发表于 2012-4-30 19:15:15
求教楼主两个问题,
1.在线安装一直卡在27%就停了,
2.下载eclipse-arm-6.30-latest.zip文件本地安装,也提示失败,提示信息如下:
Your original request has been modified.
"IAR Common Components" is already installed, so an update will be performed instead.
"IAR C-SPY Debugger Generic Components" is already installed, so an update will be performed instead.
"IAR Common Toolchain Components" is already installed, so an update will be performed instead.
"IAR Build Support for ARM" is already installed, so an update will be performed instead.
"IAR End-User Documentation" is already installed, so an update will be performed instead.
"IAR C-SPY Debug Support for ARM" is already installed, so an update will be performed instead.
Cannot complete the install because of a conflicting dependency.
Software being installed: IAR C-SPY Debugger Generic Components 0.12.2.v20120207-230916 (com.iar.ide.debugger.feature.feature.group 0.12.2.v20120207-230916)
Software currently installed: Eclipse IDE for C/C++ Developers 1.4.0.20110615-0550 (epp.package.cpp 1.4.0.20110615-0550)
Only one of the following can be installed at once:
OSGi System Bundle 3.7.2.v20120110-1415 (org.eclipse.osgi 3.7.2.v20120110-1415)
OSGi System Bundle 3.7.0.v20110613 (org.eclipse.osgi 3.7.0.v20110613)
Cannot satisfy dependency:
From: C-SPY Dialogs 1.0.0.v20120207-230916 (com.iar.ide.common.dialogs 1.0.0.v20120207-230916)
To: bundle org.eclipse.wb.core.databinding 1.1.0
From: IAR C-SPY Debugger Generic Components 0.12.2.v20120207-230916 (com.iar.ide.debugger.feature.feature.group 0.12.2.v20120207-230916)
To: com.iar.ide.common.dialogs [1.0.0.v20120207-230916]
From: Eclipse IDE for C/C++ Developers 1.4.0.20110615-0550 (epp.package.cpp 1.4.0.20110615-0550)
To: org.eclipse.epp.package.cpp.feature.feature.group [1.4.0.20110615-0550]
From: EPP CPP Feature 1.4.0.20110615-0550 (org.eclipse.epp.package.cpp.feature.feature.group 1.4.0.20110615-0550)
To: org.eclipse.platform.feature.group [3.7.0.v20110530-9gF7UHNFFt4cwE-pkZDJ7oz-mj4OSEIlu9SEv0f]
From: Java Development Tools Launching Support 3.6.1.v20111006_r372 (org.eclipse.jdt.launching 3.6.1.v20111006_r372)
To: bundle org.eclipse.osgi [3.7.1,4.0.0)
From: Eclipse Platform 3.7.0.v20110530-9gF7UHNFFt4cwE-pkZDJ7oz-mj4OSEIlu9SEv0f (org.eclipse.platform.feature.group 3.7.0.v20110530-9gF7UHNFFt4cwE-pkZDJ7oz-mj4OSEIlu9SEv0f)
To: org.eclipse.rcp.feature.group [3.7.0.v20110216-9DB5Fm1FpBGy_AaVz-mFamgY]
From: Eclipse RCP 3.7.0.v20110216-9DB5Fm1FpBGy_AaVz-mFamgY (org.eclipse.rcp.feature.group 3.7.0.v20110216-9DB5Fm1FpBGy_AaVz-mFamgY)
To: org.eclipse.osgi [3.7.0.v20110613]
From: WindowBuilder Core 1.3.0.r37x201202052311 (org.eclipse.wb.core 1.3.0.r37x201202052311)
To: bundle org.eclipse.jdt.launching 0.0.0
From: WindowBuilder Databinding Core 1.3.0.r37x201202052311 (org.eclipse.wb.core.databinding 1.3.0.r37x201202052311)
To: bundle org.eclipse.wb.core 0.0.0 |
