current sources on
  60. //寄存器02
  61. #define ADS1x20_02_VREF0                0x00//Internal 2.048-V reference selected (default)
  62. #define ADS1x20_02_VREF1                0x40//External reference selected using dedicated REFP0 and REFN0 inputs
  63. #define ADS1x20_02_VREF2                0x80//External reference selected using AIN0/REFP1 and AIN3/REFN1 inputs
  64. #define ADS1x20_02_VREF3                0xC0//Analog supply AVDD used as reference
  65. #define ADS1x20_02_FIR0                        0x00//No 50-Hz or 60-Hz rejection (default)
  66. #define ADS1x20_02_FIR1                        0x10//Simultaneous 50-Hz and 60-Hz rejection
  67. #define ADS1x20_02_FIR2                        0x20//50-Hz rejection only
  68. #define ADS1x20_02_FIR3                        0x30//60-Hz rejection only
  69. #define ADS1x20_02_PSW0                        0x00//Switch is always open (default)
  70. #define ADS1x20_02_PSW1                        0x08//Switch automatically closes when the START/SYNC command is sent and opens when the POWERDOWN commandis issued
  71. #define ADS1x20_02_IDAC0                0x00//Off (default)
  72. #define ADS1x20_02_IDAC1                0x01//Not used
  73. #define ADS1x20_02_IDAC2                0x02//50 uA
  74. #define ADS1x20_02_IDAC3                0x03//100 uA
  75. #define ADS1x20_02_IDAC4                0x04//250 uA
  76. #define ADS1x20_02_IDAC5                0x05//500 uA
  77. #define ADS1x20_02_IDAC6                0x06//1000 uA
  78. #define ADS1x20_02_IDAC7                0x07//1500 uA
  79. //寄存器03
  80. #define ADS1x20_03_I1MUX0                0x00//IDAC1 disabled (default)
  81. #define ADS1x20_03_I1MUX1                0x20//IDAC1 connected to AIN0/REFP1
  82. #define ADS1x20_03_I1MUX2                0x40//IDAC1 connected to AIN1
  83. #define ADS1x20_03_I1MUX3                0x60//IDAC1 connected to AIN2
  84. #define ADS1x20_03_I1MUX4                0x80//IDAC1 connected to AIN3/REFN1
  85. #define ADS1x20_03_I1MUX5                0xA0//IDAC1 connected to REFP0
  86. #define ADS1x20_03_I1MUX6                0xC0//IDAC1 connected to REFN0
  87. #define ADS1x20_03_I1MUX7                0xE0//Not used
  88. #define ADS1x20_03_I2MUX0                0x00//IDAC2 disabled (default)
  89. #define ADS1x20_03_I2MUX1                0x04//IDAC2 connected to AIN0/REFP1
  90. #define ADS1x20_03_I2MUX2                0x08//IDAC2 connected to AIN1
  91. #define ADS1x20_03_I2MUX3                0x0C//IDAC2 connected to AIN2
  92. #define ADS1x20_03_I2MUX4                0x10//IDAC2 connected to AIN3/REFN1
  93. #define ADS1x20_03_I2MUX5                0x14//IDAC2 connected to REFP0
  94. #define ADS1x20_03_I2MUX6                0x18//IDAC2 connected to REFN0
  95. #define ADS1x20_03_I2MUX7                0x1C//Not used
  96. #define ADS1x20_03_DRDYM0                0x00//Only the dedicated DRDY pin is used to indicate when data are ready (default)
  97. #define ADS1x20_03_DRDYM1                0x02//Data ready is indicated simultaneously on DOUT/DRDY and DRDY
  98. //#define ADS1x20_SADC0_1                        ADS1x20_OS|ADS1x20_MUX0|ADS1x20_PGA5|ADS1x20_MODE1|ADS1x20_SPS4|ADS1x20_TEMP0|ADS1x20_PULL1//单次使能|AIN0-AIN1|PGA16|单次|128SPS|ADC|弱上拉
  99. //#define ADS1x20_ADC0_1                        ADS1x20_MUX0|ADS1x20_PGA5|ADS1x20_MODE0|ADS1x20_SPS4|ADS1x20_TEMP0|ADS1x20_PULL1//AIN0-AIN1|PGA16|连续|128SPS|ADC|弱上拉
  100. //#define ADS1x20_STEMP                        ADS1x20_OS|ADS1x20_MODE1|ADS1x20_SPS4|ADS1x20_TEMP1|ADS1x20_PULL1//单次使能|单次|128SPS|温度|弱上拉
  101. //#define ADS1x20_TEMP                        ADS1x20_MODE0|ADS1x20_SPS4|ADS1x20_TEMP1|ADS1x20_PULL1//连续|128SPS|温度|弱上拉
  102. void ADS1x20_Init(void);
  103. void ADS1x20_ReadRegister(unsigned char *pData);
  104. void ADS1x20_WriteRegister(unsigned char StartAddress, unsigned char NumRegs, unsigned char * pData);
  105. void ADS1x20_ReadChannel(unsigned char Channel,unsigned char*Data);
  106. unsigned short ADS1x20_ReadChip(void);
  107. float ADS1x20_ReadChipTemp(void);
  108. #endif
出0入53汤圆
发表于 2020-8-4 08:06:01 | 显示全部楼层
reflecter 发表于 2020-8-3 20:37
稳定,我们东区已有客户100K级别出货~
若无需低功耗模式,还有个low cost特别型号AD74-014可以选用的(电 ...
100k 能到什么价位,还有有效数据能稳定到多少位
出0入53汤圆
发表于 2020-8-4 13:30:16 | 显示全部楼层
bolizhicheng204 发表于 2020-8-4 10:28
我之前写过ADS1220相关的帖子,不知道是不是我水平问题,这个片子我觉得精度不好,没有ADI的片子好伺候 ...
TI得就是各种寄存器 搞得很晕,我当时参照谁的忘记了,但是我那个驱动是调通了
GMT+8, 2024-5-4 17:19
