发表于 2010-1-1 00:47:48
请问老大用的哪个版本的编译器?我用TQ2440光盘里面那个不行,出现了/opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivsi3.o): In function `__aeabi_uidiv':
(.text+0x0): multiple definition of `__udivsi3'
lib_arm/libarm.a(_udivsi3.o):/root/bootloader/u-boot-1.2.0/lib_arm/_udivsi3.S:17: first defined here
arm-linux-ld: error: Source object /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivdi3.o) has EABI version 5, but target u-boot has EABI version 0
arm-linux-ld: failed to merge target specific data of file /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivdi3.o)
arm-linux-ld: error: Source object /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivsi3.o) has EABI version 5, but target u-boot has EABI version 0
arm-linux-ld: failed to merge target specific data of file /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivsi3.o)
arm-linux-ld: error: Source object /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_dvmd_lnx.o) has EABI version 5, but target u-boot has EABI version 0
arm-linux-ld: failed to merge target specific data of file /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_dvmd_lnx.o)
arm-linux-ld: error: Source object /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_clz.o) has EABI version 5, but target u-boot has EABI version 0
arm-linux-ld: failed to merge target specific data of file /opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_clz.o)
drivers/nand/libnand.a(nand.o): In function `nand_init_chip':
/root/bootloader/u-boot-1.2.0/drivers/nand/nand.c:50: undefined reference to `board_nand_init'
/opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_udivdi3.o):(.ARM.exidx+0x0): undefined reference to `__aeabi_unwind_cpp_pr0'
/opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/armv4t/libgcc.a(_dvmd_lnx.o): In function `__aeabi_ldiv0':
(.text+0x8): undefined reference to `raise'
make: *** [u-boot] 错误 1 |
