发表于 2010-12-24 22:01:59
bluehacker : 千兆网MAC是我根据网上的资料改写的,不是用opencore上的 IP core
协议包括MAC + ARP + UDP 才2k 多一点
你以为我是在吹吗 ,我贴个模块,给大家参考一下,你是个内行,你看看
module gisend(
clk125,
rst,
mode,
empty,
headadd,
length,
rd,
datain,
addr,
txd,
tx_en,
tx_er,
col,
crs,
tran_ok,
late_col,
ex_col
input clk125;
input rst;
input mode;
input empty;
input headadd;
input[9:0] length;
output rd;
reg rd;
input[7:0] datain;
output[10:0] addr;
reg[10:0] addr;
output[7:0] txd;
output tx_en;
reg tx_en;
output tx_er;
reg tx_er;
input col;
input crs;
output tran_ok;
reg tran_ok;
output late_col;
reg late_col;
output ex_col;
reg ex_col;
reg[9:0] counter;
reg[9:0] j_counter;
reg[3:0] jam_number;
reg[3:0] busy_counter;
reg out_jam;
reg[3:0] over_counter;
reg[8:0] current;
reg[8:0] next;
parameter IDLE=1, RD=2, GET=4, LOAD=8,
SEND=16, SEND_E=32, JAM=64, OVER=128,
BUSY=256;
wire[9:0] length_a;
assign length_a = length + 1'b1;
assign txd=datain;
always@(current or crs or empty or mode or col or length or counter
or busy_counter or jam_number or out_jam or over_counter)
begin
next=9'bxxxx_xxxx_x;
case(current)
IDLE: begin
if(!empty)
next=RD;
next=IDLE;
end
RD: next=GET;
GET: next=LOAD;
LOAD: begin
if(!mode&&crs)
next=BUSY;
next=SEND;
end
BUSY: begin
if(busy_counter==15&&!crs)
next=SEND;
next=BUSY;
end
SEND: begin
if(mode) begin
if(length_a ==counter)
next=OVER;
next=SEND;
end
else begin
if(col)
next=JAM;
else if(length==counter) begin
if(length>961)
next=OVER;
next=SEND_E;
end
next=SEND;
end
end
SEND_E: begin
if(counter==961)
next=OVER;
next=SEND_E;
end
JAM: begin
if(out_jam) begin
if(jam_number==15)
next=IDLE;
next=LOAD;
end
next=JAM;
end
OVER: begin
if(over_counter==11)
next=IDLE;
next=OVER;
end
default: next=IDLE;
endcase
end
always@(posedge clk125 or negedge rst)
begin
if(!rst) current<=IDLE;
else current<=next;
end
begin
if(!rst) counter<=10'h000;
else begin
case(next)
SEND,
SEND_E: counter<=counter+1'b1;
default: counter<=10'h000;
endcase
end
end
begin
if(!rst) j_counter<=10'h000;
else begin
if(next==JAM)
j_counter<=j_counter+1'b1;
j_counter<=10'h000;
end
end
begin
if(!rst) out_jam<=1'b0;
else begin
if(next==JAM&&j_counter==10'h3ff)
out_jam<=1'b1;
out_jam<=1'b0;
end
end
begin
if(!rst) jam_number<=4'h0;
else begin
if(next==JAM&¤t!=JAM)
jam_number<=jam_number+1'b1;
else if(next==IDLE)
jam_number<=4'h0;
end
end
begin
if(!rst) busy_counter<=4'b0000;
else begin
if(next==BUSY)
busy_counter<=busy_counter+1'b1;
end
end
begin
if(!rst) over_counter<=4'h0;
else begin
if(next==OVER)
over_counter<=over_counter+1'b1;
over_counter<=4'h0;
end
end
begin
if(!rst) rd<=1'b0;
else begin
if(next==RD)
rd<=1'b1;
rd<=1'b0;
end
end
begin
if(!rst) addr<=11'b0000_0000_000;
else begin
case(next)
LOAD: addr<={headadd,10'h000};
SEND: addr<=addr+1'b1;
default: addr<=11'b0000_0000_000;
endcase
end
end
begin
if(!rst) begin
tx_en<=1'b0;
end
else begin
case(next)
SEND:begin
tx_en<=1'b1;
end
JAM: begin
if(j_counter<12)
tx_en<=1'b1;
tx_en<=1'b0;
end
default: begin
tx_en<=1'b0;
end
endcase
end
end
begin
if(!rst) tx_er<=1'b0;
else begin
if(next==SEND_E)
tx_er<=1'b1;
tx_er<=1'b0;
end
end
begin
if(!rst) begin
tran_ok<=1'b0;
late_col<=1'b0;
ex_col<=1'b0;
end
else begin
if(next==OVER&¤t!=OVER)
tran_ok<=1'b1;
tran_ok<=1'b0;
late_col<=1'b1;
late_col<=1'b0;
if(next==JAM&¤t!=JAM&&jam_number==14)
ex_col<=1'b1;
ex_col<=1'b0;
end
end
endmodule |
