效果图如下:
全部显示效果 遗憾的是没有小数点 (原文件名:DSC_1779.jpg)
显示数字 (原文件名:DSC_1792.jpg)
背面 (原文件名:DSC_1794.jpg)
HT1622 (原文件名:DSC_1796.jpg)
程序如下:
HMS17AN段码液晶屏测试程序 Drive HT1622 CPU MSP430G2454 @ 1MHz
第十六位 第三十位
液晶屏内容: 8 8888888888888 8 第二排
8 8888888888888 8 第一排
第一位 第十五位
#include "msp430g2452.h"
#define SET 1
#define RESET 0
#define _ADD_STR(a, b) a##b
#define ADD_STR(a, b) _ADD_STR(a, b)
/* PxIN */
#define _IO_PORT_IN(PORT) (PORT##IN)
#define GPIO_READ_BITS(PORT, BIT) ( (_IO_PORT_IN(PORT) & BIT) ? (SET):(RESET))
#define GOIO_READ_PORTS(PORT) ( _IO_PORT_IN(PORT) )
/* PxOUT */
#define _IO_PORT_OUT(PORT) (PORT##OUT)
#define GPIO_SET_BITS(PORT, BIT) ( ( _IO_PORT_OUT(PORT) ) |= (BIT) )
#define GPIO_RESET_BITS(PORT, BIT) ( ( _IO_PORT_OUT(PORT) ) &= ~(BIT) )
/* PxDIR */
#define _IO_PORT_DIR(PORT) (PORT##DIR)
#define GPIO_OUTPUT_DIR(PORT, BIT) ( ( _IO_PORT_DIR(PORT) ) |= (BIT) )
#define GPIO_INPUT_DIR(PORT, BIT) ( ( _IO_PORT_DIR(PORT) ) &= ~(BIT) )
/* PxIE */
#define _IO_PORT_IE(PORT) (PORT##IE)
#define GPIO_ENABLE_IRQ(PORT, BIT) ( ( _IO_PORT_IE(PORT) ) |= (BIT) )
#define GPIO_DISABLE_IRQ(PORT, BIT) ( ( _IO_PORT_IE(PORT) ) &= ~(BIT) )
/* PxSEL */
#define _IO_PORT_SEL(PORT) (PORT##SEL)
#define GPIO_PORT_FUNC(PORT, BIT) ( ( _IO_PORT_SEL(PORT) ) |= (BIT) )
#define GPIO_MULTI_FUNC(PORT, BIT) ( ( _IO_PORT_SEL(PORT) ) &= ~(BIT) )
/* ------------------ High layer function ----------------------------------- */
#define TEST_BIT(x) ( GPIO_READ_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define SET_BIT(x) ( GPIO_SET_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define CLR_BIT(x) ( GPIO_RESET_BITS( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define BIT_OUT(x) ( GPIO_OUTPUT_DIR( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define BIT_IN(x) ( GPIO_INPUT_DIR( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define EINT_BIT(x) ( GPIO_ENABLE_IRQ( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
#define DINT_BIT(x) ( GPIO_DISABLE_IRQ( ADD_STR(x, _PORT), ADD_STR(x, _BIT) ) )
/* eg. */
/* #define HC165_SCLK_PORT P1 // 使用的是P1口 */
/* #define HC165_SCLK_BIT BIT5 // BIT5位 */
/* BIT_OUT( HC165_SCLK ); // 设置P1.5位输出 */
unsigned char DIS_BUF[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18};//显示缓冲区
//段码表 0 1 2 3 4 5 6 7 8 9 A b C d E F - _ 空
const unsigned char DIS[]={0xBF,0x06,0x7C,0x5E,0xC6,0xDA,0xFA,0x0E,0xFE,0xDE,0xEE,0xF2,0xB8,0x76,0xF8,0xE8,0x40,0x10,0x00};
HT1622 指令宏定义
#define SYSDIS 0X00 // 关振系统荡器和LCD偏压发生器
#define SYSEN 0X01 // 打开系统振荡器
#define LCDOFF 0X02 // 关LCD偏压
#define LCDON 0X03 // 打开LCD偏压
#define TIMEDIS 0x04 // 禁止时基输出
#define WDTDIS 0x05 // 禁止WDT超时标志输出
#define TIMEREN 0x08 // 启用时基输出
#define WDTEN 0x0D // 启用WDT超时标志输出
#define TONEOFF 0x0F // 关闭声音输出
#define CLRTIMER 0x05 // 清除时基发生器的内容
#define CLRWDT 0x0F // 清除WDT的内容
