发表于 2011-5-25 11:38:44
还有个问题,你的高度转换的程序是这个函数吧:
int32_t PascalToCentimeter(const int32_t pressurePa)
// Lookup table converting pressure in Pa to altitude in cm.
// Each LUT entry is the altitude in cm corresponding to an implicit
// pressure value, calculated as [PA_INIT - 1024*index] in Pa.
// The table is calculated for a nominal sea-level pressure = 101325 Pa.
static const int32_t PZLUT_ENTRIES = 77;
static const int32_t PA_INIT = 104908;
static const int32_t PA_DELTA = 1024;
static const int32_t lookupTable[PZLUT_ENTRIES] = {
-29408, -21087, -12700, -4244, 4279,
12874, 21541, 30281, 39095, 47986,
56953, 66000, 75126, 84335, 93628,
103006, 112472, 122026, 131672, 141410,
151244, 161174, 171204, 181335, 191570,
201911, 212361, 222922, 233597, 244388,
255300, 266334, 277494, 288782, 300204,
311761, 323457, 335297, 347285, 359424,
371719, 384174, 396795, 409586, 422552,
435700, 449033, 462560, 476285, 490216,
504360, 518724, 533316, 548144, 563216,
578543, 594134, 609999, 626149, 642595,
659352, 676431, 693847, 711615, 729752,
748275, 767202, 786555, 806356, 826627,
847395, 868688, 890537, 912974, 936037,
959766, 984206};
if(pressurePa > PA_INIT)
return lookupTable[0];
const int32_t inx = (PA_INIT - pressurePa) >> 10;
if(inx >= PZLUT_ENTRIES - 1)
return lookupTable[PZLUT_ENTRIES - 1];
const int32_t pa1 = PA_INIT - (inx << 10);
const int32_t z1 = lookupTable[inx];
const int32_t z2 = lookupTable[inx+1];
return (z1 + (((pa1 - pressurePa) * (z2 - z1)) >> 10));
能简单解释一下不。谢谢 |
