最近在研究用STM32F107通过RC522芯片来读写IC卡,将STM32F107的SPI1的SPI_SCK,SPI_MOSI,SPI_MISO,SPI_NSS(片选)引脚分别和RC522的SCK,MOSI,MISO,NSS(片选)相连,RC522的复位引脚直接通过一电阻连接到3.3V电压,EA引脚接高电平,I2C引脚接低电平(采用SPI模式通信),通过软件复位后,直接FIFODataReg中先写10个0XFF,然后再读回FIFODataReg中的数值;但MISO引脚传到STM32的值一直是0XFF,不知是什么原因。
下面是相关代码
nt main(void)
{ int i,k;
u8 te,tmp=0x01;
USART1_Configuration();
SPI1_Init();
InitRc522();
for(i=0;i<10;i++)
{WriteRawRC(FIFODataReg,0xF0);}
for(i=0;i<10;i++)
{te=ReadRawRC( FIFODataReg ); Display_Char(te);}
while (1){};
void SPI1_Init(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_SPI1 ,ENABLE);
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5| GPIO_Pin_7;//PA5(SPI1_SCK), PA7-----SPI1_MOSI
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //MISO引脚,设置为上拉模式
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_SetBits(GPIOA, GPIO_Pin_6);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//SPI1的NSS引脚与RC522的NSS引脚相连,作为片选信号
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
SPI_Cmd(SPI1, DISABLE);
SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode=SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low ;
SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial=7;
SPI_Init(SPI1,&SPI_InitStructure);
SPI_SSOutputCmd(SPI1, ENABLE);//Enable SPI1.NSS as a GPIO 将此引脚作为变通IO口用
SPI_Cmd(SPI1,ENABLE);
//功 能:复位RC522
//返 回: 成功返回MI_OK
char PcdReset(void)
WriteRawRC(CommandReg,PCD_RESETPHASE); //此处因为电路图上RC522的复位引脚直接通过一电阻连接到3.3V电压,所以在这里直接向522寄存器中直接写复位命令复位
WriteRawRC(ModeReg,0x3D); //和Mifare卡通讯,CRC初始值0x6363
WriteRawRC(TReloadRegL,30);
WriteRawRC(TReloadRegH,0);
WriteRawRC(TModeReg,0x8D);
WriteRawRC(TPrescalerReg,0x3E);
WriteRawRC(TxAutoReg,0x40);//必须要
return MI_OK;
u8 SPI1_ReadWriteByte(u8 RWData)
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);//检查指定的SPI标志位设置与否:发送缓存空标志
SPI_I2S_SendData(SPI1,RWData); //通过外设SPIx发送一个数据
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); //检查指定的SPI标志位设置与否:接受缓存非空标志位
return SPI_I2S_ReceiveData(SPI1); //返回通过SPIx最近接收的数据
//功 能:读RC632寄存器
//参数说明:Address[IN]:寄存器地址
//返 回:读出的值
u8 ReadRawRC(u8 Address)
u8 ucAddr;
u8 ucResult=0;
// GPIO_ResetBits(GPIOA, GPIO_Pin_4); //拉低电平,选通芯片
ucAddr = ((Address<<1)&0x7E)|0x80;
SPI_NSSInternalSoftwareConfig(SPI1,SPI_NSSInternalSoft_Reset);
SPI1_ReadWriteByte(ucAddr);
ucResult=SPI1_ReadWriteByte(0);
// GPIO_SetBits(GPIOA, GPIO_Pin_4); //拉高电平,取消片选
SPI_NSSInternalSoftwareConfig(SPI1,SPI_NSSInternalSoft_Set);
return ucResult;
//功 能:写RC632寄存器
// value[IN]:写入的值
void WriteRawRC(u8 Address, u8 value)
u8 ucAddr,tmp;
ucAddr = ((Address<<1)&0x7E);
SPI_NSSInternalSoftwareConfig(SPI1,SPI_NSSInternalSoft_Reset);//拉低SPI1_NSS,选通芯片
SPI1_ReadWriteByte(value);
SPI_NSSInternalSoftwareConfig(SPI1,SPI_NSSInternalSoft_Set);//拉高SPI1_NSS电平,取消片选
