论坛里讲PID原理的挺多,但是讲算法的实现却比较少,或是比较难懂,今天网上找到一个老外写的PID C语言实现,P ,I ,D 各环节独立实现,还是比较好理解的。- PID算法(c 语言)(来自老外)
- (2010-02-17 00:18:24)
- 转载
- #include <stdio.h>
- #include<math.h>
- //定义PID 的结构体
- struct _pid
- int pv; //integer that contains the process value 过
- 程量
- int sp; //*integer that contains the set point 设
- 定值
- float integral; // 积分值 -- 偏差累计值
- float pgain;
- float igain;
- float dgain;
- int deadband; //死区
- int last_error;
- struct _pid warm,*pid;
- int process_point, set_point,dead_band; float p_gain, i_gain, d_gain,
- integral_val,new_integ;;
- pid_init DESCRIPTION This function initializes the
- pointers in the _pid structure to the process variable
- and the setpoint. *pv and *sp are integer pointers.
- void pid_init(struct _pid *warm, int process_point,
- int set_point)
- struct _pid *pid;
- pid = warm;
- pid->pv = process_point;
- pid->sp = set_point;
- ----------------------pid_tune DESCRIPTION Sets the proportional gain
- (p_gain), integral gain (i_gain),
- derivitive gain (d_gain), and the dead band (dead_band)
- of a pid control structure _pid.
- 设定PID参数 ---- P,I,D,死区
- void pid_tune(struct _pid *pid, float p_gain, float
- i_gain, float d_gain, int dead_band)
- pid->pgain = p_gain;
- pid->igain = i_gain;
- pid->dgain = d_gain;
- pid->deadband = dead_band;
- pid->integral= integral_val;
- pid->last_error=0;
- ---------------------- pid_setinteg DESCRIPTION Set a new value for the
- integral term of the pid equation.
- This is useful for setting the initial output of the
- pid controller at start up.
- 设定输出初始值
- void pid_setinteg(struct _pid *pid,float new_integ)
- pid->integral = new_integ;
- pid->last_error = 0;
- pid_bumpless DESCRIPTION Bumpless transfer
- algorithim.
- When suddenly changing setpoints, or when restarting
- the PID equation after an extended pause,
- the derivative of the equation can cause a bump in the controller output. This function will help smooth out
- that bump.
- The process value in *pv should be the updated just
- before this function is used.
- pid_bumpless 实现无扰切换
- 当突然改变设定值时,或重新启动后,将引起扰动输出。这
- 个函数将能实现平顺扰动, 在调用该函数之前需要先更新 PV值
- void pid_bumpless(struct _pid *pid)
- pid->last_error = (pid->sp)-(pid->pv); //设定值与反馈值偏差
- pid_calc DESCRIPTION Performs PID calculations for the
- _pid structure *a. This function uses the positional form of the pid
- equation, and incorporates an integral windup
- prevention algorithim.
- Rectangular integration is used, so this function must
- be repeated on a consistent time basis for accurate
- control.
- RETURN VALUE The new output value for the pid loop.
- USAGE #include "control.h"
- 本函数使用位置式PID计算方式,并且采取了积分饱和限制运算
- PID计算
- float pid_calc(struct _pid *pid)
- int err;
- float pterm, dterm, result, ferror;
- // 计算偏差
- err = (pid->sp) - (pid->pv);
- // 判断是否大于死区
- if (abs(err) > pid->deadband)
- ferror = (float) err; //do integer to float
- conversion only once 数据类型转换
- // 比例项
- pterm = pid->pgain * ferror;
- if (pterm > 100 || pterm < -100)
- pid->integral = 0.0;
- else
- // 积分项
- pid->integral += pid->igain * ferror;
- // 输出为0--100%
- // 如果计算结果大于100,则等于100
- if (pid->integral > 100.0)
- { pid->integral = 100.0;
- // 如果计算结果小于0.0,则等于0
- else if (pid->integral < 0.0)
- // 微分项
- dterm = ((float)(err - pid->last_error)) * pid->dgain;
- result = pterm + pid->integral + dterm;
- else
- result = pid->integral; // 在死区范围内,保持现有输出
- // 保存上次偏差
- pid->last_error = err;
- // 输出PID值(0-100)
- return (result); }
- void main(void)
- float display_value;
- int count=0;
- pid = &warm;
- // printf("Enter the values of Process point, Set
- point, P gain, I gain, D gain \n");
- // scanf("%d%d%f%f%f", &process_point, &set_point,
- &p_gain, &i_gain, &d_gain);
- // 初始化参数
- process_point = 30;
- set_point = 40;
- p_gain = (float)(5.2);
- i_gain = (float)(0.77);
- d_gain = (float)(0.18);
- dead_band = 2;
- integral_val =(float)(0.01);
- printf("The values of Process point, Set point, P gain,
- I gain, D gain \n");
- printf(" %6d %6d %4f %4f %4f\n", process_point,
- set_point, p_gain, i_gain, d_gain);
- printf("Enter the values of Process point\n");
- while(count<=20)
- scanf("%d",&process_point);
- // 设定PV,SP 值
- pid_init(&warm, process_point, set_point);
- // 初始化PID 参数值
- pid_tune(&warm, p_gain,i_gain,d_gain,dead_band);
- // 初始化PID 输出值
- pid_setinteg(&warm,0.0);
- //pid_setinteg(&warm,30.0);
- //Get input value for process point
- pid_bumpless(&warm);
- // how to display output
- display_value = pid_calc(&warm);
- printf("%f\n", display_value);
- //printf("\n%f%f%f%f",warm.pv,warm.sp,warm.igain,wa
- rm.dgain);
- count++;
复制代码 PDF文档:
