发表于 2010-12-21 09:49:05
楼主调24L01的经验很丰富啊,我现在也遇到了问题,是软件方面的,在接受端不能清除RX_FIFO而且和那奇怪要再读一次RX_PAYLOAD才行,不然只能接收一次,可能不太好懂,一下是我的程序
#include "msp430x14x.h"
void init_chip(void);
void init_uart(void);
void init_clock(void);
unsigned char SPI_RW(unsigned char byte);
unsigned char SPI_Write(unsigned char byte);
unsigned char SPI_RW_Reg(unsigned char reg, unsigned char value);
unsigned char SPI_Read(unsigned char reg);
unsigned char SPI_Read_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes);
unsigned char SPI_Write_Buf(unsigned char reg, unsigned char *pBuf, unsigned char bytes);
void StandbyI(void);
void StadbyII(void);
void RX_Mode(void);
void TX_Mode(void);
void setupnrf(void);
void delay(int a);
void LED(void);
#define ADR_WIDTH 5 // 5 bytes TX(RX) address width (地址长度)
#define PLOAD_WIDTH 20 // 20 bytes TX payload (最大是 32 bytes)
unsigned char TX_ADDRESS[ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static TX address (即目标地址)
unsigned char Local_ADDRESS[ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // Define a static RX address (即本地地址)
unsigned char rx_buf[PLOAD_WIDTH]; //接收缓存容器
unsigned char tx_buf[PLOAD_WIDTH]={'c','o','n','g','r','a','t','u','l','a','t','i','o','n',' ','r','i','g','h','t'}; //发送缓存容器
//unsigned char tx_buf[PLOAD_WIDTH]={0x01,0x02,0x03,0x04,0x05,0x01,0x02,0x03,0x04,0x05,0x01,0x02,0x03,0x04,0x05,0x34,0x43,0x10,0x10,0x01}; //发送缓存容器
unsigned char flag; //标志
int flag_r;
int flag_t;
int flag_e;
unsigned char sta; //状态标志
#define RX_DR sta&0x40 // RX_DR=sta^6; 接收数据中断,当接收到有效数据后置1
#define TX_DS sta&0x20 //TX_DS =sta^5; 数据发送完成中断
#define MAX_RT sta&0x10 // MAX_RT =sta^4; 达到最多次重发中断
//DEFINE IO
#define SET_CSN P5OUT|=0X01
#define CLR_CSN P5OUT&=0XFE
//#define SET_CE P5OUT|=0X10
//#define CLR_CE P5OUT&=0XEF
#define SET_CE P1OUT|=0X40
#define CLR_CE P1OUT&=0XBF
#define SET_MOSI P5OUT|=0X02
#define CLR_MOSI P5OUT&=0XFD
#define SET_SCK P5OUT|=0X08
#define CLR_SCK P5OUT&=0XF7
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
void init_chip()
P5SEL=0;
P5DIR|=0X1B; //P5.0 5.1 5.35.4输出P5.2输入
P1SEL=0;
P1DIR|=0X40;
CLR_CE;
SET_CSN;
CLR_SCK;
CLR_MOSI;
P1OUT=0X00;
P1IE|=0X80;
P1IES|=0X80;
P1IFG=0X00;
//_EINT();
void init_clock()
BCSCTL1=0X80;
do
{IFG1&=~OFIFG;
delay(159);}
while(IFG1&OFIFG);
BCSCTL2=SELM0+SELM1;
void init_uart()
P3SEL|=0X30;
UCTL0=SWRST;
ME1|=UTXE0+URXE0; //使能发送接收
UCTL0|=CHAR;
UTCTL0=SSEL0;
U0BR0=0X03;
U0BR1=0X00;
U0MCTL=0X4A;
UCTL0&=~SWRST;
IE1|=URXIE0+UTXIE0; //使能中断
int i;
for(i=0;i<8;i++)
if(byte&0x80!=0)
SET_MOSI;
CLR_MOSI;
byte=byte<<1;
SET_SCK;
if(P5IN&0x40)
byte|=0x01;
byte&=0xfe;
CLR_SCK;
return(byte);
void StandbyI()
SPI_RW_Reg(WRITE_REG+CONFIG,0X0E);
void StandbyII()
