发表于 2013-1-22 05:40:36
IEEE1057 3-parameter implementation:
as promised, here is the (more) wholesome implementation of the IEEE1057 3-parameter approach:
- #include <stdio.h>
- #include <stdlib.h>
- #include <math.h>
- #define PI 3.14159265359 //pi
- #define _2PI (2*PI) //2 * pi
- typedef struct {
- double A, B, C; //fitted cosine wave: yn = A * cosine(wt) + B * sine(wt) + C
- double A0, theta; //fitted cosine wave: yn = A0 * cosine(wt + theta) + C
- } FITTED_COSINE_T;
- typedef struct {
- double Z; //parallel / serial impedance
- double Zr, Zi; //parallel/serial impmedance, real and imaginary
- //double Sr, Si; //serial impedance, real and imaginary
- double theta; //angles
- double Q; //Q factor
- double LC; //dut's resistance, L(uh) or C(ph)
- } IMPEDANCE_T;
- #define M 200 //number of data samples, unsigned short
- #define N (M * f_osc / 10) //sample per period
- unsigned short voltn[M], curtn[M]; //data samples
- FITTED_COSINE_T volt, curt; //voltage / current vectors
- double f_osc=10000.0; //sample frequency, in hz
- //impedance measurement
- double Rm=1000.0; //measurement resistor, in ohm
- IMPEDANCE_T dut; //device undertest
- //generate adc data
- void data_gen( unsigned short length, //length of data
- unsigned short *buffer, //output data buffer
- double A, //gain for the sine term
- double B, //gain for the cosine term
- double C, //constant
- double error_gain //gain for the error term
- unsigned short n; //loop index
- //srand(1235); //seed the random number generator
- for (n=0; n<length; n++) buffer[n]= A * cos(_2PI * f_osc * n / N) + //sine term
- B * sin(_2PI * f_osc * n / N) + //cosine term
- C + //constant
- error_gain * (rand() / 32768.0 - 0.5); //error term, mean = 0.0
- //return;
- void data_gen1( unsigned short length, //length of data
- unsigned short *buffer_v, //output data buffer
- unsigned short *buffer_c //output data buffer
- double amplitude = 100; //osc amplitude
- double theta_v = 10.0 / 360 * _2PI; //voltage signal
- //set up dut
- dut.Z = 1000; //dut's impedance
- dut.theta = -45.0 / 360 * _2PI; //theta. - for capacitance and + for inductance. converting from degrees to radius
- dut.Zr = dut.Z * cos(dut.theta);
- dut.Zi = dut.Z * sin(dut.theta);
- for (n=0; n<length; n++) {
- buffer_v[n]= amplitude * cos(_2PI * f_osc * n / N + theta_v) + //cosine term
- //B * sin(_2PI * f_osc * n / N) + //sine term
- 500 + //constant
- 0.01 * amplitude * (rand() / 32768.0 - 0.5); //error term, mean = 0.0
- buffer_c[n]= - 1* amplitude / dut.Z * Rm * cos(_2PI * f_osc * n / N + theta_v + dut.theta) + //cosine term. negative due to the opamp being out of phase
- 1000 + //constant
- //printf("buffer_v[%4d] = %10d, buffer_c[%4d] = %10d\n", n, buffer_v[n], n, buffer_c[n]);
- //return;
- //print buffer
- void data_prt(unsigned short length, unsigned short * buffer) {
- unsigned short i; //loop index
- printf("simulated data\n"); //simulated data to be printed
- //for (i=0; i<length; i++) printf("buffer[%4d]=%5d\n", i, buffer[i]);
- for (i=0; i<length; i++) printf("%5d\n", buffer[i]);
- //ieee-std-1057, non-matrix 3 parameter sine curve fitting
- //ieee-std-1057 1994, P19
- void ieee1057_3(unsigned short length, //sample data length
- unsigned short * buffer, //input sample data buffer
