FIBOCOM G600
FIBOCOM G600G600: Dual-band, miniaturized GPRS Module
Fibocom G600 GPRS module comes as all-round module suitable for a host of fields: security, vending, metering, gateways, remote maintenance and control, routers etc. The dual-Band technology allows the module to be used anywhere in the world.
General features
• Dual-Band GSM/GPRS 850/1900 MHz; GSM/GPRS 900/1800 MHz G600 GPRS模块
• GPRS multi-slot class 10/8
• GPRS mobile station class B
• Compliant to GSM phase 2/2+
– Class 4 (2W @ 850/900MHz)
– Class 1 (1W @ 1800/1900MHz)
• Dimension: 35.0 x 32.5 x 3.0 mm
• Weight: 6 g
• Control via AT commands (GSM 07.07, 07.05 and Fibocom enhanced AT Commands)
• SIM application toolkit
• Supply voltage range 3.3V...5.2V
• Low power consumption
• Normal operation temperature: -30℃ to +75℃
• Storage temperature: -40°C to +85°C
Specifications for fax
• Group 3, class 1
Specifications for data
• PBCCH support
• GPRS class 10: max. 85.6 Kbps (downlink)
• PPP-stack
• Coding schemes CS 1, 2, 3, 4
• CSD up to 14.4 kbps
• USSD
• Transparent mode
Specifications for SMS via GSM
• MO/MT Text and PDU modes
• SMS cell broadcast
Specifications for voice
• Tricodec
– Half rate (HR)
– Full rate (FR)
– Enhanced Full rate (EFR)
• Hands-free operation (Echo suppression)
Interfaces
• Interface to external SIM 3V/1.8V
• Two analog audio interfaces
• RTC backup
• Serial interface and debug interface
• LCD interface
• Keypad interface
• Single 50pin board to board
