发表于 2010-6-9 14:54:36
从哪个版本开始不再支持了?
Where is the driver for IAR J-Link? (v.5.xx)
EW targets: 430
EW component: C-SPY debugger
Keywords: FET, J-Link
Last update: April 20, 2010
Problem
I can not find the driver in the directory \430\drivers\ for the J-Link.
Comment
The reason for this is that TI has changed their driver for the FET debug module so that the most recent J-Link driver do not work with the FET driver. The development of the J-Link-430 is discontinued, so there will not be an updated driver J-Link-430.
What to do
If you chose to use the J-Link then you need to use an older EW430 version. To use the present EW430 you need to use a modern JTAG debug module. |