- FITTED_COSINE_T * output //vector data output
- unsigned short n; //index
- double alphan, betan; //sine / cosine terms
- double sum_yn=0, sum_alphan=0, sum_betan=0; //define the sums, on P19
- double sum_alphanxbetan=0, sum_alphan2=0, sum_betan2=0; //define the sums, on P19
- double sum_ynxalphan=0, sum_ynxbetan=0, sum_yn2=0; //define the sums, on P19
- double Xn, Xd; //temp variables used in calculation
- //calculate signal sums
- //calculate alpha / beta
- alphan=cos(_2PI * f_osc * n / N);
- betan=sin(_2PI * f_osc * n / N);
- //caulate the sums
- sum_yn += buffer[n];
- sum_alphan += alphan;
- sum_betan += betan;
- sum_alphanxbetan += alphan * betan;
- sum_alphan2 += alphan * alphan;
- sum_betan2 += betan * betan;
- sum_ynxalphan += buffer[n] * alphan;
- sum_ynxbetan += buffer[n] * betan;
- sum_yn2 += ((double)buffer[n]) * buffer[n]; //to avoid overflow
- //calculate An/Ad
- Xn = (sum_ynxalphan - sum_alphan * sum_yn / M) / (sum_alphanxbetan - sum_alphan * sum_betan / M) -
- (sum_ynxbetan - sum_betan * sum_yn / M) / (sum_betan2 - sum_betan * sum_betan / M);
- Xd = (sum_alphan2 - sum_alphan * sum_alphan / M) / (sum_alphanxbetan - sum_alphan * sum_betan / M) -
- (sum_alphanxbetan - sum_betan * sum_alphan / M) / (sum_betan2 - sum_betan * sum_betan / M);
- output->A = Xn / Xd;
- Xn = (sum_ynxalphan - sum_alphan * sum_yn / M) / (sum_alphan2 - sum_alphan * sum_alphan / M) -
- (sum_ynxbetan - sum_betan * sum_yn / M) / (sum_alphanxbetan - sum_betan * sum_alphan / M);
- Xd = (sum_alphanxbetan - sum_alphan * sum_betan / M) / (sum_alphan2 - sum_alphan * sum_alphan / M) -
- (sum_betan2 - sum_betan * sum_betan / M) / (sum_alphanxbetan - sum_betan * sum_alphan / M);
- output->B = Xn / Xd;
- output->C = sum_yn / M - output->A * sum_alphan / M - output->B * sum_betan / M;
- //alternative output
- output->A0 = sqrt(output->A * output->A + output->B * output->B);
- output->theta = atan(-output->B / output->A);
- //output->theta += (output->A < 0)? PI: 0;
- //calculate impedance (Zdut)
- //measurement approach: autobalancing bridge
- //connection:
- // - volt (sampling point) - curt (sampling point)
- // Vosc---------- | Zdut |-------------| Rm |-------
- // (freq=f_osc) ------ | ------ |
- // |Amp O|------|
- // Vbias
- // --- (GND)
- void impedance(FITTED_COSINE_T * voltage, FITTED_COSINE_T * current, IMPEDANCE_T * dut) {
- //double tmp; //temperary variable
- //calculate current through Rm
- //tmp = current.A0 / Rm;
- dut->Z = voltage->A0 * Rm / current->A0; // tmp;
- dut->theta = /*-*/(current->theta - voltage->theta); //eliminate '-' as the current signal is out of phase.
- dut->Zi= dut->Z * sin(dut->theta);
- dut->Zr= dut->Z * cos(dut->theta);
- //calculate L or C
- if (dut->theta < 0) { //capacitive load
- dut->LC = -1.0 / (dut->Zi * _2PI * f_osc); //calculate C, in f
- } else {
- dut->LC = dut->Zi / (_2PI * f_osc); //calculate L, in H
- //perform the calculation for dut's impedance / LCR parameters
- void Z_measure( unsigned short length, //length of data sample
- unsigned short *voltage, //voltage data array
- unsigned short *current, //current data array
- IMPEDANCE_T *dut) //device data measurement. Output
- //FITTED_COSINE_T volt, curt; //temp variables.