#define RC32K 0x18 // 系统时钟源,片上RC振荡器
#define EXT32K 0x1C // 系统时钟源,外部时钟源
#define TONE4K 0x40 // 音的输出频率:4kHz的
#define TONE2K 0x60 // 音的输出频率:2kHz的
#define IRQDIS 0x80 // 禁止IRQ输出
#define IRQEN 0x88 // 启用IRQ输出
#define F1 0xA0 // 时基时钟输出:2Hz WDT的超时标志后:4s
#define F2 0xA1 // 时基时钟输出:2Hz WDT的超时标志后:2s
#define F4 0xA2 // 时基时钟输出:4Hz WDT的超时标志后:1s
#define F8 0xA3 // 时基时钟输出:8Hz WDT的超时标志后:1/2s
#define F16 0xA4 // 时基时钟输出:16Hz WDT的超时标志后:1/4s
#define F32 0xA5 // 时基时钟输出:32Hz WDT的超时标志后:1/8s
#define F64 0xA6 // 时基时钟输出:64Hz WDT的超时标志后:1/16s
#define F128 0xA7 // 时基时钟输出:128Hz WDT的超时标志后:1/32s
#define TEST 0xE0 // 测试模式下,用户不使用。
#define NORMAL 0xE3 // 普通模式
管脚分配 CS P1.0 WR P1.1 DAT P1.2
#define HT1621_CS_PORT P1 //HT1621使能引脚
#define HT1621_CS_BIT BIT0 //HT1621使能引脚
#define HT1621_WR_PORT P1 //HT1621时钟引脚
#define HT1621_WR_BIT BIT1 //HT1621时钟引脚
#define HT1621_DAT_PORT P1 //HT1621数据引脚
#define HT1621_DAT_BIT BIT2 //HT1621数据引脚
HT1622 底层驱动 Data 数据 Length 数据长度
void Write_HT1622_Byte(unsigned char Data,unsigned char Length)
unsigned char i,Temp=0x80;
for (i=0;i<Length;i++)
CLR_BIT ( HT1621_WR ); //“写”时钟置0
if (Data&Temp)
SET_BIT ( HT1621_DAT );//数据线置1
CLR_BIT ( HT1621_DAT );//数据线置0
Temp>>=1; //准备下一位
SET_BIT ( HT1621_WR ); //“写”时钟置1
HT1622写入数据函数 Address 写数据地址 Data 数据
void Write_HT1622_Data(unsigned char Address,unsigned char Data)
CLR_BIT ( HT1621_CS ); //片选置0
Address <<= 2; //将实际地址挪到高位
Data <<= 4; //将实际数据挪到高位
Write_HT1622_Byte(0xA0,3); //写入写数据的ID 101 高3位有效
Write_HT1622_Byte(Address,6);//写入6个位初始地址 高6位有效
Write_HT1622_Byte(Data,4); //写入4个位数据 高4位有效
SET_BIT ( HT1621_CS ); //片选置1
//HT1622写命令函数 Command 命令
void Write_HT1622_Command(unsigned char Command)
Write_HT1622_Byte(0x80,3); //写入命令的ID:100
Write_HT1622_Byte(Command,8);//写入实际命令的高8位(CMD.):C8-C1
SET_BIT ( HT1621_DAT ); //|写入一个“1”即手册上所指“无关位”的那一个数据位
CLR_BIT ( HT1621_WR ); //|
_NOP();_NOP();_NOP(); //|
SET_BIT ( HT1621_WR ); //|
显示数字函数 *Data显示内容指针 Address 显示首位置 Length内容长度
void Display(unsigned char *Data,unsigned char Address,unsigned char Length)
unsigned char i = 0,Temp=0x0F;
unsigned char ADDH,ADDL;
for(;i<Length;i++)
Temp=DIS[*Data]; //数据解析
ADDL = Address*2; //低4位地址解析
ADDL = ADDL*2+2-(ADDL/31)*59; //低4位地址解析
Write_HT1622_Data(ADDL,Temp&0x0F);//写低4位数据
ADDH = Address*2-1; //高4位地址解析
ADDH = ADDH*2+2-(ADDH/31)*59; //高4位地址解析
Temp>>=4; //高4位数据解析
Write_HT1622_Data(ADDH,Temp&0x0F);//写高4位数据
Data ++; //显示数据指针增一
Address ++; //显示地址增一
主函数 上下两排显示 0到E
WDTCTL = WDTPW + WDTHOLD; //关看门狗
BIT_OUT ( HT1621_DAT ); //|IO口初始化
BIT_OUT ( HT1621_CS ); //|
BIT_OUT ( HT1621_WR ); //|
SET_BIT ( HT1621_CS ); //|
Write_HT1622_Command(SYSDIS);//关闭系统振荡器和LCD驱动
Write_HT1622_Command(SYSEN); //打开系统振荡器
Write_HT1622_Command(LCDOFF);//关闭LCD显示
Write_HT1622_Command(LCDON); //打开LCD显示
Display(DIS_BUF,1,15); //显示0到E 第一排
Display(DIS_BUF,16,15); //显示0到E 第二排
while(1);
