发表于 2013-11-5 11:21:11
w111liang222 发表于 2013-11-5 08:55
请教下火哥如何配置优先级分组
用 CMSIS 库 即可,我贴 一下 源代码:- /** \brief Set Priority Grouping
- This function sets the priority grouping field using the required unlock sequence.
- The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field.
- Only values from 0..7 are used.
- In case of a conflict between priority grouping and available
- priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
- \param [in] PriorityGroup Priority grouping field
- static __INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
- uint32_t reg_value;
- uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07); /* only values 0..7 are used */
- reg_value = SCB->AIRCR; /* read old register configuration */
- reg_value &= ~(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk); /* clear bits to change */
- reg_value = (reg_value |
- ((uint32_t)0x5FA << SCB_AIRCR_VECTKEY_Pos) |
- (PriorityGroupTmp << 8)); /* Insert write key and priorty group */
- SCB->AIRCR = reg_value;
- /** \brief Enable External Interrupt
- This function enables a device specific interrupt in the NVIC interrupt controller.
- The interrupt number cannot be a negative value.
- \param [in] IRQn Number of the external interrupt to enable
- static __INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
- /* NVIC->ISER[((uint32_t)(IRQn) >> 5)] = (1 << ((uint32_t)(IRQn) & 0x1F)); enable interrupt */
- NVIC->ISER[(uint32_t)((int32_t)IRQn) >> 5] = (uint32_t)(1 << ((uint32_t)((int32_t)IRQn) & (uint32_t)0x1F)); /* enable interrupt */
- /** \brief Set Interrupt Priority
- This function sets the priority for the specified interrupt. The interrupt
- number can be positive to specify an external (device specific)
- interrupt, or negative to specify an internal (core) interrupt.
- Note: The priority cannot be set for every core interrupt.
- \param [in] IRQn Number of the interrupt for set priority
- \param [in] priority Priority to set
- static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
- if(IRQn < 0)
- SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);
- } /* set Priority for Cortex-M System Interrupts */
- else
- NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);
- } /* set Priority for device specific Interrupts */
复制代码 |