SPI_RW_Reg(WRITE_REG+CONFIG,0X3E);
SPI_RW(FLUSH_TX);
delay(1000);
SET_CE;
void setupnrf()
SPI_RW_Reg(WRITE_REG+EN_RXADDR,0X01);
SPI_RW_Reg(WRITE_REG+SETUP_AW,0X03);
int i;
for(i=0;i<8;i++)
if(byte&0x80)
P5OUT|=0X02;
P5OUT&=0XFD;
byte<<=1;
_NOP();_NOP();_NOP();
P5OUT|=0X08;
_NOP();
if(P5IN&0X04)
byte|=0x01;
byte&=0xfe;
P5OUT&=0XF7;
return(byte);
unsigned char SPI_RW_Reg(unsigned char reg,unsigned char value)
unsigned char status;
SET_CSN;
CLR_CSN;
status=SPI_RW(reg);
SPI_RW(value);
SET_CSN;
return(status);
unsigned char reg_val;
SET_CSN;
CLR_CSN;
SPI_RW(reg);
reg_val=SPI_RW(0);
SET_CSN;
return(reg_val);
unsigned char SPI_Write_Buf(unsigned char reg,unsigned char *pBuf,unsigned char bytes)
unsigned char status,byte_ctr;
SET_CSN;
CLR_CSN;
status=SPI_RW(reg);
for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
SPI_RW(*pBuf++);
SET_CSN;
return(status);
unsigned char SPI_Read_Buf(unsigned char reg,unsigned char *pBuf,unsigned char bytes)
SET_CSN;
CLR_CSN;
status=SPI_RW(reg);
pBuf[byte_ctr]=SPI_RW(0);
SET_CSN;
return(status);
void TX_Mode(void)
//P1OUT&=0XBF; //P1.6=0
CLR_CE; //P5.4=0
SPI_Write_Buf(WRITE_REG+TX_ADDR,TX_ADDRESS,ADR_WIDTH);
SPI_Write_Buf(WRITE_REG+RX_ADDR_P0,TX_ADDRESS,ADR_WIDTH);
SPI_Write_Buf(WR_TX_PLOAD,tx_buf,PLOAD_WIDTH);
SPI_RW_Reg(WRITE_REG+EN_AA,0X00);
SPI_RW_Reg(WRITE_REG+SETUP_RETR,0X1a);
SPI_RW_Reg(WRITE_REG+RF_CH,0X00);
SPI_RW_Reg(WRITE_REG+RF_SETUP,0X07);
//P1OUT|=0X40; //P1.6=1
SET_CE; //P5.4=1
delay(159);
CLR_CE;
void RX_Mode(void)
CLR_CE; //P5.4=0
SPI_Write_Buf(WRITE_REG+RX_ADDR_P0,Local_ADDRESS,ADR_WIDTH);
SPI_RW_Reg(WRITE_REG+EN_RXADDR, 0x01);
SPI_RW_Reg(WRITE_REG+RX_PW_P0,PLOAD_WIDTH);
SPI_RW_Reg(WRITE_REG+CONFIG,0X0F);
SET_CE; //P5.4=1
delay(159);
void flash_write(unsigned char byte)
/*unsigned char data[24];
for(int i=0;i<24;i++)
data=i;
unsigned char *tp;//,*write_ptr;
tp=(unsigned char *)0x1000;
FCTL2=FWKEY+FSSEL0+FN0;
FCTL3=FWKEY;
//*tp=1;
FCTL1=FWKEY+WRT;
//for(i=0;i<24;i++)
*tp=byte;
//tp++;
FCTL1=FWKEY;
FCTL3=FWKEY+LOCK;
void delay(int a)
while(a--){}
void IRQEINT()
sta=SPI_Read(STATUS);
int i;
if(RX_DR)
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,20);
flash_write( rx_buf[0]);
for(i=0;i<PLOAD_WIDTH;i++)
{TXBUF0=rx_buf;
while((UTCTL0&TXEPT)!=TXEPT);}
flag=1;
//TX_Mode();
delay(1000);
flag=0;
SPI_RW(FLUSH_RX);
SPI_RW_Reg(WRITE_REG+STATUS,sta);
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,20); //就是一定要加这句话才能继续接收,要不RX_DR就是0不产生标志位了
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
//int i;
init_chip();
init_clock();
init_uart();
StandbyI();
SPI_RW(FLUSH_RX);
//_EINT();
//RX_Mode();
RX_Mode();
IRQEINT();
//sta=SPI_Read(STATUS);