- ieee1057_3(length, voltage, &volt); //covert the voltage
- ieee1057_3(length, current, &curt); //covert the current
- //curt.theta = - curt.theta; //current signal measured 180 degrees opposite
- impedance(&volt, &curt, dut); //calculate the impedance
- int main(void) {
- //generate simulated data
- //data_gen(M, voltn, 500, 100, 1000, 10); //voltage signal
- //data_prt(M, voltn); //print out data
- //data_gen(M, curtn, 100, 200, 2000, 10); //current signal
- //data_prt(M, currentn);
- //simulated data generation
- data_gen1(M, voltn, curtn); //load specification in data_gen1()
- //calculate the voltage signal
- ieee1057_3(M, voltn, &volt);
- printf("volt.A = %10.2f, volt.B = %10.2f, volt.C = %10.2f\n", volt.A, volt.B, volt.C);
- printf("volt.A0 = %10.2f, volt.theta = %10.2f\n", volt.A0, volt.theta);
- //calculate the current signal
- ieee1057_3(M, curtn, &curt);
- printf("curt.A = %10.2f, curt.B = %10.2f, curt.C = %10.2f\n", curt.A, curt.B, curt.C);
- printf("curt.A0 = %10.2f, curt.theta = %10.2f\n", curt.A0, curt.theta);
- //estimate dut's impedance parameters
- impedance(&volt, &curt, &dut);
- //alternatively, use the following call to convert the data
- //Z_measure(M, voltn, curtn, &dut);
- printf("dut.Z = %10.2fohm, dut.Zr = %10.2fohm, dut.Zi = %10.2fohm\n", dut.Z, dut.Zr, dut.Zi);
- printf("dut.theta = %10.2f\n", dut.theta);
- printf("dut.Zr = %10.2f, dut.Zi = %10.2f, dut.%1s = %10.2e(u%1s)\n", dut.Zr, dut.Zi, (dut.Zi < 0)?"C":"L", dut.LC*1e6, (dut.Zi < 0)?"f":"h");
- return 0;
复制代码 It is practically identical to the one I posted a couple days ago, with the following exception:
1) notational changes: I moved to a notation system identical to IEEE1057's.
2) implemented a data generation module: data_gen1() generates two vectors, based on a voltage signal (buffer_v[]), and a current signal (buffer_c[]). buffer_c[] is generated assuming that the voltage signal runs through a known impedance (specified as dut in the data_gen1() routine), then go through an inverting amplifier with Rm as its feedback resistor -> aka an autobalancing bridge.
In this particular case, we are assuming a dut with impedance of 1kohm, and -45 degrees of Rx (a capacitor of 22.5079n @ 10Khz). We expect that our code should estimate such parameters. Here is the output:
- volt.A = 98.52, volt.B = -17.38, volt.C = 499.45
- volt.A0 = 100.04, volt.theta = 0.17
- curt.A = -81.92, curt.B = -57.35, curt.C = 999.49
- curt.A0 = 100.00, curt.theta = -0.61
- dut.Z = 1000.42ohm, dut.Zr = 707.40ohm, dut.Zi = -707.41ohm
- dut.theta = -0.79
- dut.Zr = 707.40, dut.Zi = -707.41, dut.C = 2.25e-02(uf)
复制代码 So we have Z = 1000.42ohm vs. 1000ohm, C of 22.4983n vs. 22.5079n.
That's pretty good.
3) one small note: for convenience purposes, I introduced a new routine, Z_measure(), which essentially estimates dut's parameters from the sampled data series. You can obtain the same results via calling ieee1057_3() or impedance(), as I did in the code above. |
